Do You Charge For Blades
Old 07-13-2009, 10:30 PM   #1
katoman's Avatar
Trade: carpenter
Any sawzall or Fein blades that are damaged, broken, worn out on a job, I charge for. Also for hammer drill bits - recently broke 14 on one job. But I don't charge anything for chop saw blades. Consider that overhead.
Just wondering if you do the same?
katoman is offline
Old 07-13-2009, 10:33 PM   #2
LRG WoodCrafting
Leo G's Avatar
Re: Do You Charge For Blades
I can only see doing this on a T&M job. If you have a contract price, your price should have expendables built into it.
Unless you put a stipulation in the contract that all extra blades/bits used will be a change/add order.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
nEighter (07-14-2009)
Old 07-13-2009, 10:34 PM   #3
Capra aegagrus
Tinstaafl's Avatar
That would be on a case-by-case basis. Generally, my blades & bits last through several jobs at least, so it wouldn't be kosher to charge the last victim separately. But on a job that's an obvious tool-killer, yep, I charge for 'em.
Tinstaafl is online now
Old 07-13-2009, 10:35 PM   #4
katoman's Avatar
Trade: carpenter
Yes, I'm referring to T&M jobs. Thanks for the clarification.
katoman is offline
Old 07-13-2009, 10:36 PM   #5
LRG WoodCrafting
Leo G's Avatar
Of course, if it is a T&M, bits and blades come under material.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-13-2009, 10:38 PM   #6
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
I dont charge for them, but, I make a big deal with the HO if I'm eating blades and bits. Makes them feel better about the bill maybe???
willworkforbeer is offline
Old 07-13-2009, 10:41 PM   #7
Inner10's Avatar
Trade: Control Systems
Typically I don't, I try to factor it into the overhead; if it involves cast iron drilling or other vile bit killers then I add in a hardware expense. I'll definitly have to start since its scary to think of the cost of all the 'disposables" I use up. I have a bad habit of not factoring in hardware expense on smaller jobs but it adds up fast.
Sawzall blades are crap after 3 cuts anyway, its like putting gas in your truck, chop saw blades last me a long time, i keep cutting with em until the strut begins to melt apart.
A big expense of mine is cobalt metal pin drills/twist drills; and small hammerdrill bits.
Inner10 is online now
Old 07-13-2009, 10:46 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Yes, probably, unless you come off as a drooling whiner.
Bottom line, you DO charge for them sooner or later if you're going to stay in business. It's just a question of whether you incorporate it into your general overhead or bill it out specifically to individual customers.
Old 07-13-2009, 10:52 PM   #9
genecarp's Avatar
No matter how you want to phrase it. you should be charging for every blade , bit and screw tip. G
genecarp is offline
Old 07-13-2009, 10:57 PM   #10
I come across more as a self-centered egostistical a**hole, damn the concequences. I may eat stuff but I dont whine.
Old 07-13-2009, 11:30 PM   #11
BobsLandscaping's Avatar
Trade: Landscaping
The rental company charger per 1/32" of wear on a saw blade. Perhaps you could institute the same policy if you're concernecd about it.
BobsLandscaping is offline
Old 07-13-2009, 11:37 PM   #12
Inner10's Avatar
Maybe less effective on a sawzall blade.
"And thats 37 cents for the wear on this new 14TPI blade..."
Old 07-13-2009, 11:39 PM   #13
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
I have a column on my spreadsheet when doing take offs...Shovels - $ 200.00
Gets priced into every job weather they get used, lost, stolen, doesn't matter, I call that part of my operating costs.
Chris
Chris Johnson is offline
The Following User Says Thank You to Chris Johnson For This Useful Post:
Old 07-13-2009, 11:40 PM   #14
Trade: Landscaping
That's for the diamond blades for the gas cut off saw and chop saw for pavers. For the concrete chainsaw I believe they charge per sharpening and only sharpen each chain x number of times before replacement.
Old 07-14-2009, 02:49 AM   #15
Fortune and glory, kid.
moorewarner's Avatar
Trade: Carpentry & Restoration/Remodeling
I wasn't, but I started. One of those nickle and dime things that started adding up.
moorewarner is offline
Old 07-14-2009, 06:12 AM   #16
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
I have a line item in my internal estimate for Shop Supplies that covers it.
On T & M or ballpark estimate smaller jobs I include the shop supplies again on each ticket usually $10 - $45. Covers disposables, sandpaper, gloves, blades. Its just a way of recovering the costs outside of the T & M that sometimes has the customer frowning for a minute. Most completely understand.
We Fix Houses is online now
Old 07-14-2009, 07:20 AM   #17
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
I include a line item "comsummables" if the job is T&M, it's either a lump sum price reimbursed to me as an extra, or I just include the items into the purchase of materials. On fixed price, I figure a number based on the type of the project, and add in accordingly.
Not charging, or forgetting to charge for blades, bits, tips, fasteners, disposal, etc. is easy to do. If you do not include a line item for these things, you can loose money on a job real quick.
I also try to pad my consummables a little bit to cover for wear and tear of equipment.
Kevin
www.BadcoDoors.com
Pearce Services is offline
Old 07-14-2009, 02:49 PM   #18
DrewD's Avatar
Trade: Log Home Construction/College Student
Along the same lines, my last boss only provided the cheapest quality circular saw blades and recip. saw blades. He told us if we wanted a better blade we had to pay for them without reimbursment. It sucked but I bought my own, mostly Dewalt brand, a few Freuds for any finish cuts, I didn't mind buying my own miter saw blades as much, they got less use on his jobs. I was wondering what any of your guy's policy was, if an employee provides his own circular saw/recip saw do you supply quality blades or not?
DrewD is offline
Old 07-14-2009, 03:00 PM   #19
mmike032's Avatar
Trade: trim carpentry
the boss should supply all the tools and quality blades if he wants a quality finished product.
Why would you use your power tools?
unless maybe your getting paid piece work?
IDK doesnt sound right to me.
mmike032 is offline
Old 07-14-2009, 03:14 PM   #20
LRG WoodCrafting
Leo G's Avatar
if you are an employee he should provide the power tools and accessories for them. Whether he wants to use high quality of crap is up to him. In most cases it is penny wise and dollar silly. If you are supplying power tools you should get medium quality, the employee will almost never treat them like their own. And get good quality blads/bits/tooling so they last a long time and give good results.
If you are a sub and you are using your "bosses" tooling on a regular basis, you might not actually be a sub.
Carpenter by day.
http://lrgwood.com
Leo G is offline
How much should YOU charge? B.K General Discussion 18 06-17-2009 07:20 PM
What would YOU charge??? finehomes Excavation & Site Work 6 04-01-2009 02:41 PM
how do i charge....... crystaldwn78 Painting & Finish Work 45 02-13-2009 05:38 PM
What to charge to install exterior door Buca1025 Windows, Siding and Doors 11 09-30-2008 04:43 PM
How much should I charge... zccarpenter Carpentry 29 09-24-2008 06:43 PM
