Steve
Trade: Remodeling and Custom Cabinets
Bosch Angle Finder Spring Angle ? Storing For The Day Possible?
Anyone know if you can store the spring angle for the entire job? Setting the spring angle before measuring each corner a bit of a pain. I had to set it 18 times today as I measured 18 corners
![]() Great tool, just a bit of extra work. Thanks in advance for any answers, Steve |
Trade: Residential Remodeling
Re: Bosch Angle Finder Spring Angle ? Storing For The Day Possible?
Nope you can't. It is a big problem and they are made aware of it, but haven't done anything about yet.
#3 | |
Re: Bosch Angle Finder Spring Angle ? Storing For The Day Possible?Quote:
No, - - you would have to re-set it every time. Just make a scrap piece of wood duplicating your spring angle and use it for a quick set every time. Also, - - it's easier to just take all your corner-angle readings at once, - - recording them as you go, - - then record your 'spring and corner' computations before you even make your first cut. Even faster yet if you attach your 'scrap-spring-angle-setter' right to your work-table , for a quick set and read . . .
http://www.tr-built.com Last edited by Tom R; 01-28-2008 at 11:15 PM. |
You're better off yet just using your angle-finder to read your corners and just have a chart handy.
I like the novelty of the angle-finder myself, - - but speed is of the essence, - - especially when doing more than just a few angles. And, as Jim (clampman) pointed out in one of these crown threads a while back, - - a degree or two variation from 90 (or whatever) in your corner angle affects your fit very, very little . . .
http://www.tr-built.com |
| How do I cope for an obtuse angle? | karma_carpentry | Finish Carpentry | 9 | 01-10-2009 08:40 AM |
| Bosch Tools. | Tw. | Tools & Equipment | 10 | 12-11-2007 04:55 PM |
| Best way to attach angle to this? | sandyman720 | Masonry | 6 | 09-25-2007 08:17 PM |
| Brick Veneer on steel angle iron | sandyman720 | Construction | 9 | 07-15-2007 05:20 AM |
| bosch angle finder, chestnut clamps | summertime | Tools & Equipment | 9 | 09-27-2006 05:59 PM |
