Cleaning Foam Gun
Old 02-07-2010, 11:17 AM   #1
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Cleaning Foam Gun
Well my helper forgot to close my Hilti foam gun. It's plugged. Any tips on how to clean this out?
I soaked it in cleaner for a couple of days and no luck. I'm reluctant to try and take it apart. But at $250 I'm not buying another one.
I might try laquer thinner, but I think that will destroy the plastic handle.
Any help will be appreciated.
katoman is offline
Old 02-07-2010, 11:20 AM   #2
genecarp's Avatar
Re: Cleaning Foam Gun
Xylene will def eat the foam, but the plastic will also take a hit, If you try Xylene, make it a surgical procedure, GMOD.
genecarp is offline
The Following 2 Users Say Thank You to genecarp For This Useful Post:
katoman (02-07-2010), tcleve4911 (02-07-2010)
Old 02-07-2010, 11:31 AM   #3
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
I've taken mine apart before and (like Gene says) surgically cleaned all the parts and then put it back together.
That saved the plastic..................
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 02-07-2010, 11:39 AM   #4
katoman's Avatar
Trade: carpenter
I think yes, I will have to take it apart. Where can I buy Xlene? Hardware store? HD ?
katoman is offline
Old 02-07-2010, 12:06 PM   #5
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Kato
look in the bottom where the gun attaches to the can,look all the way down the hole,take a wd40 straw and poke it in there
there is a spring loaded ball there,make sure it's free,you may have to push firmly
hilti gun is the best
Tom Struble is offline
Old 02-07-2010, 12:41 PM   #6
Shawn Prentice's Avatar
Trade: carpenter/remodeler
Rewards Points: 250
You can get xylene at the paint store, box stores.
Shawn Prentice is offline
Old 02-07-2010, 12:56 PM   #7
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
try lacquer thinner
jlhaslip is offline
Old 02-07-2010, 10:48 PM   #8
parts's Avatar
Trade: Insulation contractor
Rewards Points: 150
For the price Hilti guns are overrated. I have never successfully cleaned a severely clogged plastic gun as they don't come apart as easy and the solvent softens the parts. Above the poster mentioned the ball with the spring if that doesn't move get a new all metal one at an insulation supply house. They run 50 to about 100 dollars
parts is offline
Old 02-07-2010, 10:55 PM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,478
Unless the foam is tactile and you can blast it out with a can of acetone foam cleaner you are pretty screwed.
Are we talking about the same gun here because they sell for 90 bucks (Canadian) from Hilti or come free with 2X 12 packs of foam. Only 40$ more then a GreatStuff gun.
Inner10 is online now
Old 02-08-2010, 01:42 PM   #10
rustyjames's Avatar
Rewards Points: 1,548
Knowing the stuff Hilti makes I'd think there has to be a way to clean it. No doubt you'd probably have to completely disassemble it and use lacquer thinner, xylene or acetone. Maybe spray carb cleaner might also do it.
rustyjames is online now
Old 02-08-2010, 02:14 PM   #11
katoman's Avatar
Trade: carpenter
Picked up some laquer thinner today, I shall report in if I'm successfull.
Or I'll be buying a new gun
katoman is offline
Old 02-08-2010, 02:35 PM   #12
rustyjames's Avatar
Is your gun the DS-1? That's what I have, picked it up on ebay with 2 cans of foam for about 40.00. I haven't used it in over a year. They say to leave a can on with the valve closed so that's what I did. I was always wondering about long term storage with them.
Old 02-08-2010, 03:24 PM   #13
Inner10's Avatar
I thought for long-term storage you should pop on the acetone can and purge it. I think if you leave a partial can on closed for too long it cures and your gun is toast.
Old 02-08-2010, 03:52 PM   #14
katoman's Avatar
Trade: carpenter
Yaaa!! It wasn't plugged. I had a can of cleaner on it that wouldn't spray.
I assumed it was plugged. What happened was the top of the cleaner can was actually stuck and broken in the foam gun.
Picked out the broken piece, put a new can of cleaner on it, and bingo!
I love it when something like that happens and I am saved buying a new gun.
Now ................ what can I foam
katoman is offline
Old 02-08-2010, 03:55 PM   #15
katoman's Avatar
Trade: carpenter
You are correct, always do that.
The broken cleaner thing is a new one for me.
katoman is offline
Old 02-08-2010, 04:42 PM   #16
parts's Avatar
Rewards Points: 150
The propellant in the cans gets out though rough handling or incorrect usage then you have a full can that won't spray
parts is offline
The Following User Says Thank You to parts For This Useful Post:
katoman (02-08-2010)
Old 02-08-2010, 09:05 PM   #17
RMcBride's Avatar
Rewards Points: 25
We have a great stuff gun and the Dow rep who demoed it for us clogged it up. I had great success with their cleaning spray even on a clogged gun, mixed with some lengths of copper wire to fish the softened goo out as it loosened up. Definitely takes patience though. I know a few people who use acetone instead of the expensive cleaner cans when they need to break down a gun and it seems to work well enough.
Richard McBride
Rehab Construction Supervisor
Habitat for Humanity of Metro Louisville
RMcBride is offline
Old 02-08-2010, 09:19 PM   #18
Trade: siding
Rewards Points: 20
i never had much luck with the great stuff guns
the hilti guns can sit with a used can on it for quite some time
i think they use a teflon coating on them not sure
Old 02-08-2010, 09:29 PM   #19
RMcBride's Avatar
Rewards Points: 25
I know, but they give us the stuff for free...
Richard McBride
RMcBride is offline
Old 02-08-2010, 09:52 PM   #20
Inner10's Avatar
Hmm, having the can break off is a new one on me too!
McBride, Hilti "gives" them away for free too.......
...with a purchase of 2 cases totaling over 400 bucks.
Tyvek under 1/4in foam for Vinyl siding? PittTrack Windows, Siding and Doors 66 06-22-2012 12:56 PM
Roof Cleaning Pictures Wanted !! Roof Cleaning Pressure Washing 5 09-07-2010 08:24 AM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 01:39 PM
foam spray gun vs canned foam AustinDB Tools & Equipment 4 12-03-2008 07:30 AM
Cleaning Open Cell Spray Foam cambiumco Insulation 4 11-22-2008 08:23 PM
