Impact Driver Stripping Screws
Old 05-28-2007, 04:14 PM   #1
bcf's Avatar
Trade: Fence Contractor
Hey everybody, lately I've been researching these to replace my cordless drill, and they seem very capable of everythng I need. I kep reading that they don't strip out phillips screws as bad as drills, but what about square heads? I use stainless steel square head screws, and with my drill if I'm carefull I'll strip only 1 in 10. I'm wondering if this will go down, up, or stay the same with an inpact driver. Thanks.
Matt Ehrenzeller-General Manager
A Great Divide Fence Company
www.agreatdividefence.com
bcf is offline
Old 05-28-2007, 04:26 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Re: Impact Driver Stripping Screws
They do not strip out as easily... But if your bit gets worn down a little bit they will strip them out. I am betting you will see about the same performance as with regular drills... The reason you are stripping so many is that SS is a lot softer and strips easy.
RobertCDF is offline
Old 05-28-2007, 04:30 PM   #3
The Grand Wazoo
KillerToiletSpider's Avatar
I don't strip out as many screws with one, but I quit using it because I got tired of the racket it makes and went back to using a drill.
KillerToiletSpider is online now
Old 05-28-2007, 06:52 PM   #4
GregS's Avatar
Trade: Low Voltage
Do some practicing first.. Make sure you hit the Robertson screws straight on. Any angle will cause a strip.
GregS is offline
Old 06-02-2007, 12:10 PM   #5
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Are you serious? The racket? My helper makes more racket than my impact drills. And for a longer time.
Either way I can live with the sound. It is WELL worth the trade off as opposed to using a regular drill!!!!
Speedy Petey is offline
Old 06-02-2007, 05:16 PM   #6
Teetorbilt's Avatar
I've been using the same Makita 1/2" drill for over a decade. I mostly build docks and service floats, 2 X construction and all SS screws and can't remember stripping a Robertson head.
I use Apex bits, change them when they don't fit tightly and pay attention as the screw starts to hit paydirt. I use 316 SS screws and think that using an impact could cause the heads to shatter.
Albert Einstein
Teetorbilt is offline
Old 06-02-2007, 07:51 PM   #7
Trade: Electrical
Impacts are less likely to strip or break off screws in my experience.
Old 06-03-2007, 05:23 PM   #8
bcf's Avatar
So I bought the Makita 4 in1, and that impact driver is great!! So much faster than a drill, and so far it seems to strip the screws less. Yes, the ratcheting can be annoying, but for only 2 seconds I think I can live with the increased productivity. And my hip likes the fact that is is so much lighter than my V28 drill.
bcf is offline
Old 06-03-2007, 06:43 PM   #9
Chris G's Avatar
Trade: Porch and Deck Builder
I wish I could adjust them to start impacting when I wanted. In awkward spots where I can't put much pressure on the screw, it would be nice to have it impact right away.
Chris G is offline
Old 06-03-2007, 07:44 PM   #10
Trade: Electrical
I like the fact that the impact only starts when needed.
Under light tension the bit screams until it senses resistance, then it ratchets.
Ryobi 18V impact driver review IHI Tools & Equipment 29 02-26-2009 11:51 PM
Impact Driver Nick H Tools & Equipment 24 02-21-2008 07:37 PM
oem milwaukee impact driver? TempestV Tools & Equipment 4 06-03-2007 05:26 PM
Rigid Impact Driver died wolffhomerepair Tools & Equipment 9 07-05-2006 03:47 PM
Impact tools question Mike Finley Tools & Equipment 11 04-25-2006 11:51 PM
