LRG WoodCrafting
It Lives...
Since I was wasting time cleaning my shop I decided to try to repair my Jet table saw. About 1 1/2 years ago it started making an awful whine whenever it was running. Sounded like bearings. So I just got a new saw, put this one aside and just used the new one.
I got the bearings for it about 6 months ago, pretty cheap, $13 ea and I need two. Original OEM parts from WHM. I had the exploded drawing, a crappy one and the bearings. So here we go. I took the side shroud off and lowered the blade, took off 3 belts and could see the nut that holds the arbor on. After some finagling I got the nut off and the serrated washer out. Now there was a spanner nut that needed to come out, it holds the bearing in the casting. Time to make a tool. Found a pc of 1/8" steel kicking around the shop and I shaped it on my edge sander, took about 15 minutes and I had a spanner wrench. Popped it on the spanner nut and twisted it and it came out - yea. Now I was looking at the bearing. At this point I figured the arbor needed to be pushed out. Uh-huh. Put the nut on the arbor and gave it a couple of whacks to see if it would move, nope. Called Jet and got the techs voice mail. Left a message. A buddy of mine came by at that point and we started working on it together. We both agreed the next thing was to get the arbor out. He suggested a dowel and rap it good and hard. So I did and we got it to move until the dowel bottomed out on the bearing. He went to get a punch. I found a 1/2" x8" lag bolt. The arbor had a dimple in the end of it and I put the lag bolt into the dimple and started hammering. And after a few minutes of that it was out. Now we needed to get the bearings out of the casting. A bolt a few washers and a large socket and we had a bearing puller. Got both bearings out in 10 minutes. The first one was harder than the second. Got out the new bearings and put the first bearing on the arbor shaft after we cleaned and oiled it. Put the spring washer, spacer on the shaft, inserted it in the casing and put the pulley on. Then commenced with the banging to get the bearing seated into the casting. Got it in about 3/4 way and then the shaft was far enough so we could start using the thread on the end of the shaft to pull it in. Got it most of the way in. Put the other spacer and bearing in and used a socket to seat it. This one was easier than the first. Put on the spanner nut and tightened it down. Seemed to be in a bit more than it was originally, the wrench I made was hitting the casting when it wasn't before. So I put the serrated washer and the nut on. We tightened the set screw on the pulley and we were done. Found the cord and plugged it in. Fire in the hole. Pushed the on button and it fired up. No squealing, mission accomplished. Popped a blade on, the blade is slightly more left than it was originally, about 0.007". I haven put the fence on so it hasn't been tested. But it worked before and it fires up. I now had a second tablesaw. Would have been nice to have on the last job ![]() The tech called pretty much as we were finishing up (of course). It was good timing as we had a question about the tightness of the spacers against the pulley. He was able to answer us and it reassured us. It was good timing. Total job was about 2 hours time.
I like Green things
Re: It Lives...
Even wood butcher's have some mechanical skill.
I cant believe you bought a new saw over 13 dollars worth of bearings and a couple hours work. All those Coke cans are probably half empty too!!! Have fun with 2 saws. |
LRG WoodCrafting
Re: It Lives...
The saw was dying and I needed one. Kinda the main tool in the shop. It was old, going on 20+ years, it was underpowered (worn bearings ??). Dad actually bought me the new saw, sort of surprised me with it. Glad I got it too. Much better cuts with the new saw. I use to have to have a very very sharp blade to get good quality crosscuts in plywood on the old Jet. Now with the new Delta Unisaw just a sharp blade gave excellent results with the crosscuts. I didn't know the bearings were the problem, I didn't know if they were available. I didn't know how long the job would take or if I could do it in my shop or if I would have to pull the arbor assembly out and send it out to a machine shop. I asked around and no one had done the job on a Jet, just Powermatics, and it was a different setup.
I have excellent mechanical skills. I can do just about anything. But I know that I can't lay brick, way to slow to make any kind of money there.
Re: It Lives...
Good for you.
I'm sure the three of you will be very happy together.
Re: It Lives...
Really, two saws is a dream
set up. Maybe this will inspire me to fix the motor mount on my old one. Probably not though.
Re: It Lives...
Sounds like a winner!
Nobody rebuilds stuff anymore just as you didn't/did. I save thousands a year DIYing it.
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
Re: It Lives...
Pics or it didn't happen!
LRG WoodCrafting
Re: It Lives...
Pics or not, it did happen. Way to late for pics now. I could show you pics of the old bearings and what the arbor looks like installed. But I doubt that would be very exciting.
#9 | |
Re: It Lives...Quote:
makes me feel all warm and fuzzy.
LRG WoodCrafting
Re: It Lives...
I was just so happy that I didn't have to take the machine apart to get at the arbor. They said you could do it from the top of the machine. But I did most of the work from the side of the machine. I wish I had taken pics. I could have set up a tutorial for it and charge the big $ching$ for it.
| Closing up shop | Patrick | Windows, Siding and Doors | 69 | 01-07-2010 11:56 PM |
| Past Lives | neolitic | Off Topic (Non Trade) | 2 | 11-30-2008 12:32 AM |
| Highway tunes | ChainsawCharlie | Off Topic (Non Trade) | 0 | 09-21-2008 11:27 PM |
| Anybody Know one of these Guys? | sonny | Off Topic (Non Trade) | 8 | 08-22-2007 06:47 PM |
| A Moment of silence, remembrance, and embrace | Mud Master | General Discussion | 7 | 04-17-2007 05:03 PM |
