HighTech Air Hose
Old 03-15-2007, 09:36 PM   #1
McCall Builders's Avatar
Trade: Residential Building & Remodeling
HighTech Air Hose
I saw this in a recent Fine Homebuilding magazine and was wondering if anyone has seen or has used this brand of air hose. Looks to be easier to build custom length hoses.
hightechairconnection.com
McCall Builders is offline
Old 03-15-2007, 09:52 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Re: HighTech Air Hose
Only comes in 3/8"... I use 1/4" flexeels only. If you need custom lenghts just buy a 100' and cut up as needed. That is what I did. I know you can buy the 1/4" in 250' rolls as well. But I think anything over 100' would become unruly.
RobertCDF is online now
Old 03-16-2007, 08:52 PM   #3
travish's Avatar
Trade: Framing
Haven't used in construction but had similar in other fields. You need to cut the end square to get a seal but thats not a big deal.
The stuff I've used before deforms a little everytime you connect it, not a problem for those applications but if you unhook your tool everyday it could add up. Simple to just trim back the hose but its something to be aware of.
My biggest problem is the checkvalve; the one on the site looks like it would go at the compressor. So when you unhook a tool (say switch from a nailer to stapler) the pressure in the hose gets dumped
travish is offline
Old 03-17-2007, 12:40 AM   #4
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
I also have the flexeel hose. I have a 50' and 100'. They are so light it is like having a a cordless. You can get them on ebay for have the cost of the hardware stores.
Norrrrrrrrrrrrm is offline
Old 03-17-2007, 08:56 AM   #5
pro picnic table builder
vwovw's Avatar
Trade: gc
yep...but i don't cut up new ones. sure as shiit a couple days after i buy a new flexeel hose somebody cuts threw it or something. Then i cut them down to different sizes. I had a sub who tossed a cigarette off the roof(after i told him no smoking near any wood ..i.e. house). It hit my hose two floors down and burnt a hole in it.
vwovw is offline
Old 03-17-2007, 10:32 AM   #6
Same Old's Avatar
Trade: Residential General
ummm how would your gun get air??? Try thinking before posting, it helps us cut down on the clutter.
Same Old is offline
Old 03-20-2007, 01:10 AM   #7
travish's Avatar
Trade: Framing
I don't even know where to start. Take some of your own advice.
Seeings how you want to cut down clutter I'll spell it out now instead of bantering back and forth. I'm not sure what part of my post needed more thinking so I'll go through everything you quote:
Checkvalve - you need this to keep from emptying your compressor every time you unhook a tool. In a regular air q/d its contained in the female section. In a typical setup you have one right at the compressor, where the male end of your hose goes in. Once that piece is in the valve is held open and pressurizes your line up to the next female q/d. Connect your tool and then its pressurized. I don't know how to make this simpler
checkvalve at the compressor - the only place a checkvalve will keep a hose from dumping when you change tools is at the tool side. From the site it looks like their checkvalve goes at the compressor. So best possible situation is that if you unhook your tool its a magic checkvalve that only dumps the line, or else its a standard mechanical one that will leak the compressor. Way around this? Run down to the compressor, unhook the hose there (only dumping the hose - can't get around that), swap tools and reconnect to compressor
unhooking a tool - you've never had to switch tools? Its a common jobplace occurance
If you think I'm talking down to you its because I am. Just responding in kind
One more thing - you are not your post count
Edit: If anyone has any experience with this hose I'd love to hear it. I'm always up for new tools but I can't see this being useful to me
travish is offline
Old 03-20-2007, 08:57 AM   #8
Same Old's Avatar
Sorry I misread your post a little. I thought you were suggesting it had one of these magic checkvalves, perhaps I should take my own advice.
Same Old is offline
Old 03-20-2007, 08:36 PM   #9
RobertCDF's Avatar
Only melted through 1 so far in 3 years. And I did it with a hot sawzall blade.
Old 03-23-2007, 04:05 PM   #10
Dan
ApgarNJ's Avatar
Send a message via AIM to ApgarNJ
flexeels rule. 3/8's only for me, although the 1/4 is nice for finish nailing
ApgarNJ is offline
Old 03-23-2007, 09:50 PM   #11
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
I use a flexeel also. Nice and light. I've noticed they're starting to sell them at Home Cheepo now. I think a 100' is about $50.
In_Mexifornia is offline
1/8" id Airless Hose Al Truistic Painting & Finish Work 6 08-12-2010 04:18 PM
hose reels mattp General Discussion 3 06-25-2007 06:38 PM
Fittings for Air compressor hose plazaman Plumbing 9 02-18-2007 08:56 PM
Pump Hose Clamp Damage dragon Construction 4 04-12-2006 12:17 PM
Faulty Hydraulic Hose jmic Excavation & Site Work 5 04-03-2006 02:00 PM
