Bit Stuck In Router - Tools & Equipment - Contractor Talk
Bit Stuck In Router
Old 05-19-2015, 11:45 PM   #1
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
Bit Stuck In Router
I have a dewalt dw625 that never seems to want the bit go. I take the nut off the collet but the shank of the bit never wants to come out. I rarely use this router as a result. has anyone experienced this? Any tricks to getting them loose?
It really shouldn't be this difficult.
philcav7 is offline
Old 05-19-2015, 11:51 PM   #2
Radical Basement Dweller
Robie's Avatar
Rewards Points: 660
Re: Bit Stuck In Router
http://www.contractortalk.com/f40/i-...it-out-141428/
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is offline
Old 05-20-2015, 12:04 AM   #3
philcav7's Avatar
Perfect. Looks like I'm not the only one.
I also have a 30 year old craftman router, bits come out with ease. There must be a bunch of corrosion in the dewalt.
philcav7 is offline
Old 05-20-2015, 09:54 AM   #4
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
Make sure you don't bottom out the bit. A small rubber bead dropped into the collet helps.
Rustbucket is offline
The Following User Says Thank You to Rustbucket For This Useful Post:
GettingBy (05-20-2015)
Old 05-20-2015, 11:46 AM   #5
GettingBy's Avatar
Rewards Points: 6,486
Giving one of the three jaws in the chuck a whack with a nailset or drift pin may free the bit.
If not, a copper tube slightly larger than the bit dia. and slid over the bit and whacked, will give all three jaws a nudge.
Oil in the chuck may prevent normal operation. WD40 is not a lubricant but it may also work, depending on the root cause of the binding.
See troubleshooting at the end of
http://buckchuckusa.com/userfiles/fi...C%20Manual.pdf
I couldn't find a patent claiming to cure this so it may fall under normal maintenance (like checking GM brake lines for rust).
The next most credible are pdf files, IMO.
http://www.techniksusa.com/metal/holder_maintenance.htm
Mech or metallurgical engs are welcome to chime in at any time, BTW. I know you are out there!
GettingBy is offline
Old 05-20-2015, 12:12 PM   #6
Texas Wax's Avatar
Rewards Points: 1,008
Tap the bit metal to metal with a small hammer or wrench. In a circular fashion around the end of the bit. A little oil may help.
Another option is to block between the locking nut and bottom of bit with hardwood, then loosen the nut.
It's a tapered fitting. Even the best machined tapers can hold tight. When the machining is rough, they hold even harder.
Reefing the chit out the locking nut is the most common cause of it not loosening up. Weather conditions and just the oil on your hands can cause a little rust, making it even harder to loosen.
Taking a little 600-1000 grit to the taper in the arbor and outside of collet might help. Remove the burrs from the machining, that lock this tight. Keeping all "LIGHTLY" oiled doesn't hurt either.
Texas Wax is offline
Old 05-20-2015, 12:21 PM   #7
Texas Wax's Avatar
...OR
Biggest pipe wrench you got, on the bit and 6' of pipe over the wrench for leverage.
Maybe a rag over the bit, to protect it
Made in USA product list J.C. General Discussion 360 06-16-2018 04:52 PM
Looking for CNC Router for woodcarving recomemdations donschaeffer New Member Introductions 3 05-31-2013 05:31 PM
Router bearings shot? dkillianjr Tools & Equipment 8 03-14-2013 11:06 PM
Router talk....101..... PrestigeR&D Tools & Equipment 94 12-16-2012 09:58 PM
Colt router base creep Cole82 Tools & Equipment 32 11-15-2011 06:31 AM
