Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Equipment & Safety > Tools & Equipment
Old 01-24-2005, 06:01 PM   #1
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Bosch jigsaw
One of the biggest problems I am faced with is cutting thick stock (up to 2 inches thick) in scroll patterns and keeping the cut perpendicular.
Bosch has come out with a new jig saw trying to help with the issue and from reviews so far the results seem to be better than other attempts by other manufacturers so far. They are calling it 50% more blade accuracy which is a lot if it is true. It has two arms that clamp down on the blade with the press of a button, they end up just off the work surface.
1) Never owned a Bosch anything - how do they stack up in your experience.
2) In regard to specifically what this saw is designed to do, do you have any tricks or techinques you have adopted, I've gone so far as purchasing blades based on thicker the better, putting in an exagerated table tilt prior to cutting... ect...
Mike Finley is online now   Reply With Quote
Old 01-24-2005, 07:29 PM   #2
JustaFramer's Avatar
Trade: General Carpentry
I have used the older Bosch jigsaw and I liked it. I did have trouble cutting 2 by material that was not a soft wood. But over all I would buy one if I used a jigsaw all the time.
I do like the bosch skill saw too except for the tables look at them wrong and they break. Would prefer a MAG 77 table to the bosch's.
JustaFramer is offline   Reply With Quote
Old 01-24-2005, 07:40 PM   #3
Trade: underground
I have both a Bosch jigsaw as well as a Bosch roto-hammer. I love both.
I bought the jigsaw after repeatedly trying, with my old Craftsman, to cut a decent semi-cirle out of a piece of 3/4 plywood I was using to make a basin pedestal. What a joke that was. I'm in no way shape or form a carpenter but with the Bosch and was able to cut a near perfect edge on the first try. I've only used it about a dozen times since on odds and ends but I sure love having a tool that makes me look good. The blade guides do just what they're supposed to.
After trying for 30 minutes to get a Hilti salesman at HD I bought a Bosch 'Boschhammer'. We use it pretty frequently for both drilling and chipping. I use to exclusively buy Hilti hammerdrills - never again after using the Bosch.
PipeGuy is offline   Reply With Quote
Old 01-24-2005, 08:01 PM   #4
Teetorbilt's Avatar
Bosch are the only saw of this type that I have purchased in the last few years. IMHO they are the best.
No 'tricks' just the standard stuff, right blade for the job, shoe square with the blade, blade sharp, take your time and let the tool do the work. Most people try to use this saw too fast, this will cause the blade to dull quicker and also cause it to deflect off of hard spots like knots. Once the blade bites it (bends, dulls on one side more than the other, overheats) the straight cut is over.
Teetorbilt is offline   Reply With Quote
Old 01-24-2005, 11:41 PM   #5
Chief Toilet Mover
What about pinching the tip of the blade between two fingers and trying to hold it against the wood so it stays straight up and down? Every try that?
Old 01-24-2005, 11:53 PM   #6
Trade: underground
This is what I use for doing delicate scroll work in thick stock.
Just plunge cut right down to the bumper spikes and scroll away :Thumbs:
Old 01-25-2005, 12:28 AM   #7
Chief Toilet Mover
Only problem is when the kids...
and the pets...
get ahold of your tools!
Old 01-25-2005, 12:44 AM   #8
Trade: underground
Lmao
Old 01-25-2005, 12:50 AM   #9
Trade:
Funny Mike..
I've got a Dewalt that looks similar to the Bosch. I've had good luck with it-- best I've had as far as blade deflection. It has a wheel that stabalizes the blade and/or changes the stroke of the blade for faster cutting.
trekr is offline   Reply With Quote
Old 01-25-2005, 01:42 AM   #10
Chief Toilet Mover
I think I might have the same one you are using. But the wheel on mine where the blade sits is a bit wide so the blade has a lot of play back and forth and the wheel sits about a 1/2 inch above the work surface making it even less effective. The design of the Bosch looks to be a bit better, making it the reason I am considering getting one if it really would help.
Hey, why would someone prefer the handle grip configuration
over the barrel grip configuration?
Old 01-25-2005, 08:47 AM   #11
Deck Designer/Builder
DecksEtc's Avatar
Trade: Deck Design & Construction
The handle grip makes it easier to run the saw with one hand and hold your stock in the other hand. I do a lot of my work solo and when I use a jigsaw it isn't for overly precise cutting, eg. cut-outs in deck surface for posts, cut-outs for skirting around posts, small notches, etc. I do my cuts right next to where I'm working and don't like to waste time clamping things down or having to make my flunkie run over and hold the wood.
Also, not that it's as good a jigsaw, but I picked up a cordless Ryobi last fall. It doesn't do the absolute best cuts on thick boards but for 3/4" skirting or 5/4" deck boards it works good - especially since I use cedar the most. Not having another cord to worry about and move around made the $99 investment well worth it.
I am the liquor - Jim Lahey, Trailer Park Supervisor
www.decksetc.ca
DecksEtc is offline   Reply With Quote
Old 01-25-2005, 09:21 AM   #12
Teetorbilt's Avatar
I found the barrel grip a little awkward at first but now I am used to it and there really isn't much difference.
Old 01-25-2005, 11:26 AM   #13
cdac
Guest
Trade:
Posts: n/a
Makita Vs. Bosch gtdail Tools & Equipment 38 04-10-2009 05:58 PM
bosch scms wobble Mrmac204 Tools & Equipment 3 07-26-2007 10:29 PM
Bosch 10.8 volt Pocket Driver highlife77 Tools & Equipment 3 04-11-2007 05:57 PM
Bosch Router Table dayspring Tools & Equipment 4 06-14-2006 09:31 PM
Used a Bosch 2.4 gigahertz drill today IHI Tools & Equipment 0 04-27-2006 10:30 PM
Contractor Talk™ © 2003 - 2010 The Building Network LLC
