Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 08-23-2006, 06:55 PM   #1
Oldguy
Trade: general
jamb saw
Has anyone used the Roberts 10-40 jamb saw? I have an opportunity to buy one very inexpensively. TIA
Rehabber is offline   Reply With Quote
Old 08-23-2006, 07:12 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I would buy this instead, more versatile, inexpensive ($100.00 new) and won't kill you.
http://www.boschtools.com/tools/tool...=54928&I=55132
Mike Finley is offline   Reply With Quote
Old 08-23-2006, 07:54 PM   #3
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
Ditto on the Bosch. Just used mine today on a floor install.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 08-27-2006, 09:01 PM   #4
Trade: Lisc. General Contractor
The Bosch is a very versatile saw it has so many more uses than the jamb saw with the circular blade.
gtdail is offline   Reply With Quote
Old 08-27-2006, 09:02 PM   #5
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
If you need a forth opinion, Bosch. If you buy it and don't like it, send me the blades.
dougchips is offline   Reply With Quote
Old 08-27-2006, 10:12 PM   #6
Trade: General contractor
What else could you do with it?
Im looking at it as a possible pickup...but do I need it more than a hand jamb saw....?
415moto is offline   Reply With Quote
Old 08-27-2006, 10:28 PM   #7
Chief Toilet Mover
I don't think you will be able to use it too well as a pick up, maybe more as a station wagon.
There are lots of uses for it just as it is, but if you purchase it in the kit with the miter device it becomes even more versatile. On just about any bathroom job we are on the saw undercuts the framing on the doors, it cuts the Schluter transistion stirps using the metal blade and usually cuts a little shoe molding for under the vanity. Then of course there are other uses that you might find yourself using it for.
As for the hand saw, besides the obvious gain in productivity with the power version, I always had more of a chance to scar the wood with a missed stroke using the hand version, with the power version it just isn't an issue. But the gain in productivity is the main reason I like it.
Old 08-28-2006, 11:07 PM   #8
thanks mike
its on my to get list if i find it used.
Old 08-29-2006, 04:39 PM   #9
AtlanticWBConst's Avatar
We'll have to pick up that new toy also....
Thanks for the advice!
- Build Well -
AtlanticWBConst is offline   Reply With Quote
Old 08-29-2006, 05:25 PM   #10
Trade: Structural Engineer/Contractor Wanabee
I use this saw to also cut the shims off for pre-hung doors. Works great when you have some thick shims built up.
handyman923 is offline   Reply With Quote
Old 08-31-2006, 10:46 PM   #11
dkillianjr's Avatar
Hey guys I was wondering on that bosch saw I was looking on their website and they say the cutting capacity for wood is 2 1/2" . So if i gotta flush cut say a 6" wide jamb will it cut it? I've been using a hand saw but this looks like a pretty good deal and easier on the arm.
Ok I think I just answered my own question correct me if I'm wrong but 2 1/2" is the cut depth and it will cut whatever the length or the blade in it is right?
Thanks, Dave
dkillianjr is offline   Reply With Quote
Old 09-01-2006, 06:33 AM   #12
Master Craftsman
Big Dave's Avatar
Thanks, Dave
Bingo, you've got it.
Old 09-09-2006, 07:35 PM   #13
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
If you do flooring alot get a real jamb saw....that Bosch will not get into corners (trust me you will want one that does) and it will not do stone/brick hearths. Fwiw I have used just about every jamb saw contraption known to man and imo the best saw by far is the Crain 820. That little Roberts is seriously lacking in power but it does get into corners better than most and the blades are cheap. Also I believe Fein makes a tool similar to the Bosch that is alot more versatile iirc.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Old 09-09-2006, 10:41 PM   #14
Greg Di's Avatar
Trade: Remodeling & Decks
Yep, they sure do...The Fein Mulimaster. It will flush cut, plunge cut, scrape, sand, buff...you name it.
The blades are expensive, but it makes cuts not possible with anything else. I use it all the time and could not imagine life without it.
Greg Di is offline   Reply With Quote
How many screws does it take to secure a door jamb? Dustball Remodeling 28 02-21-2008 05:03 PM
Mortising doors Rich Turley Finish Carpentry 39 01-08-2008 01:51 PM
Scribe door or re-fit jamb Chris G Carpentry 19 08-14-2006 07:51 PM
Door Jamb transition Bukemdano Finish Carpentry 72 01-01-2006 10:49 AM
Door jamb weatherstrip kerf router?? trekr Tools & Equipment 7 12-17-2005 09:42 AM
