Fastcap 3rd Hand Support System.
Old 12-19-2011, 09:44 AM   #1
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Hey guys does anyone have the fastcap 3rd hand poles?
Here's the link...
http://www.amazon.com/FastCap-Suppor...4309157&sr=8-1
I know zipwall is the industry standard but I want to gives these a shot. They seem more versitile..
What does everyone think?
Rich D. is offline
Old 12-19-2011, 09:48 AM   #2
Dirtywhiteboy's Avatar
Rewards Points: 7,966
Re: Fastcap 3rd Hand Support System.
I've got one and it works fine. I hear the Harbor Fright ones are good too
Dirtywhiteboy is offline
Old 12-19-2011, 09:52 AM   #3
Repair & Renovation
Rich D.'s Avatar
Aren't they just load bars for trucking? Or???
I want something that won't damage the ceiling when putting up protection...
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 12-19-2011, 09:59 AM   #4
Pgfman's Avatar
Trade: Gc
Rewards Points: 75
I have these. They are awesome for dust shields. I havn't used them for crown yet like they show in the picture but they are definitely useful if you work alone.
Pgfman is offline
Old 12-19-2011, 10:03 AM   #5
I got mine at Woodcrafters,,,,, It's 6:00 I gotta go to work
Old 12-19-2011, 10:04 AM   #6
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
I've had a set of four for several years now. I use them mainly for setting upper kitchen cabinets. They make minute (1/16") adjustments easy and simple.
They aren't that good for crown. I use adjustable plastic hangers for that. But they WILL effectively force a piece of crown into place while glue dries when nails aren't holding all that well.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 12-19-2011, 10:21 AM   #7
Giving it my best
RS Sam's Avatar
Trade: Cabinet Maker and Residential Remodeler
Rewards Points: 512
I work alone and use one of these for all kinds of help, including crown work, and who knows what else. I'm glad to have it - sometimes wish I had 2 or 3 - like for curtaining areas. Not a substitute for a laser jamb pole to hold your laser level but otherwise a great 3rd hand.
Grace is bestowed upon the soul - not upon the ego.
RS Sam is offline
Old 12-19-2011, 12:24 PM   #8
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
I have two, but will pick up two more if I stumble upon some. They have a magnetic tip on them that you can use to clip plastic sheet onto to make setting up a barrier wall pretty easy. I also have a pair of short ones that I use if I need to remove/replace cabinet uppers when the bottoms are already installed.
Rustbucket is offline
Old 12-19-2011, 12:53 PM   #9
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
I have a set as well, mainly for containment. Here are some thoughts of these vs. the Zipwall.
The 3rd hands are considerably cheaper and considerably sturdier. They are also considerably heavier and not quite as easy to use as the Zipwalls.
For putting up containment the system they use, a spring loaded pin and holes every 18" or so and then the levered adjustment at the end is a little more awkward to set up, especially on tall ceilings such as we have here (10'-13' or higher).
If you are getting them for containment barriers, honestly if the price were the same as Zipwalls I would get the Zipwalls, since it's not it depends on how important the diff in price matters more than the extra weight and less convenience. If you are getting them for assorted tasks, things like cabs or other load bearing uses they are a good choice.
They are sturdy, much sturdier than the Zipwalls. I checked the HF ones before getting the 3rd hand and they are junk. If you cant inspect the HF before buying I urge to be cautious. However the HF ones are dirt cheap.
I am interested in getting more poles for containment and may well get the Zipwalls for dedicated containment uses and use the 3rd hand for other tasks.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
The Following User Says Thank You to moorewarner For This Useful Post:
scraigc (12-24-2011)
Old 12-19-2011, 02:12 PM   #10
Repair & Renovation
Rich D.'s Avatar
Thanks for all the responses everyone. I just ordered 2 to test out.
The price is right and they can do more then just hold up plastic sheeting... Which is deffinitly a plus for me... I can think of 1000 uses already...
The extra weight isant a concern and I am a patient man so they shouldn't be a problem. Can't wait for them to arrive.. should be here by tommorow..
Rich D. is offline
Old 12-19-2011, 02:45 PM   #11
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
To be honest with you all the subs and other contractors that have happened by my jobsite while using them never have seen 'em before. Since I'm a cheap 'ole crusty bugger I have the harbor freight ones. They have some issues tho. But I use them on every job.
One purpose that really comes in handy is for ceiling drywall. 3 man crew, 2 hold the sheet up, I come behind and jack the 2 poles up, they have two hands to screw it home while I'm cutting the next.
I've got about 20.
Paulie is offline
Old 12-19-2011, 03:29 PM   #12
Cool beans, whether you run the 3rd hand, zipwall or hf they are a great addition to the arsenal, enjoy em.
Old 12-19-2011, 04:14 PM   #13
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I use mine for holding up drywall, top plates, straightening bowed timbers, crown and of course containment. They have so many uses after you have them. They will extend pretty dam far.
www.bcconstructionllc.com
BCConstruction is offline
Old 12-20-2011, 08:11 PM   #14
Repair & Renovation
Rich D.'s Avatar
Well just got the 3rd hands I ordered off amazon. They look cool... Just one problem. There missing all the top and bottom pads... Now I gotta send em back and have amazon send me new ones.
Rich D. is offline
Old 12-21-2011, 05:44 AM   #15
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,184
I've got 4, plus 4 zip walls. I primarily use them for containment. They call em 3rd hand, because you almost need a 3rd hand to use them for containment. My zip walls are my go to poles & the 3rd hand if I got more than 2 doors to cover.
pinwheel is online now
Old 12-24-2011, 04:48 PM   #16
ewils91's Avatar
Trade: Finish carpentry
Rewards Points: 25
We have 9 of these, we use them for crown, drywall, tin ceiling, cabinetry...all kinds of stuff.
We had 8 but one of our customer's kids broke one of the tension screws off when he hit it moving his bicycle through the house. I called Fastcap to see if I could order a replacement part...after all it was not their fault. The owner got on the phone and told me he would not send me a part, he made me take a complete replacemet for free. Then he made me take some crown hangers for free too., so now we use the broken one without the tension screw.
ewils91 is offline
Old 12-24-2011, 11:21 PM   #17
Pgfman's Avatar
Trade: Gc
Rewards Points: 75
They are awesome. Something similar happened to me. I got the 4 pack and I accidentally broke the threaded ball joint off one. I called them up and they sent me a free replacement. It came in the mail a few days later. They have great customer service!
Pgfman is offline
Weep system for thin veneer Stone Masonry 3 07-01-2010 11:15 PM
Inspector wants fire sprinkler system TLE/RL1911 General Discussion 90 06-04-2010 04:35 PM
Exhaust Fan Hood System Help... Remco Air HVAC 1 06-27-2009 10:24 AM
Systems Development List Gordo Business 19 01-08-2007 06:28 PM
