Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 04-10-2008, 08:24 PM   #1
Trade: carpenter
discussion etiquette
Nathan: I have a question regarding posting a link to a prototype that I have a patent on. I just want some feed back from some peers, is this cool?
mike backman is offline   Reply With Quote
Old 04-11-2008, 02:55 AM   #2
Trade: General
I give you my permission.
Timster is offline   Reply With Quote
Old 04-11-2008, 07:22 PM   #3
Greg Di's Avatar
Trade: Remodeling & Decks
Mike,
I guess you're done over at the other site, huh?
Greg Di is offline   Reply With Quote
Old 04-11-2008, 07:36 PM   #4
Trade: carpenter
I think there done with me. I believe I approached the forum thing all wrong.
Old 04-11-2008, 07:52 PM   #5
Custom Deck Builder
BuiltByMAC's Avatar
Trade: Decks, patio roofs
Dude, I'm sorry but I can't see the application. (2) 36" clamps and a beam saw will take care of 24 2x4s, sitting on the lumber stack, with no setup time.
This is not me trashing you or your invention, this is a builder telling you try, try again 'cause this one ain't gonna fly.
I don't think Nathan will mind because you're not trying to sell it to us, merely get feedback, but I wouldn't expect a drastically different reaction here.
Mac
BuiltByMAC is online now   Reply With Quote
Old 04-11-2008, 08:08 PM   #6
Trade: carpenter
Mac, with that method don't you need to measure each and every group of 24?
Old 04-11-2008, 10:32 PM   #7
Custom Deck Builder
BuiltByMAC's Avatar
Oh definitely. But with a 12" speed square and a 3' level, I can pull measurement on one and mark line on all 24 before you can get the two pole pieces screwed together. And if I had to do that for 300 studs, I'd have to pull a measurement only 12 more times. I'll bet I'd still beat your tool in total time. Positioning a clamp on one end of the bunch so I can butt all the ends up against the clamp means I'm only making one cut per bunch. Half as many pieces to pick up, half the speed to cut to length. I can keep my saw in one spot (don't have to move it around the lumber pile), move the lumber only once (from stack to wall layout) - it just seems like a helluva lot more expedient way to cut than using your tool.
What application are you focusing on? For new construction, wall heights are built to standard stud lengths - 92 1/4", 96" or 108". I've never seen a jobsite where they needed to cut 300 studs to the same length. Remods and basement pony walls are not usually that perfect - each stud gets cut to fit.
But I'm getting ahead of the thread - I know what you're working on 'cause I, like some others, frequent multiple forums. Go ahead and start up a thread with your YouTube video and get some more feedback. I'll stay outta that thread and let the opinions fly. The crowd's more blunt here though, keep that in mind...
Mac
Old 04-11-2008, 10:55 PM   #8
Jason W's Avatar
Trade: Preservation & Reproduction Millwork
Let me see it
*and by the way Mac, blunt is what I love about this place! (and obviously many others feel the same)
Jason W is offline   Reply With Quote
Old 04-12-2008, 08:46 AM   #9
Trade: carpenter
mac, That is a prototype. the threaded poles have been redesigned. i have a piece of hardware that makes the same flush connection with 1/4 turn. and this tool is basically the same as your method but you need to measure once. what if you need to cut 200 studs? plus the clamp out front has been re designed.
Old 04-12-2008, 08:51 AM   #10
Trade: carpenter
also you don't necessarily need to square both ends that other end can be used as a stop. this is also an east coast west coast thing. most lumber yards don't do custom order studs out here and if they do there expensive.
Old 04-12-2008, 09:51 AM   #11
Custom Deck Builder
BuiltByMAC's Avatar
I can only comment on the tool I saw on the video - if you've completely changed it, that's great, but you can't use that as a valid argument to rebut my statements about your original tool.
You've built a tool that works for one application - cutting a crapload of studs. That would only be one small aspect of building a house. It's a large ungainly tool that takes several minutes to set up, takes up space in the truck, takes up space on the jobsite and is probably going to cost more than $100.
If I need to cut 200 studs, I'll make 9 measurements on bundles of 24 studs. 9, dude! That's it. Say we figure 7 minutes per bundle to measure, mark, cut and move - assuming the wall layout is within 20 yards of the stud stack. 3 trips w/ 8 studs - moved once...from stack to layout.
That's one hour spent cutting studs out of the entire time it takes to build a house.
The lengths I mentioned aren't custom order, they come from the mill that way. Where are you located? You can update your profile to fill in your location by clicking on the "User CP" button in the blue bar above and clicking on "Edit Profile" in the left-hand box.
Mac
Old 04-12-2008, 11:41 AM   #12
Trade: carpenter
maine
Old 04-12-2008, 11:48 AM   #13
joasis's Avatar
I, for one, would like to see it.....
I have never had the need to cut multiples of wall studs....we make the lumber yard do that.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is offline   Reply With Quote
Old 04-12-2008, 11:48 AM   #14
Trade: Home Remodeling
WWW.USPTO.GOV, search for all prior patents/ideas have been owned/licensed/published/sold/used/copied, etc.
SelfContract is offline   Reply With Quote
Old 04-12-2008, 12:57 PM   #15
mickeyco's Avatar
Trade: Squirrel Handler
That was going to be my question, what would be the application, and after all the set up work, then cutting what if you need to shave a 1/16" or 1/8" off the ends?
If you're trying to generate interest you might set yourself up a website that shows and explains it's operation, applications and benefits. Then you can put that link in your signature here and other places. If you have something good people will be interested.
mickeyco is offline   Reply With Quote
Old 04-12-2008, 01:02 PM   #16
Trade: carpenter
I'm a carpenter this whole website thing is over my head. I am currently tiryng to get help with that
Old 04-12-2008, 01:04 PM   #17
Jason W's Avatar
I took a look at it. I'm not to sure of it, I can measure once on my chop saw set up and gang cut 6 studs at a time with out having to clamp it down. I don't understand cutting both ends either for framing materials. The stuff I get is usually pretty square on the ends. Why not just a stop on one end? Or option of.
Seems like a lot of wasted motion and material just to cut 10 studs at a time. To each his own I guess. I can cut more lumber than two framers can put up with my set up just the way it is now.
Old 04-12-2008, 01:10 PM   #18
Trade: carpenter
you can use one end as a stop, as for the "clamp" i have a way faster piece of hardware for that.
Old 04-12-2008, 01:12 PM   #19
Trade: carpenter
I believe that a chopsaw should be use for trim. and doing that many cuts kill them.
Old 04-12-2008, 01:18 PM   #20
Jason W's Avatar
Not to bust your balls or anything, but if you have made improvements to this you should do a new video and then post it. If set up time was cut in half you would do much better with it. Maybe a specialty mill or something along those lines would have an interest in it. I don't see it as a practical field tool the way it is now.
Etiquette Boogga Business 12 04-09-2007 09:36 AM
Discussion Brushslingers Painting & Finish Work 5 02-21-2007 08:25 AM
Contractor etiquette finding subs... alter_ego General Discussion 5 09-28-2006 11:05 PM
Employee Etiquette Debookkeeper General Discussion 25 09-23-2006 10:00 AM
Recent model laptop for CAD, discussion groups compare dudok General Discussion 3 03-10-2006 12:34 AM
