Milwalkee 12v LI Driver
Old 11-23-2008, 10:23 PM   #1
Renegade 1 LI's Avatar
Trade: heavy construction
I just picked one up about 2 weeks ago & I think for light duty work it is ok. It needs a 2 speed tranny so it drills a little faster, but the power seems good. I also picked up the flashlight that uses the same battery & it's bright, light weight & easily fits into your pouch. It also fits into the soft case from the driver. I really like the quick release chuck, just slip it foward & the bit drops right out & then pop in a new bit & it locks as you push it in. I also picked up their bit set in the hard plastic case & was surprised that the 6" bit extension does not use the same chuck as the driver, too bad. I'll see how it holds up on the job site next week.
Renegade 1 LI is offline
Dewalt impact driver.....DC827N frain21 Tools & Equipment 6 10-18-2008 05:31 PM
dewalt drill driver cuts in and out 72chevy4x4 Tools & Equipment 10 09-17-2008 05:47 PM
Bosch 10.8v impact and driver...Jac Pac system jeffaah Contractor Swap 0 08-19-2008 05:41 PM
Do you use an impact driver? Quick survey help would be very much appreciated. cohaver General Discussion 4 04-02-2008 07:20 PM
