Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 03-24-2009, 07:50 PM   #1
Trade: GC - Home repair
Fein Multimaster
Fein Multimaster
Great quality tool but overpriced, but dont mine paying for quality.
But what a rip off on the blades. Overpriced and you don’t get the high quality. They seem to really take advantage of customers with the pricing this and is why I wont buy any other Fein tools out of principal.
Just got a Harbor Freight tools catalog. I know cheap disposable tools.
But they have a clone for $39.99 that also comes with 2 blades, scraper and sanding pads.
The replacement blades are only $5.99.
I wonder if the blades would fit the Multimaster. After 10 years with my first one I recently upgraded to the new model with the sort of star shape in the blades.
The Fein blades are only Harbor Freight quality anyway, maybe worth a try.
rayh78 is offline   Reply With Quote
Old 03-24-2009, 07:54 PM   #2
Plausible Deniability
JumboJack's Avatar
Originally Posted by rayh78 View Post
Fein Multimaster
That would be nice.Someone on ebay sell blades that fit that are pretty cheap.I have never used them.
"The problem with socialism is that eventually you run out of other people's money."
JumboJack is offline   Reply With Quote
Old 03-24-2009, 08:02 PM   #3
loneframer's Avatar
Trade: residential framing/general carpentry
Fein Multimaster
I just talked to a guy today who has the HF clone. He was working side by side with a guy with the Fein. He claims it was a close match. The HF model is one speed (11,000) if I remember correctly. The Fein ranges from 11,000- 24,000 I think? He said the HF blades are not a perfect fit but worked and didn't fall out. I'm gonna go look at one this weekend. I'm sure it will not come close to Fein for dependability, but you can get them 10 for the price of 1.
" It's a Jersey thing, you wouldn't understand"
loneframer is online now   Reply With Quote
Old 03-24-2009, 08:02 PM   #4
Trade: Framing
Fein Multimaster
I have that HF model. Just saw a review online and the only thing bad was the fact it was single speed. That being said, I wouldn't use it every day. But as an occasional tool it is fine!(cheap blades)
The hole is a circle in the blades, don't know what youyrs requires!
Framer53 is offline   Reply With Quote
Old 03-24-2009, 08:12 PM   #5
Trade: Kitchen & Bath, General Contractor
Just a quick tip- The blades are very easy to sharpen as good as new again.
Blue Point is offline   Reply With Quote
Old 03-24-2009, 08:25 PM   #6
IHI
IHI's Avatar
i've been wanting one forever, just have a hard time swallowing that kind of coin, so i looked at the Dremel unit at Menards for $99, comes with a case and basic blades, i then looked at all the blades they had on the shelf and upfitted it with everything they had in stock for $146 total, unit and blades. The nice thing, the Dremel blades are compatible with the Fein multitool so there's your cheap out on blades I've only used it a few times and it's done everything i've needed it to do, has the variable speed and worked like a champ
first time i tried it i was putting floor patch panels in and wanted to see how easily it cut square corners...it slipped down through the 1x's like butter.
IHI is online now   Reply With Quote
Old 03-24-2009, 08:27 PM   #7
Trade: Finish Carpentry
Send a message via AIM to Quiglag
This has been posted a number of times http://multiblades.com/ I have never used them.
Quiglag is offline   Reply With Quote
Old 03-24-2009, 08:35 PM   #8
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Get a MM, the rest are just toys.
Buy a MM once in your lifetime, or 10 dremmels, rockwell, bosch whatever. The Orginal is still the king. Yes it is a tool that will see limited use but, when you have something come up that you need the MM for, I can garuntee that the Fien will work everytime you whip it out!!
I am thinking about painting mine green.
WarnerConstInc. is online now   Reply With Quote
Old 03-24-2009, 08:42 PM   #9
JumboJack's Avatar
That is so very true.It makes super tricky/awkward cuts a breeze.
Not to mention what it can do with tile,sanding,scraping and on and on.
Old 03-24-2009, 08:47 PM   #10
I refuse to sand with the MM but, that is just me. If I was a doctor, I would preform open heart surgery with a MM!!
Old 03-24-2009, 08:52 PM   #11
JumboJack's Avatar
I have only ever used it to get into really tight corners.I have too may other sanders for the dig stuff.
Old 03-24-2009, 09:25 PM   #12
wooddan's Avatar
Trade: Framing and Trimwork
Docs use it for cutting off casts. It does hurt when it hits the skin though.
wooddan is offline   Reply With Quote
Old 03-25-2009, 12:17 AM   #13
Palisade Point Const.
TempestV's Avatar
The multi-master is great other than the cost of the blades. I really need to order some off of multi-blades. As far as the ultimate cheap option, I have a pneumatic tool designed to remove windshields that works just like the multimaster, and even takes Fein supercut blades. You could buy the saw and a blade off of multiblades for less than the cost of the HF tool, and yet it's really good quality. Here is a post I had in another thread about it.
As for a really cheap alternative to the Fien, check this out:
http://www.tool-home.com/products/ca...oducts_id=6266
It works the same as the fien, and is surprisingly good quality. It takes a fair amount of air, but when the pressure is up, it cuts faster than a Fien multi master, or about the same as the Fien Supercut. It takes Supercut blades, although you can use Multimaster blades if you really crank down on them. In order to fit the sanding pad, replace the washer and bolt that hold the blade on with something smaller to fit in the depression in the sanding pad (10 min and $2 at the hardware store). The greatest thing about this tool is the size however- about the size of the Procon detail saw, or about half the size of the Fien and the Dremel- great for getting into tight places. The tool exausts to the rear, so if you remove that black tube off the back, It blows air over your arms, which feels really good during the summer, but is less desirable in the winter. It will however make a passable air gun for blowing dust. As for cons- this thing uses a lot of air if you are using it a lot. I was running mine off of a 8 gallon wheelbarrow compressor, and with just the one tool plugged in, it was running at least half the time. Then there is the noise. Cross the noise that the Fien makes with a dentist's drill and double the volume, and you have an idea of what it sounds like. Anyways, I usually use my Fien, mainly because of the convenience of plugging into the wall, but it's really handy when I need to get in somewhere really small, or if I need both a sanding pad and a blade, because I can set up one on each.
TempestV is offline   Reply With Quote
Old 03-25-2009, 03:22 AM   #14
General Contractor
Winchester's Avatar
Trade: Residential & Commercial
My fein MM is great.
I want to buy their vacuum as soon as I have the extra money.
Winchester is online now   Reply With Quote
Old 03-25-2009, 11:49 AM   #15
jcalvin's Avatar
What does HF call their model. I have been trying to order one for a couple weeks now and can't bite the bullet. It would be so much easier to do it if it was only $40. I will only be using mine occasionally that I can think of now. If I use it more than I think I will, I will jump into the MM without a problem.
Cal
You hired WHO
jcalvin is offline   Reply With Quote
Old 03-25-2009, 12:02 PM   #16
jcalvin's Avatar
I think I found it. It is listed at 59.99. Is this it?
http://www.harborfreight.com/cpi/cta...emnumber=65700
Cal
You hired WHO
Old 03-25-2009, 12:08 PM   #17
If you sign up for their
e-newsletter, they send you
a "special" 20% off coupon
every week.....
neolitic is offline   Reply With Quote
Old 03-25-2009, 01:04 PM   #18
TempestV's Avatar
Keep in mind, that's going to cut like a multimaster on it's lowest setting.
As long as you have a compressor on site, buy the window remover for $16, and a bunch of blades. It will work way way better.
Then maybe later you can jump right past the multimaster and get the supercut, which will use the same blades as the window remover.
ETA: there is a converter that you can buy to fit multimaster blades on a supercut. It costs about $30, but I'm not sure if it will work on the window remover, because I think it threads into the bolt hole, and I'm not sure it's the same thread. I'm intending to look into it, because it would be great to be able to use the same blades for my Multimaster and the window remover.
Old 03-25-2009, 02:25 PM   #19
jcalvin's Avatar
Isn't a multimaster on it's lowest setting still better than a sawzall on any setting?
Cal
You hired WHO
Old 03-25-2009, 03:34 PM   #20
Trade: Design
Only for small cuts without nails...
(Love the multimaster...but it's not meant for nail-embedded wood.)
gallerytungsten is offline   Reply With Quote
multimaster vs crain 820 for undercutting denverboz Flooring 8 07-31-2008 10:45 PM
Fein Multimaster newenergy Tools & Equipment 12 06-17-2008 02:28 PM
Anybody seen the Fein Multi-master infomercials? Mike Finley Tools & Equipment 6 02-16-2008 07:30 PM
How would you do this? Mike Finley Remodeling 20 09-03-2007 09:32 PM
I think Fein is real Fine ron schenker Tools & Equipment 1 07-20-2006 07:24 PM
