Can Pleated Shop - Vac Filters Be Washed ?
Old 09-01-2013, 07:41 AM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,984
Just curios to know if the cylinder type shop vac filters can be effectively cleaned - extending their life ? I'm thinking running water through them would clog up the media ?
I use the near HEPA filter 98% - 99% ($20) with a collection bag inside the canister. Maybe with the economy picking up I can get a Fein or Festool vac. But until then I need to make due with what I have.
We Fix Houses is offline
Old 09-01-2013, 07:48 AM   #2
tjbnwi's Avatar
Rewards Points: 3,478
Re: Can Pleated Shop - Vac Filters Be Washed ?
This is the brand filter I used in my shop vacs. They are washable and worked very well. I don't think the paper ones are washable, that is why I went to the Clean Stream filters.
http://www.cleanstream.com
tjbnwi is offline
TNTSERVICES (09-03-2013)
Old 09-01-2013, 07:59 AM   #3
That's a neat vid on the clean stream. That's the ticket.
Tom, you know everything !
Old 09-01-2013, 08:34 AM   #4
tjbnwi's Avatar
I didn't know my wife would be upset when I put them in the dishwasher to clean them.
Really I did, just didn't care, she'll got over it.
tjbnwi is offline
Old 09-01-2013, 08:10 PM   #5
Sisyphus's Avatar
Trade: Renovation and property management
Rewards Points: 881
I blow the dust off my filters either with a compressor or with another shop vac. When I use the other shop vac I just blow through the inside of the dirty filter (i.e. opposite from the way the filter got dirty).
When I use the compressor I blow along the outside almost parallel to the surface. The compressor pressure is higher and may damage the filter if you blow through it. BTDT
Obviously blowing it clean makes a disgusting cloud of dust, but you don't get a bunch of sludge to deal with and if you do it frequently it's not too bad. (Or get one of your henchmen to do it. LOL)
Sisyphus is offline
The Following User Says Thank You to Sisyphus For This Useful Post:
Old 09-01-2013, 08:13 PM   #6
Sisyphus's Avatar
Rewards Points: 881
Of course you also have to consider what materials you are blowing into the air or dissolving into the water. I'm primarily dealing with sawdust.
Sisyphus is offline
m1911 (09-02-2013)
Old 09-01-2013, 11:07 PM   #7
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I've washed the blue ones several times.
m1911 is offline
Old 09-02-2013, 07:10 PM   #8
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 7,210
What they said.
Blow it out with a compressor or suck it out with another vac.
If you're using the collection bags you shouldn't be getting all that much crap into the filter as it is though, especially with just sawdust.
I find PVC and drywall dust is what really mucks things up.
Easy Gibson is offline
Old 09-02-2013, 08:05 PM   #9
Patrick's Avatar
Rewards Points: 2,364
Glad i saw this post ive been cleaning my barn the last few days and the vacs been sluggish i blew it out with the compressor today the two times i emptied it and it worked so much better
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 09-02-2013, 09:30 PM   #10
m1911's Avatar
I always use bags, just don't pick up set!
m1911 is offline
Old 09-02-2013, 09:39 PM   #11
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,510
I tried hosing off a rigid filter once and the drywall dust just turned it into a rock hard statue. Use another vac to suck the filter clean instead.
The past three years or so I've only been using bags in my shopvac and I can get well over a year with the same filter.
Inner10 is offline
Old 09-02-2013, 10:22 PM   #12
txgencon's Avatar
Rewards Points: 430
I've always just hosed them off with a hose end sprayer. I really don't know if the filtration changed but, if it did, I didn't notice. This includes pleated paper filters and whatever material the Hepa models are made of.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 09-02-2013, 10:25 PM   #13
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 900
I will just tap it on the side of the dumpster to knock off the loose stuff. We also use bags in conjunction with the pleated filter. Only time it gets real gummed ups when the bag tears and I don't catch it.
overanalyze is offline
Old 09-02-2013, 11:06 PM   #14
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,016
I swear by the cleanstream filters for standard shop type vacs.
I have 2 Clean Stream filters that I rotate through my craftsman vac.
I just knock the filters out in the trash, then hose em off.
While one is on the shelf drying, I use the other.
Going on 4? yrs now with those 2 filters.
Aaron Berk is offline
The Following User Says Thank You to Aaron Berk For This Useful Post:
FlyFishRI (09-03-2013)
Old 09-03-2013, 06:27 PM   #15
Greg from K/W's Avatar
Rewards Points: 530
I have only ever used the blue ridgid filters in my shop vac. Sometimes I blow em off other times I wash them with the garden hose. I very rarely have to buy a new one. I only use the ones for fine dust. Air works sometimes but you need to wash them to get them really clean.
I open up the pleats with my one have on the inside and run the hose under pressure on the outside. Has worked well for me.
Greg from K/W is offline
Old 09-03-2013, 07:45 PM   #16
Tom M's Avatar
Rewards Points: 6,462
I wash those blue rigid ones all the time. I always use a vac bag for drywall dustbut one of these days Im going to get that dust deputy thing and be done with it.
Tom M is offline
Old 09-03-2013, 07:58 PM   #17
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,654
Spray them off with an air hose. I use them in conjunction with bags, makes them last a LOT longer!
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
business plan for a small cabinet shop NEED INPUT finakat General Discussion 4 08-31-2012 07:40 PM
Efficient guy working with his jigs, in the shop UpNorth Finish Carpentry 11 08-18-2012 10:43 AM
Shop Facelift cranbrook2 Carpentry Picture Post 8 08-14-2012 08:36 PM
My new shop . deadjed General Discussion 17 12-30-2010 07:21 PM
Leasing a shop CatAlii Business 7 08-03-2008 11:29 PM
