Brad Vs. Pin Nailer
Old 06-06-2006, 09:58 PM   #1
gtdail's Avatar
Trade: Lisc. General Contractor
Brad Vs. Pin Nailer
I have a 18ga brad nailer and have been looking at a pinner after someone told me you would not have to putty your holes on stained shoe moulding using a pinner. Any truth to this what else are you guys using pinners with 23ga headless pins. Thanks.
gtdail is offline
Old 06-07-2006, 08:22 AM   #2
SAGE
sage's Avatar
Trade: Remodeler and Finish Carpenter
Re: Brad Vs. Pin Nailer
I would not use a pinner on shoe moulding, I don't think they will hold well enough. I use it mainly (at the job site) to stitch glued joints on prefinished stained materials where the only option is to nail in visible areas. I still make one pass over the holes, if I can find them, with a fill stick. If you don't, and you look at it from the exact perfect angle, at the right time of day with the sun to your back, you will see the pin, a tiny shiny dot. Worth every penny in my opinion.
-Lead from the front, or dont lead at all-
sage is offline
Old 06-08-2006, 04:48 PM   #3
Custom woodwork King
jgmillzy00's Avatar
Trade: finish carpentry
I own both, a brad and a pin. A pin gun is not a substitute for the brad gun. Your not going to get the long lasting tight hold with the pin or any support. I do very fine work with alot of small pieces on mantles, cabinets and what ever else. I use it mainly for miters with glue. And when I have to use it for anything else I use plenty of glue. But to answer your question it depends what kind of finish is going to be used. Latex will cover it right up. Conversion varnish you might have to use a little spackle. And for stain, if you use a light stain you'll see a little dark dot. With a dark stain your golden. Depending on what tpye of wood your using try to hit the grains. And dont push the pin gun to hard, lighty hold it on the wood. Reason being there is no safety or rubber on the end so you have nothing to protect the wood you can easily dent your wood.
jgmillzy00 is offline
Old 06-09-2006, 11:21 AM   #4
IHI's Avatar
Nother of the same opinion. Pins work great for holding miters until glue dries, and thin detail moldings-use it alot on dental moldings-but in no way sufficent for any type of casing/base applications.
Your 18ga brad is about right since it leaves a very small hole behind once you nail it, my paslode is a 16ga and since I bought the cordless compressor and 18ga brad gun I rarely use the paslode anymore for finish work since it leaves a big hole behind that is easily detectable even with color matched putty..the 18ga blends in quite well on grainey lumber
IHI is offline
Old 02-19-2008, 01:03 PM   #5
Remodeler Extraordinare
A.W.Davis's Avatar
The micropinner works well to pin your miters after you glue them.
I also nail all of my moulding with the micropinner first just in case I have to adjust something for some reason then I go back once finished and nail my cabinet crown off with the brad nailer accordingly!
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 02-19-2008, 01:45 PM   #6
AtlanticWBConst's Avatar
As already stated, a pin nailer works for light molding. Especially useful for holding corners that are glued, Narrow or light trim work on furniture, built-ins, cabinet molding, etc.
It is not a replacement for a brad nailer.
- Build Well -
AtlanticWBConst is offline
Old 02-19-2008, 02:16 PM   #7
The Deck Guy
Greg Di's Avatar
A pinner without a safety is also really good at getting your helpers to keep moving fast. A couple of shots in the ass from 10 feet away and they get the "point" real fast!
Greg Di is offline
Old 02-19-2008, 09:24 PM   #8
orson's Avatar
Trade: Kitchen & Bath
I second Greg's motion, I like to shoot unruly electricians with them.
One additional piece of info...Woodcraft sells a 21 guague pinner that you can get pins with or without heads for.
I've experimented with using 23 guage pinner to put hardwood crown on cabinets with no other fastener other than going back and running a bead of adhesive on the backside of the crown where it meets the cabinet. Method works out well although going back to run the adhesive is arguably as much trouble as filling holes of 18 guage nails.
Once you own a 23 guage pinner you will never do without one.
www.rubycon.us
Ruby Construction LLC
Lancaster Kitchen Remodeling
Lancaster Bathroom Remodeling
orson is offline
Old 02-19-2008, 10:18 PM   #9
A.W.Davis's Avatar
Yes....I concur!
Old 02-20-2008, 07:02 AM   #10
Trimcat's Avatar
Trade: Trim contractor
Send a message via MSN to Trimcat
I HIGHLY recommend a Grex gun. Everything said here is true but believe me, you will use this thing all the time if you trim, build or hang cabinets, mantles, stairs etc. It's my favorite air tool.
Trimcat is offline
Old 02-20-2008, 07:46 AM   #11
amanandhisvan's Avatar
Trade: Home Improvements
Send a message via Yahoo to amanandhisvan
Porter Cable came out with a 3 gun set which includes a Pin nailer (23 gauge), Brader, crown stapler and pancake compressor. I think the whole set is 199.00 I bought the pin nailer separate for a 100 bucks out of the set. I love that little nailer, great for moulding returns etc. like u guys have said. I thought it was a great deal for 100 bucks. My buddy bought his pinner from some specialty shop for $450!!!
amanandhisvan is offline
Old 03-09-2008, 03:44 PM   #12
Quiglag's Avatar
Trade: Finish Carpentry
Send a message via AIM to Quiglag
Throw some glue behind it, and you can use a 23ga, It would still probably save you the time of filling the nail holes.
Quiglag is offline
Old 03-24-2008, 08:38 PM   #13
y0manda's Avatar
I have a Grex and Porter Cable Pin nailer and I like the way the porter cable feels much better. I paid twice as much for the grex and It never gets used.
y0manda is offline
Old 03-24-2008, 10:07 PM   #14
Quiglag's Avatar
Originally Posted by y0manda View Post
... I paid twice as much for the grex and It never gets used.
Then sell it to me.
Quiglag is offline
Old 04-06-2008, 04:02 AM   #15
kreg mcmahon's Avatar
Trade: custom carpentry
I have both and they both have different uses. the pinner is great for holding corners together in crown along with 2p10, cabinet doors to help hold the joint while glue dries etc.
I have the grex and really like it. i went with the one that shots 1 3/8, larger than that I fell is not worth it. stick with 18g
Kreg
It's the details that make the difference.... pay attention to them.
kreg mcmahon is offline
Good hardwood floor nailer? Project53 Flooring 5 05-16-2007 01:02 PM
brad nailer question roo Finish Carpentry 4 11-17-2006 01:17 PM
21g Brad nailer Nick H Tools & Equipment 11 09-21-2006 02:51 PM
16 gauge straight finish nailer karma_carpentry Tools & Equipment 11 09-01-2006 02:35 PM
Ridgid 16g straight finish nailer ryan.s Contractor Swap 0 03-03-2006 02:35 AM
