Drywall Sanders
Old 10-19-2008, 04:40 PM   #1
Sean
SLSTech's Avatar
Drywall Sanders
Has anyone used the King Drywall Sander & how does it compare to the PC one?
Link for King Drywall Sander = http://www.kingdrywall.com/?gclid=CL...FQ4hnAodsWYTEw
FYI - I will not be using it for drywall. I need a sander to sand a T&G wood ceiling that was painted a few times & then had the famous popcorn texture shot on it (almost 1000 SF). The Popcorn has been scraped off, but I still have some residual mud & paint to remove. The HO wants to stain the wood after it is all cleaned up. I can either rent a PC, or for a few more bucks buy the King one. Any other idea's? (using a regular orbital sander would probably take about 40 to 50 hours - I figure with the bigger sander I could complete it in about 15 - to 20 hours)
Thanks
SLSTech is offline
Old 10-19-2008, 04:43 PM   #2
Handle It!
MALCO.New.York's Avatar
Re: Drywall Sanders
Ultimate Wisdom---------
MALCO.New.York is offline
Old 10-19-2008, 07:09 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Re: Drywall Sanders
I think you would ruin a bunch of sandpaper with the PC or other. You need something with holes in the paper and integrated dust extraction. Or soy-gel stripper.
WarnerConstInc. is offline
Old 10-21-2008, 08:32 AM   #4
Sean
SLSTech's Avatar
Re: Drywall Sanders
Thanks for replying - unfortunatly I don't see the stripper as being a viable option.
SLSTech is offline
Old 10-21-2008, 09:46 AM   #5
s. donato's Avatar
Re: Drywall Sanders
why not try this one?
http://www.dustlesstechnologies.com/...php?II=9&cat=3
i don't know if it would work any better or worse then the PC or the one you posted but at least its square it may sand the corners better ;-)
i think this is an occasion where getting scaffold and laying on your back with a belt sander may be the easiest option - i am in no way saying it will be easy, but i think all the drywall sanders may not be aggressive enough to get you down to raw wood, so you can stain it. plus you have a lot of grooves to clean out to make the stain look good for the finished detail.
how long would it take to install a new T&G ceiling? ;-)
s. donato is offline
Old 10-21-2008, 02:40 PM   #6
jiffy's Avatar
Trade: General Construction
Re: Drywall Sanders
Check ebay, I have seen some tools on there that are real inexpensive lately.
jiffy is offline
Old 10-21-2008, 06:24 PM   #7
Sean
SLSTech's Avatar
Re: Drywall Sanders
s. donato - I saw the one you mentioned earlier, I can't see that working
By the way it is T&G wood not Bead Board (it is like hardwood flooring - however it is on the ceiling) & no I am not strong enough to lift a floor sander up that high, & use it for more than maybe a second
I have heard people actually using the Porter Cable one on floors & wood paneling with good results - I haven't heard anything about the King one though, even for drywall work
jiffy - ebay, always an option but I generally shy away from private sales without being able to test it first
Thanks guys
SLSTech is offline
Old 10-21-2008, 08:52 PM   #8
I like Green things
Re: Drywall Sanders
Sounds like a job for a Rotex and a CT dust extractor. You could have a Planex shipped in from over seas, the suction is so good on that, that it really does hold itself to the ceiling!!!!
Old 10-22-2008, 08:46 AM   #9
s. donato's Avatar
Re: Drywall Sanders
interesting ceiling with out any type of beads in it most of the ones i see around here all have some type of bead... part of me still says using a belt sander to do the majority of the work then using a orbital to finish it would look really nice.
don't forget to get your self some sandpaper cleaner. otherwise your going to go through alot of sandpaper - well alot more ;-)
http://www.mcfeelys.com/product/ABC-...aner-8quotlong
if your going to go the rotex way - go fein instead they make a 8"...
http://www.mcfeelys.com/product/FEIN...-Orbit-Sanders
add a festool or fein vac and you would be pretty dust free ;-)
Old 07-16-2009, 03:56 PM   #10
Hammerstein's Avatar
Trade: Drywall
Re: Drywall Sanders
Do you use a Festool Planex? I am considering having one shipped from the UK.
Hammerstein is offline
Old 07-16-2009, 09:31 PM   #11
I like Green things
Re: Drywall Sanders
I wish, I want one as soon as it is available. I have the PC, it does the job.
I looked into having one shipped, then I remembered that I would need to order a bunch of sand paper for it. So once I figured out it would be over 2K, I gave up.
Old 07-16-2009, 09:44 PM   #12
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
Re: Drywall Sanders
just throwing this out there..but would blasting it with walnut shells work on something like this? If not I never said < this
nEighter is offline
Old 07-16-2009, 09:51 PM   #13
Sean
SLSTech's Avatar
Re: Drywall Sanders
Forgot about this one - Warner nailed it, I used a crapload of paper, but it was completed in about a day (not down to bare wood, good enough for painting - yep HO changed their mind)
Not sure about the walnut shells, maybe one of the blasters can speak up
SLSTech is offline
drywall sanders Worm Drive Drywall 20 07-17-2009 07:52 AM
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 06:19 AM
drywall romaina-europe crystal Drywall 20 02-08-2009 05:28 PM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 11:52 AM
Breaking into the commercial drywall work dryrocker27 Commercial Construction 8 12-11-2007 06:48 PM
