Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 04-09-2009, 11:44 PM   #1
StaggsConstruction.com
Trade: carpenter
Enclosed Trailers & 1500 Trucks
I was wondering if anyone here is pulling or has pulled a 16' Enclosed trailer with a Dodge Ram 1500, and what it was like. I have a 2007 Dodge Ram Quad Cab Hemi 1500 and am thinking about purchasing a 16'x7' Cargo Craft dual axle trailer but am just a little worried about it being too much for the truck to handle. I'll be hauling cabinets and tools so I wont be adding too much weight. what do you think?
jcs1984 is offline   Reply With Quote
Old 04-09-2009, 11:48 PM   #2
Rock it...
BattleRidge's Avatar
I have a friend thats a drywall contractor that does that, he has a chevy 1500 with the same trailer. Lots of scaffold and such too.
www.battleridgebuilders.com
BattleRidge is offline   Reply With Quote
Old 04-10-2009, 02:14 AM   #3
Palisade Point Const.
TempestV's Avatar
A newer half ton shouldn't have any problem with that. If you had a half ton from before the auto manufacturers started competing for higher half ton towing rating, then I would recommend upgrading if you were pulling something like that on a regular basis, but a 07 shouldn't have any problems.
Even my 96 F150 can pull a 12' dump bed trailer, but it doesn't really like it, and I wouldn't want to do it on a regular basis.
TempestV is offline   Reply With Quote
Old 04-10-2009, 05:57 AM   #4
wolffhomerepair's Avatar
Trade: General Remodeling
Make sure you check the weight rating of your hitch. If it is a class 3 you may need a weight distributing hitch to be legal.
http://www.wolffhomerepair.com
" Of course I don't look busy, I did it right the first time "
wolffhomerepair is offline   Reply With Quote
Old 04-10-2009, 08:35 PM   #5
Fyrzowt's Avatar
Trade: Finish Carpenter
My jobsite trailer is only 8', but I do tow a 25' Airstream travel trailer. To Yellowstone and back with my GMC 1500 no problem.
It's going to come down to how much weight you put in it. Load it up and take it to a scale - you may be surprised at how much it really weighs loaded. As mentioned earlier, you may need a weight distribution system.
Fyrzowt is offline   Reply With Quote
Old 04-11-2009, 12:09 PM   #6
Mark
mhillc's Avatar
Trade: carpenter
I pull a 6x12 two axle trailer everyday for the last 5 years with a 98 dodge 1500 4x4. The trailer is fully loaded with tools and sheving.Its alittle bit heavy for that truck but it pulls great.I added ashift kit to help with the shifts,working out well.
mhillc is offline   Reply With Quote
Old 04-11-2009, 02:24 PM   #7
M.A.D. Renovations
Tattoo's Avatar
I used to pull a 16' v-nose ... weighed about 6500lbs loaded with gear.... with the same truck (07 1500 quad with the hemi) it wasn't to bad but it struggled on starts and steep inclines..... the new 08 F350 deisel does a much better job.
Tattoo is offline   Reply With Quote
Old 04-11-2009, 03:16 PM   #8
woodchuck2
woodchuck2's Avatar
Your truck can pull that trailer fine. It is going to suck gas and it may be hard on your tranny but you will have plenty of power to pull it.
woodchuck2 is offline   Reply With Quote
Old 04-11-2009, 06:54 PM   #9
Trade: framing contractor
I have an 07 1500 Ram and we pull 7x14 enclosed trailers all day with no problems. I have added an extra leaf to the back springs on all our trucks. I am not sure what we will do to the 09 with coil springs.
Tony
tonyeastern is offline   Reply With Quote
Tags
trailer dodge weight
New fuel efficient trucks are now guaranteed Mike Finley Vehicles 4 07-31-2008 12:13 PM
Enclosed Trailers What has everyone had good luck with TurnkeyConst Tools & Equipment 24 07-19-2007 09:57 PM
subbing w/ logo'd up trucks and trailers. Mr. D General Discussion 18 09-12-2006 08:17 PM
Enclosed Trailers jimcuviello Tools & Equipment 2 09-03-2006 11:56 AM
