More Paslode Problems
Old 02-16-2008, 11:30 AM   #1
Shoreline58's Avatar
Rewards Points: 77
I have been checking the posts for Paslode issues but have not seen my problem. Paslodes website kinda sux when it comes to troubleshooting.
My 18 ga. brad nailer is giving me trouble. Went to use it for the first time in a month or so yesterday and after charging the battery and inserting it in the gun I got no green LED on the handle and no fan. Went out and slapped down $55.00 for a new battery and charged it overnight. Same thing, no LED and no fan. Checked the contacts for corrosion, none there. Checked the connections under the filter, all tight.
Any ideas????
Shoreline58 is offline
Old 02-18-2008, 01:52 PM   #2
bonnie scotland's Avatar
Trade: carpenter / joiner
Location: I live in Scotland (uk) where it always rains
Re: More Paslode Problems
[quote=Shoreline58;379877]I have been checking the posts for Paslode issues but have not seen my problem. Paslodes website kinda sux when it comes to troubleshooting.
Any ideas????[/qu
you will have to split the handle and and inspect the spark unit for signs of damage . Have you cleaned it lately, if you have, cleaning fluid can run back into the unit and damage it .If it is that over here in scotland that part would cost me 85 so for you it must be well over$120 . also if you have not dismantled your gun for cleaning but just checked the terminals by looking down the battery holder, these terminals can break and I have had to replace them twice on my gun.
bonnie scotland is offline
Old 02-24-2008, 11:06 PM   #3
LaTorre Masonry's Avatar
Trade: Mason
is it an older gun with the real long battery ( like 9" long)? For some reason the contacts would bend, or compress in these after a while. on our old Trakfast guns that use the same battey, my guys started sticking washers or quarters under the bottom, like a shim, so they would push the battery tighter in the compartment and make contact
not an authorized repair, but kept our jobs going!
LaTorre Masonry is offline
Old 03-08-2008, 11:03 AM   #4
Continuous Improvement
crabpainter's Avatar
Trade: paslode tool repair technician
split the handle and look at the connectors on ESU (Electronic Spark Unit). Please keep me informed.
crabpainter is offline
Old 03-26-2011, 07:40 AM   #5
WJTR's Avatar
Trade: carpentry, remodeling
Rewards Points: 25
Anybody know anything about the older Paslode cordless framing gun as far as shooting 2 nails at a time? Also, the gun seems to cycle and run longer after the nail is shot than it used to. Thanks guys.
WJTR is offline
Old 03-26-2011, 01:15 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
look up "LONEFRAMER" here and send him a personal message, hes a paslode junky, he can help you out
woodworkbykirk is offline
The Following User Says Thank You to woodworkbykirk For This Useful Post:
loneframer (03-26-2011)
Old 03-26-2011, 03:57 PM   #7
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Generally, if it's shooting 2 nails, it's more likely the nail strips than it is the gun. The paper collation is prone to failure if allowed to get wet or lays in the sun too long. It's better than it was years ago, on the Paslode brand that is. Some of the generic nails are pretty crappy.
There is the possibility that the nosepiece of the gun is loose, allowing the nails to advance too far. It could also be that the gun has excessive wear in the guide, also allowing the nails to advance too far.
Also, check the driver blade on the piston to make sure it's not bent and file any burrs off of it.
loneframer is offline
Old 03-26-2011, 07:00 PM   #8
WJTR's Avatar
Rewards Points: 25
thanks Loneframer on the advice with the paslode cordless nailer. I'll check all of that and try going just with the paslode fasteners.
WJTR is offline
Paslode Impulse Problems PLC-Landscape Tools & Equipment 53 03-15-2014 09:42 PM
Paslode impulse framing gun problem's tmerring64 Tools & Equipment 19 03-26-2011 07:52 AM
super corner problems?? softtop95ta Windows, Siding and Doors 22 02-12-2008 08:38 PM
Construction Records Problems PalAl2000 Commercial Construction 5 05-15-2007 06:56 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 12:27 AM
