Compressor Problem -- Regulator?
Old 07-19-2009, 01:06 PM   #1
Builder of Stuff
Young_Buck's Avatar
Send a message via AIM to Young_Buck
Hello Folks. I have a Porter Cable 4.3 gallon Air Compressor. It pumps up to 150PSI, and it's real sexy.
Recently, I had it looked over by a friend's dad. Ever since, it won't properly power my guns. It still charges up to 150PSI on the tank, and the regulator claims to be presenting 120PSI. The guns, however, act as though they are receiving pressure that is too low for them to operate properly.
What's happening (with two identical Senco Framers (FramePro601) and a Senco Roofer) is one nail will fire and sink 1/2 to 3/4 of the way into pine. If I have the regulator at 120, the piston will usually recoil completely, and the gun will load the next nail. Every 6-7 nails, I have to open the gun, push the piston back, and advance the nail manually.
If I set the regulator around 100, the piston will not recoil, and the nail can not advance.
The guy who worked on my compressor (He did it for free) did some playing with the regulator. It was leaking, and he said he put new thread tape on it. I am hoping he just over-tightened something in there and I can fix it myself without much trouble.
Does anyone have any advice about fiddling with regulators? I've looked around online for a schematic of the compressor -- or even just a generic regulator schematic -- and can't seem to find one.
Thanks in advance.
Young_Buck is offline
Old 07-19-2009, 01:12 PM   #2
Mickey
mickey69125's Avatar
Trade: residential remodeling
Re: Compressor Problem -- Regulator?
It sounds as though you have pressure but not the volume of air for the guns to work properly. Take the regulator off and see if he didn't happen to get too much thread tape and it's plugging something. I doubt if you can fix the regulator so I wouldn't waste time looking for a schematic. You can buy them at a hardware store and they're not too expensive.
I always learn more by listening that I do by talking.
mickey69125 is offline
Old 07-19-2009, 01:57 PM   #3
Builder of Stuff
Young_Buck's Avatar
Thanks Mickey, that's one thing I'll definitely check.
I should note that the compressor was running these guys properly, before it was serviced.
Old 07-19-2009, 03:10 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Pressure guage on end of hose, see what it is.
WarnerConstInc. is online now
Old 07-19-2009, 03:16 PM   #5
LRG WoodCrafting
Leo G's Avatar
Easiest way to check for lack of volume is to put a pressure valve inline with an air nozzle. Activate the nozzle and watch the guage, let the nozzle close and the pressure should return to max instantly. If it builds then you have a restriction somewhere. Could be the tape or the regulator itself.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 07-19-2009, 03:28 PM   #6
strat hd
strathd's Avatar
Trade: framing contractor , remodeler , GC occasionally
Hey Youngbuck this is a little off topic but how do you find a compressor sexy ??????
strathd is offline
Old 07-19-2009, 03:32 PM   #7
LRG WoodCrafting
Leo G's Avatar
Maybe a vacuum cleaner......
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-19-2009, 09:48 PM   #8
Railman's Avatar
Trade: Railing
The only way a compressor could be sexy was if it had a blow gun connected to it.
Anyway, I'd first chaeck to make sure the regulator didn't get reversed so as to have the input air going in the output side. It's pretty easy to do with some, & can act exactly like your describing. The other thing has been mentioned...teflon tape clogging air ports.
My bet is a reversed regulator.
Joe
Railman is offline
Old 07-20-2009, 09:50 AM   #9
BCConstruction's Avatar
Trade: Construction
You shouldnt have a problem with air volume as a 50ft standard hose should have more than enough volume of air to power your guns so it must be a pressure problem. Go get ya self a test gauge to plu into the end of your air line and test for correct pressure. It sounds like he has not put the valve back together properly.
BCConstruction is online now
Old 07-20-2009, 10:01 AM   #10
Inner10's Avatar
Trade: Control Systems
What you never sat on a compresor before?
Inner10 is online now
Old 07-20-2009, 05:04 PM   #11
strat hd
strathd's Avatar
Uhhhhhhhhhhh............ NO. Chicks like my bike though. Maybe after riding they can ride my compressor for awhile. All systems go.
strathd is offline
Old 07-28-2009, 02:02 PM   #12
jamuz's Avatar
Trade: Mechanical Maintenance
regulators are most often nothing more than a diaphragm and a spring. The diaphragm will usually be the culprit as they like to deform or tear casueing leaking.
The problem sounds to me like Air Volume and I believe you should not only look at the regulater, as teflon tape will not seal a diaphram, but swap your air hose out with one that you know works. Sometimes the insides of the hose can tear and colaspe on itself, causeing little to no air volume. Seen it many times on Hydraulic hoses as well.
jamuz is offline
Old 07-28-2009, 04:13 PM   #13
The Deck Guy
Greg Di's Avatar
Not for nothing, PC compressors are throw aways at this point. New ones are so cheap. Just go buy one and forget it.
Greg Di is online now
Old 07-28-2009, 04:18 PM   #14
LRG WoodCrafting
Leo G's Avatar
3 post wonder. It would be nice to find out what happened after we spent so much time helping him....
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-29-2009, 02:06 AM   #15
Builder of Stuff
Young_Buck's Avatar
Hey now, I'm no 3 post wonder! I've been busy.
I haven't dealt with the compressor yet.
I've gotten enough information out of you guys that I'm confident I'll be able to fix the problem. You're awesome, I thank you, and when I do fix it I will let you know what the problem was, if just to sate Leo's curiosity.
Old 07-29-2009, 07:55 AM   #16
LRG WoodCrafting
Leo G's Avatar
Just making sure you were listening.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-14-2009, 02:20 PM   #17
Builder of Stuff
Young_Buck's Avatar
Tried to fix the damned thing. Took the regulator out, eye-balled it (as if that did anything) couldn't figure out any glaring problems. Put it back together. same issue. Didn't want to deal with it anymore. Took it to a tool repair place. Haven't heard back yet. I'll let you guys know the answer to the puzzle as soon as I know! Also, whether or not it was cheaper to fix the damned thing, instead of replacing it.
Old 07-16-2010, 04:28 PM   #18
Builder of Stuff
Young_Buck's Avatar
End result: Bad regulator gauge. New gauge and 1/2 an hour of labor ended up being about $60.
Old 07-16-2010, 06:34 PM   #19
katoman's Avatar
Trade: carpenter
Glad to hear you got 'er fixed.
Yesterday my small cambell hausfeld quit running. Just won't turn on. I need it on the job, so on the way home I picked up a new one from Canadian Tire for $60.
I'm guessing it's the switch, if I ever get time I'll tinker with it. But they are almost a disposable item.
katoman is offline
Old 07-16-2010, 08:25 PM   #20
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
LOL...I was gonna guess this, I just found this thread.
TBFGhost is online now
Repair Pressure Regulator mrmike Plumbing 3 01-20-2009 11:29 AM
draft regulator mrmike HVAC 3 01-18-2009 10:40 AM
What is this? Pressure Regulator? jicoll2000 Plumbing 11 12-18-2007 11:09 PM
water hammer/gas hammer? smellslike$tome Plumbing 10 11-09-2007 08:54 PM
Squeaky regulator Leo G HVAC 0 04-05-2006 01:36 PM
