Jenny's have the same issues the old emglos had. Run way to hot, burn oil, flat tires, decks cracking, valves baking shut, hard to work on, hard on the engines, tires going flat, hard to drain air etc etc. There is newer out there, you just have to pay for it.
Jenny used to make the tanks for emglo. Jenny does not own the old emglo plant. The second plant emglo was in is owned by my grandpa, the plant they where in before they moved to mexico, was turned into a hardware supply store.
If you want the top of line get J-Air. It is designed by the person who designed all the emglo pumps and compressors from the 70's on. In fact the G pump is named after him. Fixed all the issues, Decks wont crack they are beefed up and reinforced in 3 places. Vertically mount pilot valves to keep the water and dirt from getting caught and staying in there, ball drain valves to drain the tanks, flat free tires (roll like pneumatic but wont go flat), newer pump tech nology, there are two 5.5 hp pumps availabe. One runs 120degrees cooler and puts out 20% more air then an old emglo, one runs 100 degrees cooler and puts out .1 cfm more air (you will notice a difference though because of the way the unit is designed to deliver the air to the guns). Easy to use belt tighteningin system, can be done with one 9/16 wrench. Oil site glasses. Automatic cold start valves on pumps so the engine is easier to pull start and allows lower idle. 9 gallon tank for easier wheeling and more air storage. Heavy steel forging holding tire in to keep from busting out, when dropped out of truck. Heavy duty legs (we test these by dragging the units behind a pickup truck a 1/4 mile).
Anyway, most places sale the j-air in blue, or orange, your choice really.
Have a good night
