Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 01-05-2009, 01:05 AM   #1
Trade: Custom Metal Fabrication/Residential Construction
Hitachi Roofing Nailer Help
I have the hitachi NV45AB2 coil roofing nailer. Used it new for the first time a few months back on a roofing job and its great...good balance, never jams, etc etc. The only thing I found wrong or just maybe not right was the amount of force needed to activate the sequential fire. It just seemed like I had to really pound the gun into the shingle. Now I have only done one roof with it and figured it would probably loosen up over more use. I noticed today at the store that the dewalt, senco, bostich models need a lighter amount of force to bump fire the nose. So am I missing something? Does the gun just need to be worked in more or is there some type of adjustment to reduce the pressure or a trick in removing the spring all together. I just figured you need to just tap nose on the shingle and it would fire...never expected to get shoulder pain like driving nails with a hammer all day.
Thanks
Kastoria is offline   Reply With Quote
Old 01-05-2009, 08:38 AM   #2
Al Smith
A W Smith's Avatar
There's a knurled wheel on the right side of the gun near the contact element for depth of drive adjustment
[edt] my mistake im thinking of one of my other guns, there is a tooless depth of drive adjustment though. my guns an older model
Al Smith
http://www.awsmith.com
A W Smith is offline   Reply With Quote
Old 01-05-2009, 08:13 PM   #3
Yup i know the one youre talking about. Adjusted it several times to set the depth of the nail...but thats about all it did. The force needed to drive the nose back so it fires is what Im looking to loosen up. Thanks
Old 01-05-2009, 08:18 PM   #4
Al Smith
A W Smith's Avatar
you do put a few drops of gun oil in the air inlet and lube the moving parts on the contact element including the drive pin?
Al Smith
Old 01-05-2009, 09:12 PM   #5
yup sure do...it operates great...but compared to other brands, I just thought it wasnt that hard to press the nose down. But whatever, it works great. Maybe it just needs to be worked more. Unless there is a trick that Im missing.
Hitachi NT65MA2 finish nailer sore thumb Tools & Equipment 21 11-30-2009 12:58 AM
which hitachi roofing gun to buy??? mikeybobo Roofing 3 01-10-2009 10:47 AM
can you use bostitch roofing nails in a hitachi? mikeybobo Roofing 2 12-31-2008 08:40 AM
do bostitch roofing nails fit a hitachi? mikeybobo Tools & Equipment 0 12-30-2008 09:46 PM
Hitachi VH650 Coil Framing Nailer GitSum Tools & Equipment 0 11-06-2008 03:01 PM
