Help:In The Market For Wall-jacks
Old 02-03-2009, 10:01 PM   #1
gbruzze1's Avatar
Rewards Points: 2,608
Hey all,
I'm looking to buy some wall-jack and bracing systems, like the kind qual-craft make, but not sure which is best. Not gonna be lifting any huge walls, so I dont wanna spend a ton of money.
Just need some advice on what to buy to get me started so i can frame up some walls for an upcoming addition. Would love to hear what you guys use, like/dislike, etc.
Thanks alot
gbruzze1 is offline
Old 02-03-2009, 10:36 PM   #2
Carpenter/Finisher
john5mt's Avatar
Rewards Points: 1,404
Re: Help:In The Market For Wall-jacks
Cheapest way is to make them out of square tubing and weld a nut into the ends. Then take some 5/8's all thread and weld the nailing feet to the ends and thread them on through.
1st Gen tradesman
My summer job in college became my profession
Last edited by john5mt; 02-05-2009 at 11:08 PM. Reason: I described wall braces not jacks...too late to be typing
john5mt is offline
Old 02-04-2009, 11:27 PM   #3
Professional
Jlubb's Avatar
Trade: Exterior renovation
Rewards Points: 14
I have a set from qualcraft for sale. We dont use them anymore, we do mostly siding now. Let me know if your interested.
Jlubb is offline
Old 02-05-2009, 12:04 AM   #4
BirmanBuilders's Avatar
Trade: Framing
Rewards Points: 150
I always make my own on the job. They work great for lifting long walls, though not ideal on two story walls. Take four pieces of 2x4 2' 4' 6' full stud. Cut a 45 bevel on each and nail together progressively. When you have your wall sheeted and ready to stand nail about 4" away from the top plate into the deck and nail a block behind. If you have one on either end of the wall, when you lift, the smaller blocks slide in under the top plate and make a temp support. Lifet the other end and repeat. The last push after the 6' block is easy. Quick and cheap and saved me some back ache over the years.
If at first you don't succeed hit it harder!
BirmanBuilders is offline
Old 02-05-2009, 07:30 AM   #5
gbruzze1's Avatar
Jlubb,
Might be interested. Can you e-mail me what you have? is it just 2 wall-jacks, or supports also?? also what your asking for them.
E-mail is gary.bruzzese@gmail.com
Thanks to everyone for their reply,
Gary
gbruzze1 is offline
Old 02-05-2009, 12:27 PM   #6
jmic's Avatar
Rewards Points: 2,000
Originally Posted by gbruzze1 View Post
Hey all,
Thanks alot
Don't know where you're from but I have a pair of Proctor Wall Jacks (24') that I'll sell real reasonable.
Joe
jmic is offline
Old 02-05-2009, 01:11 PM   #7
gbruzze1's Avatar
Im not too far from you, Westchester, NY...how much are you asking??
e-mail: gary.bruzzese@gmail.com
gbruzze1 is offline
Old 02-05-2009, 01:42 PM   #8
jmic's Avatar
500.00...................they go well over 1200.00 if my memory is correct.
Joe
jmic is offline
Old 02-05-2009, 01:43 PM   #9
JonM's Avatar
Rewards Points: 1,216
Lifting walls??...isn' that want electricians, plumbers,laborers and the coffee truck guy are for?...
JonM is online now
Old 02-05-2009, 04:26 PM   #10
gbruzze1's Avatar
jmic, thats 500 for 2 wall jacks??
gbruzze1 is offline
Old 02-06-2009, 10:38 AM   #11
jmic's Avatar
Correct.
Joe
jmic is offline
Old 02-06-2009, 11:59 AM   #12
Kgmz's Avatar
Wish I wasn't on the other side of the US from you.
$500 is a good price for a pair, and they do sell new for about $1200.
The nice thing about the Proctors is that they have a stop so that the wall doesn't fall over the other way after it is upright. The Qualcraft wall jacks or similar that use a 2x4 you have to make sure someone is there to hold it doesn't fall over once the wall is up. With the Proctors or similar you could lift a wall by yourself.
The Qualcraft wall jacks run about $150 each plus the cost of a couple of 2x4's. This is about as cheap as you can get.
Kgmz is offline
Old 02-06-2009, 01:09 PM   #13
jmic's Avatar
I've used them when alone many times when I had to. Great tool to have in your arsenal of tools if you're into framing.
Joe
jmic is offline
Old 08-26-2009, 07:53 PM   #14
sec518's Avatar
Trade: Production Framer
Do you still have these? If so I will buy them cash and pick them up ASAP. I live about 2 1/2 hours from danbury so I'm not far. Call 518-858-8975 if interested
sec518 is offline
Old 08-26-2009, 08:13 PM   #15
Kgmz's Avatar
Since this came up again had to post a pic of my second in command using our Qualcraft wall jacks, my Wife.
Kgmz is offline
Old 08-26-2009, 10:22 PM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,630
If she's second in command who's first? Got another wife?
Inner10 is offline
Old 08-26-2009, 11:00 PM   #17
Kgmz's Avatar
I wish I had another one like that.
Kgmz is offline
Old 08-27-2009, 12:04 AM   #18
Inner10's Avatar
Move to Salt Lake City and let your dreams come true.
Inner10 is offline
Old 08-27-2009, 12:51 AM   #19
curiouscanuck's Avatar
Trade: carpentry
Rewards Points: 25
The pair I use are similar to the Qual-Craft, can't remember the brand. When using alone I recently secured a line from the top plate (used an eye bolt) to an anchor down on the deck to keep the wall from going over when vertical. This was just temporary while I set up bracing.
Matt
curiouscanuck is offline
Old 08-27-2009, 10:38 AM   #20
Meetre's Avatar
Matt
ditto, tow strap one end to the top plate and the other to the floor, if you do the math right it will be very close to plumb when you get it jacked all the way up.
Meetre is offline
Real estate or stock market? bob_cntrctr General Discussion 23 04-06-2014 07:04 AM
Sales Person- How to hire in Today's Market modterry Marketing & Sales 5 01-21-2009 09:04 AM
Stimulating the residential housing market CarterConstruct Business 1 01-13-2009 05:54 PM
How is the housing market in Mesquite, NV? kdub1777 General Discussion 6 08-27-2008 04:43 PM
Could the cooling house market actually be a good thing for us? SeanATL Painting & Finish Work 5 05-04-2007 01:08 AM
