Best Utility Knife
Old 02-11-2008, 08:55 PM   #1
JourneymanCarpenterT
Journeyman T's Avatar
Question
Best Utility Knife
Okay, this thread may more aptly be titled: “What is the brand that sells what I think is the best utility knife?” That’s a little long, so “Best Utility Knife” will have to do.
Do you remember those retractable grey plastic (metal blade release button) utility knives with the yellow (Stanley) or red (Craftsman) plastic blade storage compartment that were a dime a dozen just less than a decade ago? They were the only retractable utility knife with quick blade change and blade storage I’ve ever used that wouldn’t lose its grip on the blade when cutting drywall. Notice: I said the only retractable utility knife.
Stanley still makes a similar retractable quick-change that’s even made out of metal, but despite the higher quality of material (metal vs. plastic), it doesn’t hold the blade rigid (the blade wobbles slightly) and it doesn’t hold the blade secure – the blade fly’s out of the knife when scoring down a sheet of drywall.
The old retractable metal Stanley knife that goes for $3.99 is great except for the fact that you have to unscrew it and screw it back together to change a blade.
Sheffield makes a very elegant utility knife that holds a blade very rigid, just secure enough, and blade changes are almost as quick as the standard “quick change” models. However, the knife does not have any capability for blade storage. It also folds instead of retracts, which in certain situations, can be somewhat of a nuisance.
At first glance, the retractable plastic Irwin knife would seem to be the obvious choice. However, the blade does not change so quickly, simply because the blade storage clip is something you must be rather careful with if you have more than one blade in it. The knife is also rather fragile, and you can feel it pushing apart in your hand as you apply downward pressure on a cut. The real bad thing about it being fragile though, is that it breaks too easily. I’ve also bought some that have held the blade safely secure as well as some that don’t. It seems to be hit or miss.
Yeah, I know what you drywall guys are thinking: “Use a fixed blade utility knife for cutting drywall.” Well, I have one of those. What I’m looking for here is an all-around utility knife that can be relied on for everything.
I’m looking for a utility knife that must meet all of these qualifications:
Retractable
Quick Blade Change (Without a screw gun)
Secure Blade (Won’t release blade when applying strong downward pressure)
Rigid Blade (Blade doesn’t wobble when locked in knife)
Blade Storage Capability
Not too big and bulky.
Any ideas?
Journeyman T is offline
Old 02-11-2008, 09:12 PM   #2
Palisade Point Const.
TempestV's Avatar
Re: Best Utility Knife
Have you tried the Stanley knives with the push button blade change? In my experience the blade seems to be pretty solid, the blade changes are quick, it stores blades, and both of them are the same size or smaller than the Irwin knife.
Personally, I use the Irwin knife, I got it part way through a sheetrock job, and the very first couple cuts (#1 and #3), the blade fell out. However, after that, it hasn't given me any trouble, and it is way more solid than my old Stanley which was one of the yellow quick change ones you mentioned. I haven't had any trouble carrying 4 or 5 blades in the spare blade clip. I also have a little ten pack storage box that I keep in my bags that I fill from the big pack, which may be a way to go if your chosen knife doesn't store as many blades as you want.
TempestV is offline
Old 02-11-2008, 09:16 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
I have a Lennox that holds extra blades in the handle and has quick change. The blade has a LITTLE wobble to but it may be your best bet, I dont know for sure. The blade change on it is a little funny though. First you slide it out and then press the slider to the side and pull the blade out. The first time I opened it up I could not get the blade in and I was pissed. Once I figured it out I felt stupid.
RobertCDF is online now
Old 02-11-2008, 09:19 PM   #4
al10fred1081's Avatar
Trade: Carpentry/ Home Improvements
I use the newer stanley quick change. holds the blades and the quick change works good. doesn't hold the blade completely tight, but if you have a steady hand its not bad. I do a good bit of sheetrocking, but a lot more aluminum work. Some guys I worked with swore by the Lennox gold, which is a nice knife but for the cost its too damn big!!!
Also watch out for the Lennox blades, you can't break em off for a new edge like you can standard blades.
al10fred1081 is offline
Old 02-11-2008, 09:40 PM   #5
mickeyco's Avatar
Trade: Squirrel Handler
The silver one on the bottom (already had the pic on photobucket).
mickeyco is offline
Old 02-11-2008, 09:42 PM   #6
Royal-T's Avatar
I unfortunitely have to agree with al10fred which sucks because we work together and he sucks (haha) but I have used them since they came out and after you beat them up for a few years they wont hold the blade as well as they used to but for the 3 bucks you spend on them they are the best money can buy. The Kobalt flick blades are awesome flicks open like a pocket knife, holds extra blades and has a clip! By the way al10fred you better get up to finish that nightmare in the morning!
Royal-T is offline
Old 02-11-2008, 09:44 PM   #7
TempestV's Avatar
Originally Posted by al10fred1081 View Post
I
how exactly do you break off a standard utility knife blade to get a new edge?
TempestV is offline
Old 02-11-2008, 09:44 PM   #8
JumboJack for president!
XanadooLTD's Avatar
Trade: Hilti walking billboard
Sarge locking knives are good with Lennox blades indestructable.
XanadooLTD is offline
Old 02-11-2008, 09:47 PM   #9
Deck Designer/Builder
DecksEtc's Avatar
I'm very happy with my Olfa.
DecksEtc is offline
Old 02-11-2008, 09:48 PM   #10
Royal-T's Avatar
Press down sideways to snap it or tin snips and cut the tip down to get a fresh cutting surface. Learned that trick while doing metal work in Nam!
Royal-T is offline
Old 02-11-2008, 10:00 PM   #11
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
I have the lennox with retractable blades. It fits my hand well and the blades are really tough. I think it is the best knife out there imo.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 02-11-2008, 10:35 PM   #12
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
I have a irwin and love it. The stanly holds up fine but the blade doesnt move real well then throw some tarry junk on it or drywall dust and your goofing off for 20min to get it to work. The irwin is nice and smooth but thr quick change isnt as quick as the stanly. Some of may favorite and usualy always use are the nonretraclables.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 02-11-2008, 10:43 PM   #13
threaderman's Avatar
Trade: Plumbing & Gas Contractor
I've got the same model .It feels really nice in the hand and is overall really rugged.
threaderman is offline
Old 02-11-2008, 11:30 PM   #14
dkillianjr's Avatar
Heres my favorite. Its cheap, light, easy blade change, simple, and indistructable. Stanley 10-499. Before it I always had the old style stanleys that you had to take the screw out of to change blades, they I went to a big yellow one like in Mickeys picture, after it cut my hand I burried it alive in a foundation . Then I switched to the stanley 10-499. I always use the stanley heavy duty blades. Anyone use the gold tipped Lennox blades, how are they?
dkillianjr is offline
Old 02-11-2008, 11:33 PM   #15
EVIL GENIUS
I use the titanium blades and they cost like $2 more but last like 10x as long.
U.S. Coast Guard
Old 02-11-2008, 11:41 PM   #16
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
OLFA HD-1
Now legal in California...I used to have to import them when I first got here, something about a blade extending more than 6" was a weapon
Chris
Chris Johnson is online now
Old 02-12-2008, 12:02 AM   #17
mdshunk's Avatar
I use the same one dkillianjr uses. I used to use the regular 99, but now I use that one he shows there with the quick blade change. Anything fancier gets away from you too fast.
mdshunk is offline
Old 02-12-2008, 12:06 AM   #18
Univ. of Hard Knocks
beachremodlr's Avatar
Trade: Renovations & Remodeling
Maybe it's just me, but it is a fact that at least two of my most important tools are always breaking. I have had the worst luck with knifes and tape measures over the last year or so. Past fall, I bought 5 different ulility knifes and either couldn't stand the new designs, or it was crap.
Without paying the cost for the new Lennox, I settled w/ a stanley, quick release blade, and multiple blade storage, but even my first one was broken when I bought it.
The Schefield is for picking dirt out of your fingernails.
The same w/ tapes, love the stanley fat max, but they recently changed their return policy and aren't replacing them, even if the face has no damage and the tape is breaking. Should have returned my 3 broken ones in Dec.
Grandpa used to say "you could tear up a steal anvil w/ a rubber bat".
Knowledge is Power. Learning more about what I do, Is all in a days work!
beachremodlr is offline
Old 02-12-2008, 01:02 AM   #19
JamesNLA's Avatar
Trade: Plumbing & Electrical
Ditto. I really like thier line of titainum edge blades. Not only for the utility, but for sawall blades. BY FAR the longest lasting blades I have ever seen and I have had them all.
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 02-12-2008, 01:56 AM   #20
Carpenter/Finisher
john5mt's Avatar
love my lennox
i have 2!
john5mt is offline
Main utility hook up questions Badfish740 Construction 5 10-11-2007 07:01 PM
What utility knife do you use? Michaeljp86 General Discussion 33 08-20-2007 06:10 PM
STAR Gas Powered Utility Pump LNG24 Tools & Equipment 0 02-06-2007 11:11 PM
Utility Service Work denick Excavation & Site Work 6 01-03-2007 09:31 PM
Finally got my proof on utility meters. K2 Electrical 17 10-23-2006 09:55 PM
