Project Manager/Carpenter
Trade: Carpentry/Reno
Harbor Freight T50 Stapler |
#2 | |
Al Smith
Re: Harbor Freight T50 StaplerQuote:
I just thought it was interesting... I use T50 staples as miter clamps on casing
#4 | |
Al Smith
http://www.buy.com/retail/product.as...42&dcaid=17902 |
yeah...I case my pre-hungs first, glue and pin the corners, then I put a staple on the back side of the moulding spanning the joint, and two on the front. They don't alow the joint to open up. I take the staples out after the glue dries.
Trade: carpenter
what do you mean? before the jams are in? I don't understand
#7 | ||
Palisade Point Const.
there is more air models on amazon that shoot t-50's but i would just go electric. i have an electric arrow for about 10 years with no probs.
BSA Renovations - Restoration and Renovation Specialists serving New Jersey's Bergen County. Bergen County's Premier Home Maintenance Provider. |
Rock it...
Use them for roofing. Its insane how fast you can lay felt with those. They shoot like 500 staples a minute, you just run along the top and zigzag the center.
Trade: Custom Homes Builder and remodeler
I have never seen anything that came from Harbor Freight that lasted very long, or performed as well as the one it was knocked off from. (Porter Cable in this case?)There is a reason it's only $25.00.
Re: Harbor Freight T50 StaplerYup, I case the hinge side of the jamb, Glue, pin and then put T-50 staples across the miter front and back. Then I just slam the whole thing in as a unit....done... |
#12 | |
I'm a Mac
Trade: ICF Construction
So, no shims behind the hinges??? That's a lot of pressure using trim to hold a door in place.
Chris |
Trade: carpenter
I always use a 3" screw in the top hinge, that probably helps, you could slide shims from the back too, no?
Its really not, Hollow core doors are so light, and the the trim holds the door pretty damn well. The first one I did I hung on the door itself and it was strong. Try it sometime...
Trade: finish contractor
Hey there is a company on ebay that sells a t50 pneumatic stapler that i got 6 months ago and its a great gun and it even comes with a box of staples and a case for $45.00 so far it works great i use it every day for insulation. The ebay name is securefastening now all i need is to collect a commission.lol anthony ps his prices are half on the staples too.
| Tebo deck stapler | Paragon Builder | Tools & Equipment | 16 | 08-24-2011 02:38 PM |
| Would a stapler help! | Paddyman | Tools & Equipment | 14 | 04-11-2009 09:51 AM |
| Bostitch M3 Flooring stapler | Enlightened | Contractor Swap | 2 | 02-28-2008 04:29 PM |
| Wood Flooring Cleat nailer vs. Stapler | datrder | Flooring | 7 | 01-02-2008 05:04 PM |
| 2.5" or 3" air stapler | mas | Tools & Equipment | 5 | 07-31-2006 03:29 PM |
