Trade: building consultant
Bostitch N88rh
My N88 double shoots nails almost every other shot?
Re: Bostitch N88rh
Mine doesn't, and has had a lot of nails through it including metal connector nails.
Trade: Carpenter/GC
Re: Bostitch N88rh
A. boom-nail, boom-nail, are you fighting the recoil, double tap, does this model have a sequential trigger available.
or B. boom 2 nails. worn/bent drive pin? generic nails? have had a full case of nails that the angle was off just enough to screw things up. from Bostich site "The nailer’s lightweight design, powerful engine and ability to drive full round head framing nails makes it ideal for building with engineered lumber and drives into laminated beams with ease. " Does this gun use clipped and full head nails? |
Re: Bostitch N88rh
If it has the gray colored trigger installed, it is sequential trip.
If it has the black colored trigger installed, it is contact trip. And it shoots round head plastic collated 21* nails. |
| The Following User Says Thank You to Kgmz For This Useful Post: | Aframe (09-29-2009) |
Re: Bostitch N88rh
Thank you for the responses
It has a gray trigger- round headed nails from Bostich I may need to be rebuild as my former employees were not very easy on the equipment they did not own-
| help rebuild bostitch naile gun | workingjoe | Tools & Equipment | 8 | 08-17-2009 09:30 AM |
| bostitch flooring stapler | mhillc | Flooring | 3 | 08-07-2009 12:23 PM |
| Bostitch BT-200 (18ga Brad Gun) | jcalvin | Tools & Equipment | 4 | 06-29-2009 05:04 PM |
| can you use bostitch roofing nails in a hitachi? | mikeybobo | Roofing | 2 | 12-31-2008 08:40 AM |
| do bostitch roofing nails fit a hitachi? | mikeybobo | Tools & Equipment | 0 | 12-30-2008 09:46 PM |
