Smart phone? Scan me!
Trade: Painting/Framing/Drywall
I Am Seriously About To Go Postal. Sawzall Blade Keeps Coming Out!!!
I get the d@mn blade dislodged from whatever it is stuck in.. put the d@mn thing back in and about the time it gets in a hairy spot.. it gets stuck AGAIN (as in stays in wood, falls out of sawzall)!! I have a quick release for the blade, just a lever you pull back to change out the blade. Any of you guys have your blades repeatedly falling out? FECK! Now I am going to have to tear the stupid thing apart and figure out what is causing it to do this!!
Capra aegagrus
Re: I Am Seriously About To Go Postal. Sawzall Blade Keeps Coming Out!!!
Get a Milwaukee.
I take it you don't have this problem with Milwaukee huh? I don't/haven't owned any Milwaukee tools. If I can't get this figured out I will. I can't get a d@mn thing done with this. I might as well have a freaking handsaw doing the work
Trade: framing/remodeling
Let me guess. Cordless 18v dewalt right? What happens is a lot of sawdust gets trapped down in the blade catcher thingy and prevents it from fully engaging. Use a tiny screwdriver or a toothpick to clean out the gunk. Repeat as needed. My Makita corded model has a different mechanism and recently my blades started coming loose occasionally. On that model it wasn't sticking, it was getting disengaged by coming into contact with the work surface while I was using it. Still beats using the old allen wrench to tighten/change the blade.
Capra aegagrus
Not in the five years I've had it. Instead of a lever, the blade release is a rotating collar. The blade shank and engagement mechanism are pretty completely shielded from sawdust and debris. And at least the model I have has an orbital action that really gobbles its way through the material.
I've already walked the 50 yards to my truck to get it rather than use someone else's DeWalt, Makita or Hitachi that was sitting right there. |
#6 | |
Re: I Am Seriously About To Go Postal. Sawzall Blade Keeps Coming Out!!!Quote:
about my P-C's.
Hey Tin you should try my new Makita. Blade can be inserted into mechanism with one hand as it is spring loaded and locks in the open position as well. I have had a few Milwaukees also and they have a good mechanism too. Makita is also orbital but has a 15 amp motor and a soft start feature that can save your digits. Model number is JR3070CT. I have to say its been my all time favorite. As for the blades releasing, I chalk that up to user error.
LRG WoodCrafting
Got the older Milwaukee with the hex bolt set screw to hold the blade in. Had it for 15 years now. Blade never slips out or gets stuck in. Beautiful.
Capra aegagrus
Re: I Am Seriously About To Go Postal. Sawzall Blade Keeps Coming Out!!! |
Could be.
![]() At least it ain't the Green Disease.
#11 | |
Capra aegagrus
Ship it on over, I'll give it a spin.
![]() I think most of the manufacturers have improved their saws considerably over the last few years, but unless I'm mistaken Milwaukee was earlier out of the gate than most. Quote:
![]() There's no denying the reliability of the old hex screw, but with the newer chucks, I'll have the cut made while you're still changing blades. |
Trade: Control Systems
What model of saw is dropping the blades?
My dewalt I have to clear out with a jewler's screwdriver on a regular basis, my Hilti with the rotating collar does not. |
#13 | |
LRG WoodCrafting
No silly, I use a circular saw and a whittling knife for those.
I like Green things
The Grand Wazoo
Hilti, the blade chuck won't close all the way if you didn't put the blade in correctly. Of course there are a bunch of people that go out of their way to bash Hilti products because they can't or won't afford them, but the proof is in the performance.
Trade: Framing
I just through a Hilti in the trash. I cut my thumb 2x's with it.
Don't tell me operator error, I'm a framer and I think I could cut them cabinet doors, after all the erperience useing them. Have had Makita, Milwaulkee, PC and now a dewault. They all work if you push them hard enough!!!!!!!!!!!!!!!!!!!! |
#17 | |
#18 |
Project Manager/Carpenter
Trade: Carpentry/Reno
LOVE my bosch. NEVER has it lost a blade...it will stall out the saw or rip out of my hands before it will let loose a blade...and the "chuck" stays in the open position when you pull the blade out and snaps closed when you push a new one in....
#19 |
Trade: carpenter
i'll bet a coffee it's a ridgid or ryobi
My personal choice is the 13v milwaukee. with rotating handle and orbital. |
#20 |
I used to think so.......
I own and use both the Makita AVT and the Milwaukee Super Sawzall. My Milwaukee up and quit one day, so I bought the Makita as a replacement until I could fix my "Lil Red Express"
The AVT worked really well, until I shattered the piston/shaft. It has never been the same since the guys at P** Tools "rebuilt it" under warranty. It's a close second to the red M. Then there is that PC TigerClaw super twisting / rotating machine...that would have some cool applications. Turns out that my twist-lock power cord was the problem with the Milwaukee. (Found that out after a near total disassembling and direct power check by yours truly) Kinda felt like a dumb azz. The Milwaukee is great but it too loses the odd blade into wood. Typically if I buy the Lennox or Bosch blades they are thinner than Milwaukee blades and they have more "play" in the blade slot of the connector head assembly. If I stick with the fire rescue type of thick blades from Milwaukee - never a problem. |
| Free Lenox Sawzall Blade vrs T2 | SLSTech | Tools & Equipment | 1 | 03-24-2009 10:07 PM |
| Free Lenox Sawzall Blade | wolffhomerepair | Tools & Equipment | 34 | 01-18-2009 11:56 PM |
| Remodeling Show New Blade | Rockwood | Masonry | 1 | 12-01-2008 10:01 AM |
| Best blade to cut Jatoba | Laketahoedan | Finish Carpentry | 2 | 10-15-2008 08:40 PM |
| Best Utility Knife | Journeyman T | Tools & Equipment | 48 | 02-20-2008 08:54 PM |
