Cleaning Saw Blades
Old 06-25-2005, 08:39 PM   #1
GMW's Avatar
Trade: Deck builder & Handyman
Cleaning Saw Blades
Helo all. I am a deck builder in upstate NY.Very hot right now. I was wondering what to use to clean circular saw blades after cutting several decks worth of PT lumber. Is it even worth the time or do I just toss them and buy new ones? The teeth don't get chipped or anything, just gummed up with sap. If anyone has ideas or thoughts I would love to hear them. Thanks in advance.
GMW is offline
Old 06-25-2005, 08:59 PM   #2
Tom R's Avatar
Re: Cleaning Saw Blades
I use a spray-can product, - - I think it's called 'Gum-Out'. Works pretty good. I had bought a case of it on sale before Woodworkers Warehouse closed down. I'm sure it can be found over the net.
http://www.tr-built.com
Tom R is offline
Old 06-25-2005, 09:00 PM   #3
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Hey neighbor. I have always heard oven cleaner works well. Never tried it though.
IMO, for the low cost (<$10) of a decent 7.25" framing blade it would not be terrible to just toss it after each job if it's that bad. I assume this much can be built into the price of the job.
Speedy Petey is offline
Old 06-25-2005, 09:08 PM   #4
Tom R's Avatar
I forgot about that, Speedy, - - but you're right, - - I've heard about the oven cleaner for it for years, - - supposed to work really good, - - nasty stuff though, huh?
I kind of agree with you in one sense, - - 'if' it's a cheap blade, - - but sometimes it's good to clean it as you're using it. I'm usually using 40 tooth blades in my sidewinder, - - they cost more, - - but get better cuts and more bang for the buck over-all.
Tom R is offline
Old 06-25-2005, 09:12 PM   #5
GMW's Avatar
Wow. thanks for the quick replys. I guess I should try and silicone them as I go. maybe i will try that on my next blade.
GMW is offline
Old 06-26-2005, 12:14 AM   #6
bergenbldr's Avatar
Trade: builder remodelor
I use marathon "green" blades almost exclusively. They have a coating that reduces friction/gumming of blades,tool dist. or lumberyard may have carry these. Have not seen these at the local big box.
bergenbldr is offline
Old 06-26-2005, 04:32 PM   #7
Tom R's Avatar
Hmmm, - - not familiar with them, - - but definitely sounds worth checkin' into.
Tom R is offline
Old 06-26-2005, 05:00 PM   #8
mdshunk's Avatar
At the risk of sounding ignorant (too late maybe), I have to ask. Does the buildup occurs on circular saw blades when sawing certain types and species of wood affect the performance of the saw? or is it just a housekeeping issue?
mdshunk is offline
Old 06-26-2005, 05:33 PM   #9
Tom R's Avatar
Yes, it affects the performance exponentially, - - when the blade 'gums', - - it effectively dulls, - - meaning less 'chiseling' action in the cutting process, - - and therefore more 'friction' action, - - leading to more heat, - - causing blade expansion, - - compounded by 'wobble', - - then even more friction, - - causing a 'burning' action, - - leading to more dulling, - - etc., etc.
Tom R is offline
Old 06-26-2005, 05:42 PM   #10
GMW's Avatar
Talking
I really started a dicussion here. I just don't like waste and figured with a little work I could save the blades. The teeth really aren't shot( not chipped or dull) just gummed up. Maybe I should ask on the deck forum and see what other guys cutting PT do. Probably not worry as much as me
GMW is offline
Old 06-26-2005, 07:11 PM   #11
PPro's Avatar
Gasoline works wonders. Just let it sit for a few hours or overnight and scrub it off the next day.
PPro is offline
Old 06-26-2005, 09:10 PM   #12
Teetorbilt's Avatar
Dad always had a small pail of kerosene or mineral spirts that we put the blades in overnight.
I still build in the cost of new blades to a job. You can resurrect a few old ones and lose some brand new ones.
Albert Einstein
Teetorbilt is offline
Old 06-26-2005, 09:50 PM   #13
plumguy's Avatar
Trade: plumbing and heating
Have you ever tried "Goof Off" they sell it at HD. I've never cleaned saw blades with it, but, everything else I have used it for it's been great. And it's not harsh on the lungs or skin.
plumguy is offline
Old 06-29-2005, 02:42 AM   #14
Deck Designer/Builder
DecksEtc's Avatar
I've seen spray cans of "saw blade cleaners" in big box stores up here - it may be the one Tom is talking about, can't remember.
Also, one thing I always do is have seperate blades for the PT and cedar and switch them after the framing is done.
DecksEtc is offline
