Hitachi Air Compressor
Old 06-11-2007, 08:39 AM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Hi, I have a Hitachi gas driven air compressor that the drive motor runs good, the belt is driving the compressor, and it trys to compres air but will not. I took the head off (Single lung) and placed my hand over the holes and it does try to push my hand off and suck it in so I know there is plenty of compression coming out from the compressor cylinder, but when I try putting the head back on the air goes in and out of the intake. I think maby the reeds and or head gasket may be going bad, but I have another job coming up in a few days were i will need to use it and i just wanted some opinions on what the problem may be if anyone knows. I would buy and replace the reeds and head gasket, but if anyone knows of any other problems that may be causing this i would like to get all the parts at one time. Basically in a nutshell if i remove the line and stick my thumb over the pipe leading away from the compressor to the tank the air just goes in and out the intake.
Thanks
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 06-11-2007, 03:25 PM   #2
Professional Remodeler
firemike's Avatar
Re: Hitachi Air Compressor
Definetly sounds like a valve problem. Can you call Hitachi and get a rebuild kit, or maybe the name of a local stocking parts distributor so you can pick one up?
Possibly an internet supplier tha can quick-ship parts.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 06-11-2007, 08:30 PM   #3
Plumber / Carpenter
Bill's Avatar
I am going to try, i just got in from out of town yesterday and had some work to do today, will call tomorrow. Thanks for the 2nd opinion, thats what i was thinking too
Bill is offline
Hitachi NR90GR & Paslode Fuel Cells? AlbertZeroK Tools & Equipment 11 11-19-2007 05:15 PM
Moving Compressor Around, Jack Options plazaman General Discussion 3 02-01-2007 11:00 PM
Air Compressor and Power Inverter Question plazaman Tools & Equipment 0 12-18-2006 11:06 PM
Compressor talk - Mike Finley Tools & Equipment 39 11-01-2006 06:29 PM
problem with Hitachi Air compressor Redman Tools & Equipment 11 04-04-2006 08:12 PM
