Trade: Licensed Home Improvement Contractor
Mower Problems
My mower wont start. Any of you guys know small engines? If I prime is it will start and die . Its not getting gas I guess.
Home Improvement Guy
Trade: Renovations contractor
Re: Mower Problems
Is the filter clean?
Have you just taken it out of winter storage? Changed the spark plug lately? Is the gas fresh? Is it 2 stroke or 4 stroke?
Don't worry, the baseboard will hide it! |
Re: Mower Problems
If it starts and dies, you most likely have a fuel problem. My first guess is that the float valve needle is stuck to the seat.
MFWIC
Trade: house painter
Re: Mower Problems
really need more info... what kind, size mtr and all, but,
how did u prime? if it starts and then gives up, there is junk in the carb that needs to be cleaned out that is blocking a jet. any prime system overcomes function of jetting with a big slosh, just for the cold start. soon as that fuel burns, ur back to getting nothing. usually gotta pull the carb completely off and blow out passages w compressed air and clean gunk out of float bowl if it uses one. there are briggs motors out there with bowl inside tank kinda like a little teaspoon in there... with a pickup tube going into it. if its dry, or gunky, will start with prime, and maybe choke, but won't run... r |
ContractorTalk Flunkie
Re: Mower Problems
My pressure washer done it last year, it was bad (old) gas
. Dumped the tank and refilled with fresh and VaRooooooooom it went!
T.C. "Never met a man yet that I couldn't learn something from"Met a few you couldn't teach though http://remodelingncarolina.com
Re: Mower Problems
I change the air cleaner, plug and replace the old gas every year. I guess its the carb. Its 9 seasons old. Any suggestions on a new mower? I have a smaller yard. The mower that died was a 6 hp 22 inch. BTW that old gas thing used to get me. Im on to that. I always change the gas.
Trade: residential (marine) piers
Re: Mower Problems
water (condensation)in the fuel tank? (Sop it dry with paper towels)
Palisade Point Const.
Re: Mower Problems
I've seen that happen before- clean and rebuild the carb and it should be fine
#9 | |
Trade: Carpenter/Painter
Re: Mower ProblemsQuote:
Go and buy some stable and treat all your gas that you have for your lawn equipment unless you know you will be burning it up soon. |
#10 | |
I use an Ariens 21 with the swivle wheels that can be locked out. Has a brigs intek. Mulches, bags , side discharge . They were going for about 5 hun when I bought mine. The hondas are nice with the blade break and double blades. They willl run you much more jing , but are real nice mowers and they have models with the swivle wheels as well. |
| Construction Records Problems | PalAl2000 | Commercial Construction | 5 | 05-15-2007 07:56 PM |
| Common Patio Door Problems | adriand | Remodeling | 1 | 01-14-2007 01:27 AM |
| What lawn mower to buy exmark or toro | Hockeyman | Landscaping | 3 | 09-20-2006 11:56 PM |
| Solving Problems | dayspring | Off Topic (Non Trade) | 13 | 06-15-2006 08:45 PM |
| Ad-Aware found problems | Floorwizard | Technology | 15 | 06-10-2006 04:11 PM |
