Cutting Hardiboard
Old 04-15-2008, 07:39 AM   #1
72chevy4x4's Avatar
Cutting Hardiboard
The shears I've found cut hardiplank, but I've got trim boards (1" thick) to cut. I've found two different blades-one is a low dust Hardi-Plank approved blade with 4 small teeth and the other is a continuous rim diamond tip, similar to a tile or masonary blade, which can be used for fiber cement, brick, etc.. Does the latter blade create a lot of dust? Any tips on using a mist to decrease the dust, without getting electrocuted
72chevy4x4 is offline
Old 04-15-2008, 10:26 PM   #2
Troutstreamguy's Avatar
Trade: Siding
Re: Cutting Hardiboard
Use the Hardie Blade, a hepa vac with your saw is the best
Troutstreamguy is offline
Old 04-16-2008, 09:22 PM   #3
BigoWhiteboy's Avatar
Trade: Siding, Trim
The best blade we have found to cut fiber cement siding and trim is the Hitachi Hardiblade, it will usually last us 5-8 houses depending on how tough you are on it. It does make some dust but not nearly as much as the continuous rim blades.
BigoWhiteboy is offline
Old 04-16-2008, 10:02 PM   #4
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Wetsaw
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 04-16-2008, 10:11 PM   #5
Kgmz's Avatar
I also have the Hitachi Hardi blade and it works fine, but you need to get the right saw for the blade.
A Makita 5057KB, and a shop vac.
Kgmz is offline
Old 04-17-2008, 06:31 PM   #6
rojigga's Avatar
Trade: Exterior Finishing
Originally Posted by PrecisionFloors View Post
Wetsaw
Ever see what Hardi's like when wet?
10" sliding compound mitre, 10" hardi blade, build a cutting table, cut siding and/or trim. Done.
No circular saws, no shears, just precision and ease of use over and over again.
rojigga is offline
Old 04-17-2008, 09:35 PM   #7
I might not be good,but I
valerko's Avatar
Trade: Framing and remodeling
Yeah,but what if you have to use a table saw?
I'm in a same boat.Doing same job.Hardi trim and siding.Started today.Bringing my shopvac tomorrow.Dust out of miter saw is not bad,but from a table saw,HUH.
valerko is offline
Old 04-18-2008, 10:42 AM   #8
rojigga's Avatar
What about a table saw? Use one! I don't use my nice Bosch table saw for it though as the dust breaks down saws relatively fast... I buy a cheapy Ryobi or the like (any saw you wouldn't dare bevel any rips with that are usually under $100) and put a 7 1/4" Hardi blade on it (you can use a 10" but way more expensive and hardie is thin enough that you don't need it).
The dust can be a prob but you could hook a large fan or whatever to blow the dust away from you.
rojigga is offline
Old 04-20-2008, 10:13 PM   #9
72chevy4x4's Avatar
I'm using an old 10" table saw with the hitachi blade and it cuts the 5/4 (1") thick hardi trim with ease!
Quickest, best way to fill prefinished hardiboard trim nailholes? pinesol Painting & Finish Work 8 07-31-2007 07:47 AM
A B C slot cutting for recompaction. MC Excavating Excavation & Site Work 17 03-13-2007 07:04 AM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
Cutting steel roofing-what do ya'll use IHI Roofing 9 07-02-2006 07:41 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
