Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 05-29-2009, 05:36 PM   #1
Trade: Handyman Services and Home Improvements
Generic Paslode Battery
So I picked up a few of these for $18 each a few months ago.
Batteries
EXTENDED Battery for Paslode Impulse 404717 6V 2600MAH
New battery replacements for Paslode 404717
This battery stick is new factory sealed,and fresh off the press not surplus or expired. It comes with a 1 year warranty. 2600 Mah 6V NiMh. No memory effect, longest runtime
WORKS WITH PASLODE 900420 Cordless Framing Nailer 900600 Cordless Angled Nailer 902000 Cordless Straight Finish Nailer 901000 Cordless Brad Nailer
I've used often since then. I keep getting misfires w/ this when using my finish nailer, but it works great in the framer. Do you guys think this could be from the higher capacity battery or just from the generic version?
If it turns out to be caused by the higher capasity, they also have standard replacements for a few dollars less and I wouldn't mind picking up a pair.
Favorite Jobsite Quote: "I cut it twice and it's still too short!"
HandyHails is offline   Reply With Quote
Old 05-29-2009, 06:03 PM   #2
Handle It!
MALCO.New.York's Avatar
Check the output voltage!!!
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is offline   Reply With Quote
Old 05-29-2009, 06:20 PM   #3
Am I missing something? The voltage is the same as a factory battery at 6.
Old 05-29-2009, 06:56 PM   #4
Faking my Way
TBFGhost's Avatar
Trade: Architectural Trim and Punchlist Work
Check the true output voltage with a meter...
TBFGhost is offline   Reply With Quote
Old 05-29-2009, 07:24 PM   #5
Handle It!
And I have a 12" Johnson! Just like the Factory Original.
Just do not measure!! I may come up short!!!!
Old 05-29-2009, 07:27 PM   #6
Handle It!
Not that this is the same..........
But store bought Rechargeable Batteries for Electronics, AA, AAA, C, D are all 1.2 VDC. Where as Alkaline Non-Rechargeables are 1.5 VDC.
IS there a difference??? Not in many cases, but in devices like CD players and Camera Flashes, HELL YES!
The Flash takes Longer to Recharge and the CD player sounds less clear!
Output Voltage will hamper performance of MANY devices, but maybe not as apparently as one might think!
Paslode Cordless Will Not Fire lakeman Tools & Equipment 12 04-19-2009 09:58 PM
Paslode f350 major air leak HRUBY Tools & Equipment 4 03-01-2009 06:53 PM
Paslode 16 gauge Straight Finish Nailer For Sale JPV123 Contractor Swap 0 02-22-2009 06:56 PM
Paslode Cordless Framing Owners...a fix for misfires... TBFGhost Tools & Equipment 10 11-09-2008 01:35 PM
makita Lithium-Ion battery problems RodsRenos Tools & Equipment 5 10-10-2008 04:33 PM
