Direction Of Reciprocating Saw Blade
Old 04-23-2012, 02:32 PM   #1
Dan_Watson's Avatar
Rewards Points: 2,460
Which way do you usually put the blade in, with the battery down, teeth up or down?
Do you consider this the 'correct/right' way?
Dan_Watson is offline
Old 04-23-2012, 02:42 PM   #2
Tom M's Avatar
Rewards Points: 3,678
Re: Direction Of Reciprocating Saw Blade
Teeth down mostly but at the end of the day anyway I need it, I use it.
I use Porter Cable Tiger the handle rotates so that give me more freedom.
Tom M is offline
Old 04-23-2012, 02:43 PM   #3
J.C.'s Avatar
Rewards Points: 1,542
I turn it which ever way works best for what I'm cutting. There is no right or wrong way.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
The Following 4 Users Say Thank You to J.C. For This Useful Post:
Big Shoe (05-01-2012), Jaws (04-27-2012), pinwheel (04-23-2012), woodworkbykirk (04-23-2012)
Old 04-23-2012, 02:51 PM   #4
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Same here. I wonder if anyone makes blades with teeth on both sides ?
katoman is offline
Old 04-23-2012, 02:52 PM   #5
GRB's Avatar
Trade: Carpentry Contractor
Depends on what I'm cutting. Teeth down if I'm pulling the saw through a cut such as when cutting window openings. Teeth up when pushing the saw (like when cutting bottom plates out of door openings).
GRB is offline
Old 04-23-2012, 02:54 PM   #6
DavidC
DavidC's Avatar
Rewards Points: 2,006
The only correct way is the way I happen to be using it at the time. It's dangerous to use it otherwise.
Good Luck
www.CookContractingLLC.com
DavidC is offline
The Following User Says Thank You to DavidC For This Useful Post:
Jaws (04-27-2012)
Old 04-23-2012, 02:54 PM   #7
GRB's Avatar
Yes.
GRB is offline
Old 04-23-2012, 02:59 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 666
Sure. One make is Boar Blades.
Tinstaafl is offline
Old 04-23-2012, 03:04 PM   #9
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,854
Use a chain saw.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
Gary H (04-23-2012)
Old 04-23-2012, 03:06 PM   #10
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
That thing looks like it came out of a hacker movie
I'm with everybody else. I depends on what you are cutting. Sometimes putting the blade in with teeth pointing up gives you extra needed clearance.
Rustbucket is offline
Old 04-23-2012, 03:08 PM   #11
bconley's Avatar
Trade: Kitchen and bath design+remodel
If you put the blade backwards, using the orbital action it will not cut correctly
bconley is offline
The Following 2 Users Say Thank You to bconley For This Useful Post:
Brutus (04-23-2012), wallmaxx (04-28-2012)
Old 04-23-2012, 03:08 PM   #12
katoman's Avatar
Trade: carpenter
Thanks guys, I didn't know anyone made those. I'll have to get some.
Hey Killer - chainsaws are for subdivision work.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
Old 04-23-2012, 04:50 PM   #13
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
try explaining that to a know-it-all young buck. I was telling him to either turn the blade around or switch it off orbital... wouldn't do either.
We also use a Milwaukee recip which has the 360 degree rotating handle. Not as nice as the Makita AVT.... but certainly handy.
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
Old 04-23-2012, 10:09 PM   #14
Palisade Point Const.
TempestV's Avatar
Rewards Points: 1,632
Teeth up most of the time to take advantage of the reduced bulk above the blade as opposed to below the blade. I flip the blade if it becomes more convenient the other way.
TempestV is offline
Old 04-23-2012, 10:11 PM   #15
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
if im making a plunge cut i put the blade in backwards as the handle wont get in the way, for cutting out osb from r.o i put it the normal way or for cutting drywall.. i find having the blade the opposite way for making dirty cuts is more of a nuisance as the fan blows the dust right in your face otherwise
when i started out a old timer would flip out if you put the blade in the opposite way.... same guy no one on the crew wanted to work with.. ol lester...
woodworkbykirk is offline
Old 04-23-2012, 10:16 PM   #16
Handle It!
MALCO.New.York's Avatar
I find I have more strength and control when I up cut. When I pull. This is what determines which way I place the blade.
As others have said... Necessity dictates direction.
Remember... There is NO "Wrong way" if it gets the job done without damage to the tool, the job or the operator.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 04-23-2012, 10:18 PM   #17
TempestV's Avatar
So... you aren't suppose to cut trim with one?
TempestV is offline
Old 04-23-2012, 10:26 PM   #18
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 812
I like my blade sideways
dave_dj1 is offline
Old 04-23-2012, 10:29 PM   #19
The Grand Wazoo
I've never done subdivision work, and I mostly cut concrete with mine, but I have seen guys that could use one for fairly precise cutting work on demos.
Old 04-23-2012, 10:35 PM   #20
TempestV's Avatar
I've done a lot of demo with chainsaws, you just have to be aware of where nails are.
With a good, tuned up saw, and some skill, you can be well within a 1/16" of an inch with a a chainsaw.
TempestV is offline
Fein blade sharpening WilsonRMDL Tools & Equipment 34 08-05-2012 10:41 PM
Dewalt Precision Framing Blade hestonreno Tools & Equipment 25 02-24-2012 10:56 PM
Best saw blade for bamboo? Smatt Tools & Equipment 3 03-07-2011 08:59 PM
the shark blade?? ConcreteCutter2 Tools & Equipment 5 11-03-2010 08:19 PM
Best Utility Knife Journeyman T Tools & Equipment 48 02-20-2008 08:54 PM
