Frustrated With Drill Bits
Old 02-12-2006, 10:06 AM   #1
Suck it up, or shut up
rservices's Avatar
I drill in a lot of stainless, and cinder block, can any one recomend a brand of bit that holds up.
I've tried most brands, milwakee, dewalt, and even fastenals. some are better than others but what your feed back
thanks john
rservices is offline
Old 02-12-2006, 10:18 AM   #2
Aceinstaller's Avatar
Trade: sub-contractor
Re: Frustrated With Drill Bits
I keep seeing some kind of sharpener on TV lately. bout ready to give them a call and bust out the 5 gallon bucket of spent bits that I've been collecting.
If it works half as good as they say it does, I'm sittin on a gold mine!
Aceinstaller is offline
Old 02-12-2006, 10:22 AM   #3
mdshunk's Avatar
For drilling in steel and stainless, I prefer any titanium nitride coated bit. You can distinguish these by their gold outer appearance, and possibly the "TiN" markings on the bit. Key to drilling stainless is to controll the drilling speed. Get a little trigger happy, and you'll burn the bit blue on the first hole or two. A drop of Tap Magic or similar tapping fluid or gel goes a long way towards extending bit life.
For drilling masonry, I've never had any particular issues with any bits. Key again, matching drill motor RPM's to bit diameter, just like when running a milling machine or lathe, to extend tooling life. I mostly use Milwaukee and Fastenal masonry bits, and get good service from both. Some guys swear by Bosch's line of Blue Granite masonry bits, but I have yet to try one. My rotary hammer is spline drive, and the only Bosch bits sold local to me are SDS.
mdshunk is offline
Old 02-12-2006, 10:30 AM   #4
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Have you tried cobalt bits for drilling ss and other metals. Thats all I use for that. I just tryed out the RIDGID brand drill bits and they worked great. I also used to get them when we worked on trailers from a local supply store that just sold them in brown bags. Never knew what brand it was but those ones where the best I've ever used. Those Bosch bits are the best I've found also for masonary.
Eric K is offline
Old 02-12-2006, 01:57 PM   #5
rservices's Avatar
I bought a drill doctor, but either I did it wrong or it's just the wrong cut for metal bits, I'm sure they will work fine in wood, but on metal they just spin
Old 02-12-2006, 04:20 PM   #6
carpenter and builder
Nick H's Avatar
Trade: carpenter and builder
If yout drilling into metals you must keep the speed down and keep the bit cool, its the heat which kills the bit. I had to drill a load of bolt holes in steel angle and turned up with a whole load of bits thinking i'd need them all, well an "older" guy with very greasy hands "talked" me through it, low speed and keep the bit cool by constanly dipping it in water, no oil, and I did the whole job, some 40 12mm holes, with one bit. The other interesting thing was that I was going to drill a 5mm pilot first but he told me not to as that would kill the 12mm bit quicker, the cutting flutes on the larger bit running around the edge of the smaller hole creates a hot spot that kills the edge.
How come older guys know this stuff ?
Nick H is offline
Old 02-12-2006, 04:57 PM   #7
Rapture's Avatar
Trade: Booth Engineering
I've used the Bosch Blue Granite line of Drill bits to install anchors in a movie theater. I've use it several times and hasn't failed me yet. I bought three of them thinking I would go through them quickly (same concern as the topic), but I like their performance and they last. My experience only of course. Good luck. (blue guy for Blue Granite)
Rapture is offline
Old 02-12-2006, 05:37 PM   #8
Teetorbilt's Avatar
For the best bits, contact a tool supply company. Harbor Tool Supply is a good one (not to be confused with Harbor Freight). DoAll is another. Most machine shops will tell you where they buy their tools, maybe even order for you.
IMHO, Ridgid is the best 'off the rack' for metals. I've drilled through some Grade 9 and 11 bolts with them.
Albert Einstein
Teetorbilt is offline
Old 02-12-2006, 05:56 PM   #9
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
As said before low rpms and cutting fluid. I always knock the speed down on the drill press when I am drilling hardened steel. Go light on the pressure also.
JustaFramer is offline
Old 02-12-2006, 06:52 PM   #10
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Used to be a machinist and some of the old timers used to use milk to cool their drills when cutting SS. Didn't think to ask if it was skim, 2% or whole though .
Jim P.
jproffer is offline
Old 02-12-2006, 09:10 PM   #11
Teetorbilt's Avatar
A lot of the old guys swear by spit on SS too. The main thing with SS is to not let it get hot, it work hardens easily and then you really have a problem. You want to keep a low rotational speed and fairly high feed rate, this will keep the heat in the chip.
Albert Einstein
Old 02-12-2006, 10:21 PM   #12
Spectatorz's Avatar
Trade: Ca. General
Thumbs up
I worked as a machinist back when too. Feeds and Speeds are Critical.
The best drill bits I have found are from these guys : http://www.baddogtools.com/drillbits.htm
We all need to use and or buy these anyway, Why not get a Lifetime Guarantee ?
My personal set has done well for me so far, had them for a little over a year now.
"Success" Is The Ability To Go From Failure To Failure,
Without Losing Your ENTHUSIASM.
The Only Place that Success comes Before Work is in The Dictionary.
Spectatorz is offline
Old 02-13-2006, 12:06 AM   #13
RobertCDF's Avatar
Trade: Custom deck builder
Bosch blue granite are the best for masonry drilling IMO as well. Not to be confused with the Bosch SDS bits those are not nearly as good.
RobertCDF is offline
Witch Drill Is better? Morry Tools & Equipment 16 08-09-2007 04:14 AM
Dewalt 36V Drill Too much torque? GregS Tools & Equipment 11 05-07-2007 03:47 PM
dewalt drill broken?? fast pasquale Tools & Equipment 5 03-30-2007 04:13 PM
What to do with drill bits firehawk23 Tools & Equipment 9 01-11-2007 03:42 PM
milwaukee hole hawg or ridgid r7130 drill?? ko_jun Electrical 10 07-28-2006 11:54 AM
