Cutting Xps
Old 06-07-2009, 06:32 PM   #21
Re: Cutting Xps
Originally Posted by Tinstaafl View Post
Ah, the clue is in the challenge. For the vintage that you grew up assembling...
Goat sinew!
When I was a kid
they were all made
out of rocks.
Wood was only for adult
high tech stuff.
neolitic is offline
Old 06-07-2009, 06:35 PM   #22
Capra aegagrus
Tinstaafl's Avatar
Re: Cutting Xps
high tech stuff.
Tinstaafl is online now
Old 06-07-2009, 06:46 PM   #23
KemoSabe
loneframer's Avatar
Re: Cutting Xps
high tech stuff.
loneframer is online now
Old 06-07-2009, 08:39 PM   #24
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Cutting Xps
Table saw will be the most accurate, if you want to use a knife use an OLFA HD utility knife
Chris
Chris Johnson is online now
Old 06-08-2009, 07:56 PM   #25
katoman's Avatar
Trade: carpenter
Re: Cutting Xps
Well we started today, went well and began installing the xps. I put a smooth scraper blade in my Fein - works awesome! I can cut as thin as 1/16" off. Unreal. Also works for cutting to size.
FYI this is the "don't kill the parrot" job. We weatherstriped the bsmt. door and put fans in the windows and seems fine. We are not using any toxic materials. The No More Nails Ultra is almost 100 percent safe and HO approved it. Will be using this to glue down the subfloor. Never heard a word from the parrot.
katoman is online now
Old 06-08-2009, 08:02 PM   #26
Capra aegagrus
Tinstaafl's Avatar
Re: Cutting Xps
Originally Posted by katoman View Post
I put a smooth scraper blade in my Fein - works awesome! ... Never heard a word from the parrot.
Well whyn't you say you have a Fein! Sheesh!
Just wait till the parrot starts imitating the Fein. HO's gonna love you.
Old 06-08-2009, 08:06 PM   #27
I'm a Mac
Re: Cutting Xps
You know XPS does off gas right?
Chris
Old 06-08-2009, 08:49 PM   #28
katoman's Avatar
Trade: carpenter
Re: Cutting Xps
You mean off gasses when it is cut? Any appreciable amount? The fans should exhaust any fumes it the air fairly quickley, and there is no cold air return in the bsmt. so feeling fairly safe.
Old 06-08-2009, 09:11 PM   #29
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Cutting Xps
how about this for a timely ad at the bottom of the page
naptown CR is offline
Old 06-08-2009, 09:21 PM   #30
katoman's Avatar
Trade: carpenter
Re: Cutting Xps
How much?
Old 06-08-2009, 09:22 PM   #31
katoman's Avatar
Trade: carpenter
Re: Cutting Xps
God, I can't believe I said that
Old 06-08-2009, 10:12 PM   #32
I'm a Mac
Re: Cutting Xps
XPS is expanded polystyrene, meaning it forever off gases, if and when you cover it you are fine, it's in the interm it can be an issue.
For a test take two pieces tuck them tight together and seal them up, drywall, plywood, whatever, wait a year, open it up and look at the shrinkage!!!
You should have used EPS, Expanded Polystyrene, it off gases during the fabrication process and shrinkage is less than 1%
Chris
Old 06-08-2009, 10:20 PM   #33
hughjazz's Avatar
Trade: carpenter
Re: Cutting Xps
I was thinking of using the table saw, but thought it might muck it up. You done this?
I've done it. Works fine
hughjazz is offline
Old 06-09-2009, 08:46 PM   #34
katoman's Avatar
Trade: carpenter
Re: Cutting Xps
Thanks guys, I've been using both my Fein with a scrapper blade in it and my table saw with a thincurf blade. Almost done.
Old 06-09-2009, 08:52 PM   #35
tripster's Avatar
Trade: Renovator
Re: Cutting Xps
I use my Stihl MS260 on xps. My helper doesn't like holding the sheets steady though.
tripster is offline
best blade for cutting laminate platinumLLC Flooring 12 05-07-2009 11:12 PM
Brick / Paver Cutting Question Tool Researcher Masonry 24 04-15-2009 12:25 PM
Metal cutting circular saws??? nwksremodeler Tools & Equipment 17 05-04-2008 07:29 PM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
