Compressor Won't Shut Off?
Old 04-08-2012, 01:24 PM   #1
catfish/carpent's Avatar
Trade: carpenter
Rewards Points: 158
i do not work with this compressor it's just a extra one i use around the garage, but anyways its a kobalt 10 gal 1.5hp older model about 6 years old, it will start up and continue to run into the 130's and never shut's down, it's got a digital set up with a 40/90 and a plus or minus , the prv doesn't blow or anything, im hearing maybe a pressure swith, i don't know , any help would be appreciated or direction
catfish/carpent is offline
Old 04-08-2012, 01:27 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: Compressor Won't Shut Off?
maybe got air in it
Tom Struble is offline
Old 04-08-2012, 01:37 PM   #3
Trade: carpenter
Rewards Points: 158
so does that make it a chinese air balloon?
Old 04-08-2012, 01:41 PM   #4
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
I thought the safety blows over 150....
world llc is offline
Old 04-08-2012, 02:08 PM   #5
Dirtywhiteboy's Avatar
Rewards Points: 7,876
I set my DeWalt to go up to 130-135 psi???
Dirtywhiteboy is offline
Old 04-08-2012, 02:56 PM   #6
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,402
I've got one that does the same thing. I'm thinking there's a high pressure shut off switch and I'm thinking it's gone bad. I've never worked on compressors so that's just a guess.
But my new makita compressor just arrived last week so I doubt I'll be fixing this one anytime soon.
J L is offline
Old 04-08-2012, 03:05 PM   #7
r4r&r's Avatar
Trade: Contractor
IMO it is probably a leak from the pump to the tank, most likely a fitting gave out, thus preventing it pressure up to trigger the pressure shutoff. I have had this happen to two so far. I am sure they could have been fixed but I didn't like them to begin with.
r4r&r is offline
The Following User Says Thank You to r4r&r For This Useful Post:
CanningCustom (04-08-2012)
Old 04-08-2012, 03:08 PM   #8
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
sounds to me like a leak in the feed line from pump to tank. If there is a small pin hole in it then the pump will not know when to shut off. I had something similar and didnt catch it in time blew the pump.
CanningCustom is offline
Old 04-08-2012, 04:18 PM   #9
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
Since it's building pressure over the specified cutoff, I'm putting my money on pressure switch.
Rustbucket is online now
Old 04-08-2012, 06:19 PM   #10
Resident Pain
oh i agree it could be that too, mine did the same thing and it was the feed line. But on electric compressor i would think you are closer to the prize.
Old 04-08-2012, 06:27 PM   #11
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 4,506
One of two things. The high pressure cut off switch is no longer functioning or the rings are worn enough that they can't reach the pressure the switch needs to shut it down.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 04-08-2012, 08:04 PM   #12
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
What pressure is is supposed to reach? Is it 125, 135, 150 psi etc etc? Like said above if the compress is running above the specified max psi your pressure switch has pooped out on you. Simple fix, I just got inside from replacing one of mine. YOU MAY NOT need to replace it. Most are adjustable, if you take the cover off the pressure switch there are normally instructions on the back of the cover on what to adjust. Its REALLY simple.
This is the one I just placed on mine.
http://www.ebay.com/itm/AIR-COMPRESS...ht_1145wt_1396
I have it adjusted for 105psi on and 145 psi off.
Most 125 max psi compressors have a the safety blow off at 135-140 psi. 135 psi compressors use 150 blow off and 150 psi compressors use 175 psi blow offs. Check your tank specs to see how high of MAX psi it is rated for . My 60 gallon is rated for 200 psi....I have a motor and compressor head off a 125 psi unit that is able to get up to 155 psi no problem. That extra PSI is great for working on cars when you need to give your impact gun that little extra boost of power.
However, if you compressor is supposed to get to a pressure higher then 130 yet won't build pressure over 130, you then have either a leak, worn piston rings (or piston if oil-less), or you may be getting a bad seal at the reed valves....it COULD also be a clogged air filter.
TBFGhost is offline
Old 04-08-2012, 08:11 PM   #13
Finish Carpenter
TBFGhost's Avatar
http://www.generalairproducts.com/do...ent-042705.pdf
That goes over a few types. The most common is the 2nd down.
TBFGhost is offline
Old 05-01-2012, 06:58 PM   #14
copeland5133873's Avatar
Trade: sub-contractor
I got one used that was never drained. high pressure line was clogged and head pressure valve was defective.
copeland5133873 is offline
Shut off valve brendanstl Plumbing 12 06-07-2011 09:33 AM
Hot Air Furnace will not shut off mrmike HVAC 7 02-23-2011 07:36 PM
Deadman won't shut off gran_national Sandblasting 27 12-28-2009 02:52 PM
main shut off valve woodlover Plumbing 10 12-23-2008 09:11 AM
F#@%ing shut off valves Philly Dude Plumbing 24 11-30-2008 07:48 AM
