Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 09-25-2009, 10:47 AM   #1
Newbie
Kevin75's Avatar
Trade: Home Renovations
Help - Air Compressor Accessories
I have a DeWALT D55146 4.5 gallon, 200 PSI Air Compressor. I've had nothing but problems with it that's another story. Has anyone else had a similar experience?
Anyway, I'm getting prodigious amounts of water coming out with the air. We drain it completely following each use, so it's not an issue of accumulation over time.
I'd like to buy an air-dryer accessory for the outgoing air, but most of the ones I've seen won't fit this design. The two issues are configuration and pressure (200+ psi).
Has anyone found a filter that will work?
Thanks!
Proverbs 18:9 "One who is slack in his work is brother to one who destroys."
Kevin75 is offline   Reply With Quote
Old 09-25-2009, 11:24 AM   #2
The Old Master
Trade: Plumbing & Heating
[quote=Kevin75;774449]
Question that compressor has per Dewalt, 200 psi tank pressure.
but regulated pressure is what 140 ..
W.W. GRAINER Sells condendsate separators for 150 psi units.
Could not you make a little stand to hold the separator and feed it with a short hose. Inconvience would be better than getting water in the tools.
You mentioned dryer ... I assume you mean separator ... A dryer would cost you thousands and be bigger that your compressor.
Bill Parr L.M.P. www.parrsplumbing.com
for a job that's up to "PAR"
Plumber_Bill is offline   Reply With Quote
Old 09-25-2009, 12:13 PM   #3
Cole82's Avatar
Trade: Construction, siding, windows & doors
Send a message via AIM to Cole82
These work well and are small. Put that at the working end of the hose or on the tool.
http://www.northerntool.com/webapp/w...9833_200319833
Cole82 is offline   Reply With Quote
Old 09-25-2009, 09:00 PM   #4
improving homes
Trade: Roofing/Remodeling
I bought a seperator from harbor freight. I have the same compressor and it has worked pretty good for me in the last 2 years. The hose connectors are getting kinda hard to push a hose in. And recently it started sounding a little rough, not sure why. I do notice that it gets a fair amount of moisture in the tank, think it has to do with compressing the air to 200psi creates more heat which leads to moisture.
What problems are you having with your compressor?
platinumLLC is offline   Reply With Quote
Old 09-25-2009, 09:28 PM   #5
curapa's Avatar
Trade: carpentry / fencing / decks
I do not have a suggestion for you but I am curious as to what you are running at 200psi?
www.ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 09-28-2009, 12:15 PM   #6
DrewD's Avatar
Trade: Log Home Construction
I have the same compressor, no problems but just the other day the gauge displaying regulated pressure quit. I can still regulate the outgoing pressure, just no display. Curapa questions, outgoing pressure isn't 200 psi, just tank pressure. Its 4.5 gallons pressured at 200 psi, takes up less space than 120 psi. A note, check out Max's 400 psi compressor. Back to the original post, I too have alot of water drain out of my tank, the only thing I can think that would cause this is the higher tank pressure. If you install the water separator after the regulator you only have to find one rated for you regulated pressure.
DrewD is offline   Reply With Quote
Old 10-03-2009, 09:35 AM   #7
Newbie
Kevin75's Avatar
I had to replace the regulator, power switch, and now the pressure gauge. These all happened a few months apart, and it all started after the warranty expired. It's more nuisance than expense.
Old 10-03-2009, 05:27 PM   #8
I don't know too much about it, and have only had Porter-Cable compressors (with no problems), - - but it sounds like it's running too hot, creating all that extra moisture. Are you running it on a 25-foot cord or less, and is the cord 12-guage??
Also, run it on a 20-amp circuit, even if it only calls for a 15.
Right or wrong, that's all I got . . .
Tom R is offline   Reply With Quote
Old 10-03-2009, 05:29 PM   #9
mrmike's Avatar
Trade: Electrical & Carpentry
mrmike is offline   Reply With Quote
Old 11-14-2009, 05:18 PM   #10
2ndGen's Avatar
Trade: Thoroughbred Roofer
Thanks!
I bought mine spankin' brand new.
Crapped out on 2nd or 3rd job.
Took it in for service.
TWICE!
The 2nd time they charged me for a new motor!
Used it halfway through 5th job...CRAPPED OUT AGAIN!
I could accept a particular model being a bad model.
What I can't accept is DeWalt's Customer Service.
I had to jump through so many hoops and they just refused to honor their warranty (which is the reason I payed premium for this compressor...I expected them to be there to take care of it and to give me a "loaner" compressor which at the time is what they promised!).
So much downtime, so much lost money...I am going to donate my compressor to the local college to burn at the next football games victory (they usually burn couches).
BY THE WAY...
I used to be the biggest DeWalt fan.
Now, they will never get another penny from me.
"I've been up on the roof. I know what those guys go through.
My whole life has been about making that profession respectable
Ken Hendricks
2ndGen is offline   Reply With Quote
Old 11-15-2009, 02:04 PM   #11
Trade: Fire Suppression Equipment Sales & Service
I have 4 of the DeWalt compressors. Each has been in for warrenty, before and after the warrenty period. Each has been fixed under warrenty, except for one that needed a new regulator. That compressor was about 2 years out of warrenty. It was fixed for a resonable cost. They even put a wheel/tire on once because the tire was flat. Then they apologized about the used tire. It was fixed, that was important to me.
The only problem, they do not understand why I do not immediatly drive the 300 miles to the warrenty station to get my compressor. they call at least 3 or 4 times before they understand that Oregon consists of more than just Portland.
fireguy is offline   Reply With Quote
Old 11-15-2009, 02:39 PM   #12
2ndGen's Avatar
That's a good issue to have...I had to CALL THEM over and over to get any answers.
I love warranties, but I hate them having to be necessary.
I only have 1 compressor at a time.
When it's down, "I'm" down.
One I get my new Rol Air, I'm also going to have a back-up compressor
(probably a pancake, just to get me through a job).
Ken Hendricks
Old 11-15-2009, 07:29 PM   #13
Trade: drywall
I have the d55168 compressor same 200psi but has the 15 gallon tank, it has been the loudest compressor I've ever owned, sounded like the something was loose inside the thing, I figured it was just the way it was but after about 1 year to a year and a half and about 30 hrs of work time on it, I found why it was so loud, the piston is a two piece design and the bolt that holds it together must have been loose, the bolt snaped off. Only had about 15 mins of work left to do for that job and didn't have another compressor with us so we had to go back to that job the next day to finish . Twenty couple dollars in parts and an hr to put back together and it is like new again but alllllooooooottttttt quitter!
I don't have any problems with it getting excessive amounts of water in it.
drywallnflorida is offline   Reply With Quote
Old 11-15-2009, 07:41 PM   #14
2ndGen's Avatar
Mine was initially quiet...almost too quiet.
I called DeWalt and they said it was supposed to be quiet.
Then it died.
Took it in, they fixed it, it came back louder.
I thought okay, they "fixed" it, so it's supposed to be perfect now.
Crapped out again!
Took it back and it came back even LOUDER!
Crapped out after 1 1/2 jobs AGAIN!
DeWalt!
Ken Hendricks
Old 11-15-2009, 09:48 PM   #15
Trade: drywall
I didn't even take it back to them, I figure if there too stupid to put it together right the first time that they would deff. fail at fixing it!!!
Old 11-15-2009, 10:24 PM   #16
Teetorbilt's Avatar
Back to Q#5. Why do you need 200 PSI? Most tools only need 100 or less. It takes a lot of energy to get to 200.
As for the water, you can go to a coalescing filter. I use this product http://www.smcpneumatics.com/?gclid=...FRQhnAodYVYdrA If you need REALLY dry air you can go to a membrane type dryer.
Pneumatics 'R' Us.
Albert Einstein
Teetorbilt is offline   Reply With Quote
