Max Framing Nailer - Paper & Plastic Strip?
Old 03-26-2010, 10:33 PM   #1
Kastoria's Avatar
Trade: Custom Metal Fabrication/Residential Construction
Rewards Points: 154
Hey I was interested in getting the low profile Max FRH nailer (SN883RH). When I read the review it said it uses both paper strip and plastic strip nails. Sounds great to me but do have some questions to any Max users...
Does the paper and plastic strip nails both work equally well in the gun or is one better than the other? Also, what paper strip brands work? For instance, will paslode nails work since they are paper (doubt it)?
So if you can fill me in on the performance that would be great. Now I only have Hitachi nailers and no problems - just getting nails sometimes is a pain. Thats why I want to go with the paper/plastic so I can get paper strips when available and vice versa.
Thanks
Kastoria is offline
Old 03-27-2010, 06:12 AM   #2
DrewD's Avatar
Trade: General Contracting/CM
Rewards Points: 250
Re: Max Framing Nailer - Paper & Plastic Strip?
I use the larger Max FRH nailer (Superframer I believe) and always have used Bostitch plastic collated nails with no problems. When Western Tool Supply was in business around here I was nearly buying them by the pallet because they were such a good deal. Some guys don't like all the little plastic bits everywhere but it never bothered me. Also, I feel the plastic collated hold up better when left out in the elements. As for the paper collated, sorry, never had any experience with them. Your going to be real happy with that gun though.
DrewD is offline
Old 03-27-2010, 02:10 PM   #3
Feedin the geese
Joining_heads's Avatar
Trade: Finish Carpenter
Rewards Points: 286
I have the gun but only use plastic collated nails because they are easier to find here, plus the durability factor stated by drew.
It's a great gun. Light and compact but not lacking in power,
Joining_heads is online now
Old 03-27-2010, 06:56 PM   #4
Kastoria's Avatar
Rewards Points: 154
Ive always use plastic strip and never cared about the plastic bits (unless it catches you in the eye, that sucks). But I figure if I have a gun that uses both it would be nice to know what kind fit the gun...Im not for sure but think paslodes are only good for the paslode guns, so what else is there then. Either way, its not gonna prevent me from getting the nailer.
Thanks guys
Kastoria is offline
coil framing nailer??? johndel1971 Tools & Equipment 22 03-22-2009 10:00 AM
makita an901 nailer johndel1971 Tools & Equipment 2 03-11-2009 05:38 PM
Framing nailer from Harbor Freight RomZes13 Tools & Equipment 22 05-31-2008 08:02 PM
Who uses a coil framing nailer? buildenterprise General Discussion 12 05-01-2008 11:58 AM
bosch framing nailer S&P Builders Tools & Equipment 7 02-20-2006 04:54 PM
