Modifying A Skill 2972 Cordless Screwdriver
Old 06-08-2006, 03:46 PM   #1
...jammin
slickshift's Avatar
Trade: Rock Disciple
From another thread:
Originally Posted by DeepOne
I himself use modified for external power input (and replaced inner non-removed battery pack) Skil 2972 screwdriver (7,2V 0,8Ah Ni-cd). This alteration make from toys useful tool, which not yield both mentioned screwdrivers.
(the screwdrivers mentioned would be the Bosch GSR10.8Li and the metabo powermaxx)
Link to pics and text of DeepOne's modified Skill:
http://forum.4-mastera.ru/index.php?showtopic=663
(Not in English, but well worth it for the pics and Drago's "Dancing" Star Wars Storm Trooper avatar
DeepOne, could you tell me did you modify the Skill 2972 for more power or a better power supply?
Is it still a 7.2v tool?
Signature Quote
slickshift is offline
Old 06-08-2006, 06:11 PM   #2
DeepOne's Avatar
Trade: unlicensed electrician
Re: Modifying A Skill 2972 Cordless Screwdriver
Yes, Slickshift, it is a 7,2V screwdriver, but external lead-acid 6V battery bring him at once more power and better supply, because this battery has good AMP rating. In total, motor RPM and torque higher with this, then the internal 7,2V AA-sized battery. Also this screwdriver need replace internal battery pack because originally mounted elements, labeled "BYD" is very low quality device. With new battery pack soldering from "Camelion" 0,8Ah Ni-cd elements (designed for high drain devices, 0.7$ per unit, need six) this screwdriver can twist double amount of screws, then the original battery. External 6V battery may be plugged up if internal power source is near empty and its voltage reduced. Common battery capacity constitute 5Ah. I have exploit this screwdriver more than a year and i suppose it very useful in electric installation and light wood construction.
DeepOne is offline
Old 06-08-2006, 06:29 PM   #3
Downeast's Avatar
Trade: Carpenter/Painter
To heck with the star wars dude,check out the babe on the flashing avitar page 2.
Downeast is offline
Old 06-08-2006, 07:38 PM   #4
...jammin
slickshift's Avatar
Yes, Slickshift, it is a 7,2V screwdriver, but external lead-acid 6V battery bring him at once more power and better supply, etc....
Thank you for the explanation
I find that very interesting
Signature Quote
Old 06-09-2006, 02:03 PM   #5
DeepOne's Avatar
If you want to read russian topics, you may use tidy convertor english<>russian "Socrat 4". It may be downloaded from
(ftp softlinks.ru/4045279/spers41.exe). It's size 5.88MB. I found it today .
Can be interesting this, for example:
forum.kstr.ru/index.php?topic=366.0 - around Panasonic screwdriver;
mastercity.ru/cgi-bin/ml.cgi?test&44 - test of small screwdrivers;
mastercity.ru/vforum/ - big forum, similar this;
forum.4-mastera.ru/index.php?showtopic=569&st=0 - Bosch4DFE inside;
etc.
DeepOne is offline
Skill saws for framing hrscammisa Framing 80 12-04-2008 04:57 AM
Cordless drill ProWallGuy Tools & Equipment 61 09-28-2008 03:17 AM
Impact Driver Nick H Tools & Equipment 24 02-21-2008 07:37 PM
Milwaukee V28 Lithium Ion Cordless R&S Exteriors Tools & Equipment 3 08-11-2006 10:40 AM
metabo powermaxx cordless screwdriver mc_ci Tools & Equipment 6 06-08-2006 01:42 PM
