Framing Nailer Rapid Fire When Connected To Air
I have two Bostitch N88RH framing nailers. One started a couple months ago and now the other one just keeps firing when connected to air. I suspect it's a bad seal or possibly not enough oil. I don't oil them everytime I use them but probably once out of every 3-4 days used. Anyone know what might be the problem? I'm going to pull one of them apart this afternoon to check for something obvious.
BTW, they have very little use, probably 5-10 cases of nails shot through each. |
Trade: builder of stuff, real nice stuff
Re: Framing Nailer Rapid Fire When Connected To Air
They start firing continuously when you connect them. Wow that would be a fun surprise.
unlicensed hack
Trade: wood butcher
O-ring went bad, prolly blowing air past the trigger into the cylinder.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
Well, we slide the nails back when connecting. Both of these guns, since purchased, have fired a nail when connected to air.
I pulled one of them apart and inspected all of the o-rings but didn't find anything that could definately cause it. However, I cleaned everything and put it back together lubing everything with oil and now it just leaks air continuously from the exhaust. I think the problem might be the big valve at the top of the cylinder, below the exhaust, which I think opens to let the air exhaust. It has a strong spring but still seems to stick. I'm in the Bahamas and the nearest repair place would be at least 200 miles and an airplane ride away. |
#5 | |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Framing Nailer Rapid Fire When Connected To AirQuote:
Damn, my man, after you get them working again you might want to reconsider that. Air tools love that oil!
#6 | |
Moderator
From the Bostitch site;
unlicensed hack
Trade: wood butcher
#1 & #2..... Isn't that what I said????
#8 | |
Moderator
gtc, where are you? Highbourne? New Providence? (180 mi.)
#10 | |
unlicensed hack
Trade: wood butcher
#11 | |
![]() When I say I oil them every 3-4 days, that's with limited use. We rarely use them all day long. I'll try to find a place to order a rebuild kit. Thanks. |
Chief Toilet Mover
Am I the only guy that oils a pneumatic tool every time I use it? Got a slew of PC guns and everyone works like new, all are about 5 years old, they seem to be dirt cheap and reliable as hell.
Dan
mike, we oil our tools on a daily basis. keeps them running longer.
Trade: Renovations
2 drops every day they are used.
#15 | |
Moderator
Must....... resist........ being.... tacky!!!
Faulkner Building Co.
Trade: Building/Remodeling
switch to Hitachi or Max.
Any of you guys run automatic oilers for tool oil on your air compressors? I see some of the roofers with auto oilers on their compressors. Seems like an easy fix for lazy employees (and owners).
| max coil framing nailer for sale | judsteam | Contractor Swap | 0 | 05-25-2007 04:04 PM |
| plaslode framing nailer | lxdollarsxl | Tools & Equipment | 5 | 09-05-2006 07:53 AM |
| I need a new framing nailer | hammily | Construction | 3 | 04-04-2006 08:23 AM |
| bosch framing nailer | S&P Builders | Tools & Equipment | 7 | 02-20-2006 05:54 PM |
| Where's my thread? (Politics anyone?) | AAPaint | Off Topic (Non Trade) | 175 | 08-16-2005 01:45 AM |
