Makita Plunge Cut Saw
Old 05-02-2009, 10:06 PM   #21
Remodeler Extraordinare
A.W.Davis's Avatar
Re: Makita Plunge Cut Saw
Nice.....I think I need to buy 3 of those!
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 05-02-2009, 11:40 PM   #22
Originally Posted by FowlOne View Post
Greatest coach of all time
I grew up down in bama, it's pure tourcher living up here in Irish country
See, we gotta 'splain Bear
to the kids on here.
neolitic is offline
Old 05-03-2009, 09:20 PM   #23
Master Baiter
FowlOne's Avatar
Trade: Commercial/Residential Subcontractor
haha, i'm actually impressed an Indiana guy picked him out...
Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. - Ronald Reagan
FowlOne is offline
Old 05-03-2009, 11:55 PM   #24
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
For anyone wondering about the blades.
I'm the guy who wrote the tracks saw review in JLC. I looked at the blades but there wasn't space to cover them in the article.
The Makita and Dewalt take 20 mm x 165 mm blades. They are completely interchangeable. I know because I swapped them to see if they'd fit. The Festool takes 20 mm x 160 mm blades - that will fit on the Makita and Dewalt. The 160 mm blade will give you slightly less depth of cut (on the Dewalt and Makita).
This might matter if you are cutting a 2 1/4-inch door but shouldn't matter with sheet goods - unless, you want to use the end-of-cut indicator marks. These marks are on the side of the blade housing and indicate the front and back end of the cut at maximum plunge. Switching to a smaller diameter blade will throw them off.
The marks on the Festool and Makita align pretty well with the ends of the cut when the saw is on the rail. Makita has a second set of marks for when the saw is off the rail (though I can't think of a circumstance where I'd want to make stopped plunge cuts without using a rail). The marks on the Dewalt are not mentioned in the manual. I think this is because they put them in the wrong place. They only work when the saw is NOT on the rail.
Someone already mentioned the thickness of the blades. The ones that come on the Dewalt and Makita have 2.2 mm kerfs. I can't remember what the Festool has - but know they make multiple thicknesses. If you use a thick blade and then switch to a thinner one - the splinter guard will no longer come all the way up to the blade.
Hope this helps.
Dave Frane
JLC
http://forums.jlconline.com/forums/s...7&postcount=60
Just figured I'd pass it on.
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 05-04-2009, 06:11 PM   #25
I like Green things
WarnerConstInc.'s Avatar
Actually, Festool just changed their blades so that all of them have the same kerf. Enough people complained about different kerf's and the splinter strip so Festool changed.
WarnerConstInc. is online now
Old 05-04-2009, 10:39 PM   #26
Southern Build's Avatar
Trade: Doing it right the first time
Thumbs down
It looks like Tool Plus is now out of the saws ... Maybe they are planing a quick price increase also.
Southern Build is offline
Old 05-08-2009, 07:54 PM   #27
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
I'll let you know................
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 05-08-2009, 08:29 PM   #28
Tech Geek
WOW, that was fast!
-Dennis
www.bowmanch.com
Old 05-08-2009, 08:40 PM   #29
I like Green things
Jason, I want to see Makita's Systainer. It's variable speed right? You are going to let the field guys use it right? Let me know how it holds up to the grunts abuse!!
Old 05-08-2009, 09:59 PM   #30
Tech Geek
Dude, I'm no grunt. I am the "field guy" that will be using it though. Yes it's a variable speed saw.
-Dennis
www.bowmanch.com
Old 09-01-2010, 05:34 PM   #31
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
I am taking the plunge and getting the makita...however, how is the accuracy when you couple two 55" tracks together? I don't have room for the long track, but could store the shorter ones much easier. Do they couple nice? Do the Festool couplers work with the Makita rails?
TBFGhost is online now
Old 09-01-2010, 05:57 PM   #32
jiffy's Avatar
Trade: General Construction
Found it cheaper here:
http://www.wholesalepowertools.com/m...uide-rail.html
jiffy is offline
Old 09-01-2010, 06:29 PM   #33
I like Green things
I would just get the TS-55, tried and proven and you don't have to mix and match parts and accessories.
I join rails all the time without issue.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
Old 09-01-2010, 08:13 PM   #34
alboston's Avatar
Havent heard alot about the makita plunge. The TS-55 is obviously great. I use the Dewalt but am thinking of getting the TS-55 soon. The makita might be a bit cheaper but the others are proven. Or atleast that is what I think.
alboston is offline
Old 09-01-2010, 09:19 PM   #35
I like Green things
yeah kind of, Festool came out with the first rail guided saw in the 60's.
Old 09-01-2010, 10:19 PM   #36
s. donato's Avatar
does the makita have a riving knife?
BSA Renovations - Restoration and Renovation Specialists serving New Jersey's Bergen County.
Bergen County's Premier Home Maintenance Provider.
s. donato is offline
Old 09-01-2010, 10:46 PM   #37
jiffy's Avatar
I see no advantages to going Green on this tool. Imitation is the highest form of flattery, and it also leads to better products. The Makita has some nice features that the Festool does not and a nice price too.
jiffy is offline
Old 09-01-2010, 11:14 PM   #38
I like Green things
No it does not. Which I think is the best feature of this type of saw.
Old 09-02-2010, 01:40 AM   #39
SEMI RETIRED
griz's Avatar
Hey Warner, Can you recommend a supplier for the green stuff. No one in my neck of the woods has them and few have even heard of them.
griz is online now
Old 09-02-2010, 08:40 AM   #40
Restoration Crazy
Here you go. http://lmgtfy.com/?q=Festool+dealers+in+California
Facebook | Twitter
Makita Table Saw Problem....... Donegal Tools & Equipment 1 04-01-2009 11:34 PM
Makita chain mortiser Lubs Carpentry 9 03-15-2009 07:16 PM
makita an901 nailer johndel1971 Tools & Equipment 2 03-11-2009 06:38 PM
Makita TD090DW VS. Bosch PS40-2 EsotericMason Tools & Equipment 13 02-26-2009 06:23 PM
Help!! Need a new makita carry case will90 Tools & Equipment 1 02-11-2009 12:55 PM
