I Need A Bung Hole Cutter
Old 06-07-2008, 11:15 PM   #1
Tscarborough's Avatar
I simply have been unable to find one on the net, or through my vendors. It has a T handle and what looks like a serrated hole bit on the end. It is used to cut a 2 inch hole in a 5 gallon bucket lid so that tint can be added without removing the lid. Then you plug the bung with a little plastic cap.
I had and used one in the mid-eighties, but no one seems to know what the hell I am talking about.
Help!
Tscarborough is offline
Old 06-07-2008, 11:18 PM   #2
Teetorbilt's Avatar
Re: I Need A Bung Hole Cutter
How about a 2" Forsner bit?
Albert Einstein
Teetorbilt is offline
Old 06-07-2008, 11:28 PM   #3
Why not a hole saw?
If you are going all Amish on us,
chuck it in a tap handle.
neolitic is offline
Old 06-07-2008, 11:37 PM   #4
I could make the tool in a hour, but without the exact plug, it is pointless
Old 06-07-2008, 11:43 PM   #5
Teetorbilt's Avatar
Ts, maybe some precise dimension might help. Is it the same hole as a regular paint pail? I can get you that within 0.0005 tomorrow AM.
Albert Einstein
Old 06-07-2008, 11:51 PM   #6
It is a standard 5 gallon un-necked bung hole size, whatever that is.
Old 06-08-2008, 12:13 AM   #7
Teetorbilt's Avatar
I'll break out the verniers tomorrow, they're at the shop.
Albert Einstein
Old 06-08-2008, 08:36 AM   #8
PA woodbutcher's Avatar
I have a micro adjust bit for a brace. I don't use it very often, but it's the cat's meow for things like that
PA woodbutcher is online now
Old 06-08-2008, 08:50 AM   #9
mickeyco's Avatar
Trade: Squirrel Handler
You might try looking a supplies for wine and beer making, I saw something similar to what your talking about used for home made wine, they put holes in the top of 5 gallon buckets (could be he was using a painter tool, not sure).
mickeyco is offline
Old 06-09-2008, 02:49 AM   #10
Moderator
Double-A's Avatar
Try these folks. You'll have to find a distirbutor, but its a start.
New York Times, July 20, 2006
Double-A is offline
Old 06-09-2008, 02:52 AM   #11
Drew56's Avatar
Trade: framing
I cann't post urls try riekepackaging.com/prod/264
they have a manual crimper for flex spouts
Drew56 is offline
Old 06-10-2008, 09:42 AM   #12
That is it, Double A, thank you very much. Order on the way!
Need help! Hole for sink cut too big! sage Plumbing 32 02-05-2009 03:10 PM
punch a hole in concrete /w #2 POOLMANinCT Masonry 7 06-23-2007 12:50 AM
Back panel hole england030 Carpentry 2 05-18-2007 10:05 PM
three hole receps on a ungrounded system? Steve Unkie Electrical 2 12-09-2006 11:44 AM
Groundwater and mud in foundation hole ???? jdwilson44 Excavation & Site Work 5 03-27-2006 09:23 PM
