Cabinet Lift
Old 06-24-2010, 07:04 PM   #1
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Cabinet Lift
HI guys,
I saw a picture a while back where someone had a small cabinet lift/jack that sat on the base cabinets usually on a slab of plywood and that helped install the uppers for odd or heavy wall units. I can't seem to find any cabinet jacks like that and only see the ones that are larger and sit on the floor.
Anyone know what I'm looking for?
ApgarNJ is offline
Old 06-24-2010, 07:16 PM   #2
Working
Cole82's Avatar
Rewards Points: 2,276
Re: Cabinet Lift
The Gillift cabinet lifter.
The boss of awesome
Cole82 is offline
The Following User Says Thank You to Cole82 For This Useful Post:
ApgarNJ (06-24-2010)
Old 06-24-2010, 07:58 PM   #3
Dan
ApgarNJ's Avatar
Re: Cabinet Lift
that would work, the one I saw looked more like a box. maybe it was a home made job because it looked nothing like that. I just can't remember where I saw it.
ApgarNJ is offline
Old 06-30-2010, 03:06 AM   #4
James Powell's Avatar
Trade: Mill Work
Re: Cabinet Lift
I used a door hanging tool to do this job,you can leval this tool it in any plane.I just placed it on top of the floor cabnets,then
I made a wooden bracket for it and clamped it in the tool.I placed wall cabnets on the bracket,and hung the cabnets
I have the details is you think it is of any use
James Powell
James Powell is offline
The Following User Says Thank You to James Powell For This Useful Post:
ApgarNJ (06-30-2010)
Old 06-30-2010, 05:30 AM   #5
jhammer7's Avatar
Rewards Points: 286
Re: Cabinet Lift
Third Hand, was a brand, and I think Fast Cap has something.
jhammer7 is offline
Old 06-30-2010, 05:42 AM   #6
smartcarpie's Avatar
Trade: Finish/Restoration Carpenter
Rewards Points: 75
Re: Cabinet Lift
Fastcap makes a short version of their Third Hand called the Upper Hand. I have a pair- they're sized to support uppers when set on base cabs and have the big 5x5 pads on them.
I know a carpenter who did a lot of installs who swears by building a pair of square boxes to the proper dimension that sit on the base cabs. If the base has been set level, then the boxes will too, just gang the uppers and set them on top and you should be awfully close. A shim or two between box top and cabinet can make any final adjustments. It seems like once in position it would be super stable as well.
The couple of times I have used the fastcaps for this I have felt a bit uneasy about the lack of stability, didn't want to take my hands off for a minute.
smartcarpie is offline
Old 06-30-2010, 06:03 AM   #7
Trade: Mill Work
Re: Cabinet Lift
Here is a web site in the Uk that stockes what you are looking for:UK.Cabinetparts.com
Old 06-30-2010, 06:16 AM   #8
Trade: Mill Work
Re: Cabinet Lift
I agree with what you are saying about Fast Cap They are only ajustable props The wooden box would do a better job
Old 06-30-2010, 09:05 AM   #9
Re: Cabinet Lift
Yeah, we talked about making
boxes to support uppers.
Plan it right and you can get
3 different hanging heights
in one box, depending on which
way you turn it.
neolitic is offline
Old 06-30-2010, 09:12 AM   #10
Project Manager HFH..
JumboJack's Avatar
Rewards Points: 2,004
Re: Cabinet Lift
A pair of these work real nice.
http://www.amazon.com/FastCap-Little...7907105&sr=1-6
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 06-30-2010, 10:05 AM   #11
Giving it my best
RS Sam's Avatar
Trade: Cabinet Maker and Residential Remodeler
Rewards Points: 512
Re: Cabinet Lift
way you turn it.
Prior to getting my full size - floor model -Gil Lift , this was my system. Worked well for establishing the height of the cabinets and allowed a pretty calm install as I could tweak left or right and shim a little with complete confidence that the upper cabs were safe while I worked. Problem was I still had to get the cabinets on to the boxes. I like ganging as many uppers as is practical on the floor before lifting them to the wall. This just doesn't work with the box on base cabinet system. I can't imagine it would work with the lift shown in the photo or with third hands either. Certainly not if you are working alone. The full size Gil Lift is a tremendous tool. Very very high on my list of best tool purchases. I work mostly alone and the Gil Lift is my very best installer helper. Makes calm & easy, safe & accurate work of installing uppers & rolling around other heavy pieces into position. After the uppers are installed I use the lift as a movable & height appropriate table for holding tools or hardware while I set shelves & adjust upper doors etc. Lots of other unexpected uses too. I like it!
RS Sam is offline
Old 06-30-2010, 10:08 AM   #12
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Cabinet Lift
We use the full lift that you can see in the picture on the right of the guy, and just install uppers first. This is the way I was always taught, and it saves a lot of wear and tear on the lowers.
Mike Finley is offline
Old 06-30-2010, 10:20 AM   #13
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
Re: Cabinet Lift
Mike - just curious - does this delay you getting your countertops templated and installed - thereby holding up completion?
CookeCarpentry is offline
Old 06-30-2010, 10:33 AM   #14
Re: Cabinet Lift
That's an interesting point.
I suppose it could, however since we don't do a lot of kitchens, just for past clients that beg, and combine that with our counter top guys turn around stuff so freak'n fast it's ridiculous, it hasn't been an issue, but I could see how that could delay templating a day or two, so it could be an issue for someone.
Old 06-30-2010, 10:41 AM   #15
Project Manager
Re: Cabinet Lift
That's the only reason I always set base cabinets first. Get the guys in to template asap. Work on the uppers, appliances, trim, etc. Countertop in, backsplash, done.
I find it very advantageous when it is a complex layout, built up crown, etc, etc.
And I get a quick turn around on stone tops, but don't like to leave it to chance.
Old 06-30-2010, 11:09 AM   #16
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 166
Re: Cabinet Lift
Salvage from an Ikea kitchen install provided some adjustable height legs for an install device for uppers.
jlhaslip is offline
The Following User Says Thank You to jlhaslip For This Useful Post:
ApgarNJ (07-01-2010)
Old 07-08-2010, 06:48 PM   #17
R. Manning Jr. Millworks
Roger Manning's Avatar
Trade: Millworks Contractor
Rewards Points: 168
Re: Cabinet Lift
We use T-Jaks I like them better than the fast-cap ones.
http://www.amazon.com/T-Jak-MB-101-M...8632376&sr=1-3
With the T-Jaks you can fine tune the up and down, with the fast cap one if you go to high and try to come down a little they come down all the way.
Roger Manning is offline
The Following User Says Thank You to Roger Manning For This Useful Post:
ApgarNJ (07-08-2010)
Old 07-08-2010, 07:09 PM   #18
katoman's Avatar
Trade: carpenter
Re: Cabinet Lift
Two plywood boxes - covered with thin carpet - measuring 15" x 16" x 18"
This (as mentioned before) gives three different install heights, and no marring of the counters.
I will also sometimes use 2 sticks, made of 2x3 cut about 4" longer than the bottom edge of the upper. Attach another small piece of 2x3 near the top. Cover in carpet.
This is jammed under the front edge of the cabinet, and will hold it in place while you fasten it.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
Old 07-09-2010, 10:49 AM   #19
Re: Cabinet Lift
http://www.thisiscarpentry.com/2010/...cabinet-jacks/
Anybody else see this?
Pretty cool if you are doing a lot
of installs.
neolitic is offline
Old 07-18-2010, 07:03 PM   #20
11678's Avatar
Rewards Points: 250
Re: Cabinet Lift
Check out the "ezspreadnlift" jack. Adjustable table makes it better than the Gilift. Had mine for about 5 years now.
11678 is offline
Another crazy cabinet.. Leo G Finish Carpentry 39 03-18-2010 06:58 PM
Cabinet for built-in oven mattsk8 Finish Carpentry 10 03-15-2010 11:14 PM
Cabinet Software Bergstrom Finish Carpentry 58 01-10-2010 10:11 PM
Fun Cabinet.. Leo G Finish Carpentry 8 01-10-2010 12:01 AM
My new cabinet lift cabinet runner Tools & Equipment 0 08-20-2009 08:37 PM
