Custom Air Hoses
Old 01-02-2009, 05:11 PM   #1
mpt1123's Avatar
Custom Air Hoses
Guys:
Anyone have any positive experiences with adding your own fittings to air hoses? I need to make some custom hoses for my shop. I've used the barbed type and I don't trust the hose clamps they require. I've seen references to push-to-connect fittings but I haven't used them. Any thoughts?
Thanks.
mpt1123 is offline
Old 01-02-2009, 05:25 PM   #2
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
Re: Custom Air Hoses
When I worked in a body shop we used to repair the hoses with a kit that crimped on the fittings just like the factory did.... it was something along these lines
http://airhosereels.com/hoserepairkit.html
TBFGhost is offline
Old 01-02-2009, 05:32 PM   #3
painter213's Avatar
Trade: Coatings consultant and Inspector
Send a message via AIM to painter213
Try Parker. There Push-Lock hoses are great. http://www.parker.com/portal/site/PARKER/
Benny Abbott
Abbott Consulting and Coating Inspections
E-Mail: babbott@abbottcoatinginspections.com
Phone: (205-717-0292)
painter213 is offline
Old 01-02-2009, 09:59 PM   #4
Al Smith
A W Smith's Avatar
you can shorten the flexeel hoses and reuse the fittings, I did this when i punctured a hose.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-03-2009, 12:36 AM   #5
Quiglag's Avatar
Trade: Finish Carpentry
Send a message via AIM to Quiglag
flexeel hoses also use compression fittings, so they are very easy to repair. http://www.toolbarn.com/product/coilhose/PRM0404SR/
Quiglag is offline
Old 01-03-2009, 05:36 AM   #6
nail bender
sore thumb's Avatar
Trade: Carpentry,interior millwork
barb type repair fittings work fine on poly hoses,on rubber thoughthe hose will develope a air bubble over time resuting in cutting a few inchs off and redoing the fittings
i have a hose thats about 30feet that started life at 50 feet due to this,i just use it as a leader hose
i hate it when i hit the wrong nail !!!
sore thumb is offline
Old 01-03-2009, 07:12 AM   #7
mpt1123's Avatar
Thanks, everyone, for the responses. I'm going to try Push-connect fittings from Poweraire.com to plumb the air system in the shop. They seem to have a good selection and prices are reasonable. I'm also planning to pick up one of those flexeel hoses that everyone is using for use on the job. Thanks again.
mpt1123 is offline
Custom Trim work in Raleigh Stockford Finish Carpentry 4 12-21-2008 10:16 PM
Another Post and Beam Custom from Lindal wallmaxx Framing 0 12-05-2008 03:26 AM
Custom Home Builder vs. Spec and Tract Builder renet General Discussion 4 11-16-2008 01:51 AM
Custom Garage and Custom Deck Builder Subs Wanted Illinois hendron24 Help Wanted or Looking For Work 0 10-22-2008 12:47 PM
