Trade: remoddling
Help Rebuild Bostitch Naile Gun
i bought the o-ring kit. the gun was removed from the job after it would auto shoot when plugged in and it seemed there was something sliding around i the gun holding it pointing up or pointing down before plugged in to air. soetimes when plugged in to air it would just leak out then replugged in sometimes it would seat" and hold pressure to allow use. i took it apart.. cleaned it . reinstalled it all teh o rings looked fine no scrathes or nothing but loads of oil and grime in teh inside of gun. it is still shooting a nail when plugged in . maybe i shoudl rebuild the trigger valve . this is my firs nail gun rebuild so any help is appreciated.
Trade: Construction
Re: Help Rebuild Bostitch Naile Gun
See if you can find a rebuild guide on line for your model. Should be an easy fix. But def dont be using it if it's randomly letting nails fire. Sounds like the trigger valve may be faulty or needs cleaning out. Try spraying some brake and clucth cleaner down inside the air inlet then give the the tool a few blank shots. If it works fine then re oil the tool with air tool oil and see how it runs.
#3 | |
Re: Help Rebuild Bostitch Naile GunQuote:
I think I would be wary of using cleaners inside of the air nozzle. Some of those cleaners will melt the rubber o-rings inside rendering it completely useless. I know some are fine, but not all are created equal.
Trade: Construction
Brake and clutch cleaner should be fine as it's brake seal and clucth seal freindly. But read on the rear of the can before you use it to see if it says it reacts with plastic or rubber.
Home Depot aisle walker
Trade: home remodeling
Saw this thread and dropped in to make a point. Anyone inclined to work on or offer advice on nailgun repair that is not an ASE certified mechanic could be called a hack. And nailguns are dangerous right?
I was an ASE certified GM mechanic (over 20 years ago), I saw my fair share of shade tree hackery. Stuff butchered and yes even sometimes dangerous. My point is the next time those of you who are inclined to attack someone for being a hack think about it for a second first. Hey I've done it here myself. Its getting pretty freakin vicious though. Some of you guys feel entitled to big money, now its you invading the handymans territory, not always the other way around. Times are tough, there isnt enough work for everybody. Chill out a little |
Trade: remoddling
ok i pushed out the rolled pins. pulled teh valve out it looks pretty clean and ok.. cleaned it off blew through it and put back together . still shoots off a round when hooked to air.. i dunno maybe i will do the o rings and then put it back together see if that helps maybe they are damaged and causing this.
Trade: siding
it could be the trigger valve body itself i always replace the whole assembly on those
Tom |
#9 | |
Just bought a Bostich coil siding siding nailer, and not impressed with all the plastic parts. Saves weight but at a cost. Wish I bought a Hitachi , it has a better build, the older light green ones I mean. My NR90AC3 is excellent for example. I would buy a new valve. Hate all those cheap plastic parts, the pic looks like a plastic assembly. Hold any gun away from you when you click on the hose, you never know. |
| bostitch flooring stapler | mhillc | Flooring | 3 | 08-07-2009 12:23 PM |
| After Rebuild Graco 395 not holding pressure? | KJLinden2002 | Painting & Finish Work | 4 | 03-12-2009 10:03 PM |
| can you use bostitch roofing nails in a hitachi? | mikeybobo | Roofing | 2 | 12-31-2008 08:40 AM |
| do bostitch roofing nails fit a hitachi? | mikeybobo | Tools & Equipment | 0 | 12-30-2008 09:46 PM |
| Do they have a rebuild kit? | Leo G | Plumbing | 17 | 08-26-2008 08:12 AM |
