Best Rotary Self-leveling Laser Level
Old 05-07-2010, 08:28 PM   #1
doc7string's Avatar
Trade: home builder
I am planning to purchase a laser level, rotary, self leveling. I will be using it for trimming (chair rails etc.) drop ceilings, leveling footers and such. I want to spend $500 to 600. Accuracy is obviously of greatest importance as is reliability. I would also prefer a thin line to be projected rather than a wide line if possible. Any suggestions would be greatly appreciated!
doc7string is offline
Old 05-07-2010, 09:08 PM   #2
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,076
Re: Best Rotary Self-leveling Laser Level
Do an intro then you will get some answers to your questions
Anderson is online now
Old 05-07-2010, 11:47 PM   #3
wellbuilthome's Avatar
Trade: building for 30 years. new homes , additions
Rewards Points: 250
I had a few lasers over the years , But just bought a PLS 360 on amazon for around 700 bucks.
Its pretty accurate and shoots square lines around the room and on the floor .
I have a PLS 5 for lay out . John
wellbuilthome is offline
Old 05-08-2010, 07:21 AM   #4
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Send a message via AIM to ApgarNJ
I have one like this, but it's orange and several years old. I have used it interior and exterior. I'm sure there are many features I haven't used it for, but I like that I can just turn it on, it levels itself and works great.
http://www.engineersupply.com/cst-be...mh600-pkg.aspx
i didn't buy it from there, i was looking for my actual model but that one is the more recent model i think. i don't have a remote control with mine, nor does it work with one.
ApgarNJ is offline
Old 05-08-2010, 07:01 PM   #5
doc7string's Avatar
Trade: home builder
Thanks guys for the replies. I will check those out.
Old 05-08-2010, 07:18 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,259
Doc, I don't know if its like this everywhere else, but around here on Friday I noticed that Lowes had 50% off on their lasers. I saw one that was regularly $500 for 250.
Easy Gibson
Warren is online now
Old 05-08-2010, 07:21 PM   #7
doc7string's Avatar
Trade: home builder
I will check that out right away. Thanks for the tip.
Old 05-08-2010, 07:35 PM   #8
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
PLS 360 is not a rotary laser, but is throws a beam 360 degrees, it has a finer beam than my $2500 Spectra GL422.
For what you mentioned the PLS 360 would be a good choice.
Here is a used one with detector, they both come with the bracket for doing suspended ceilings.
http://cgi.ebay.com/PLS-360-System-S...item27b195d9ba
and a new one with detector
http://cgi.ebay.com/PLS-360-SYSTEM-L...item4cef398108
bwalley is offline
Old 05-08-2010, 07:44 PM   #9
doc7string's Avatar
Trade: home builder
After looking on their web site I noticed that was the case, but as you say it still throws a beam 360 deg. I didn't know the beam was finer, but that is exactly what I am looking for. I will certainly check that one out as it seems to fit the bill.
Old 05-08-2010, 07:51 PM   #10
Pompass Ass
bwalley's Avatar
For what you are looking for that is what I recommend, I have about a dozen lasers, most of them are PLS and for what you are doing I would huse the PLS 360 for probably eveything, except maybe leveling footers depending on how far they are, the PLS 360 can be used for that as well if you get the kit with the detector.
plus the PLS 360 can be had new for less than the bottom end of your budget.
I kind of like the fact that he PLS 360 is not rotary, it throws a cleaner and finer line because of it.
bwalley is offline
Old 05-08-2010, 07:56 PM   #11
J F's Avatar
Saw the same thing here in GA.
J F is offline
Old 05-08-2010, 08:03 PM   #12
doc7string's Avatar
Trade: home builder
Hey bwalley, I really appreciate the input. I certainly would get the kit with the detector. Given what I'm willing to spend and what I will be using it for, I will likely be purchasing the pls 360. Thanks for the comparison to your other laser too. It seems the pls is a real bargain.
Old 05-09-2010, 08:10 PM   #13
Rewards Points: 250
doc you need the detector for any out side work I bought mine on amazon a few weeks ago . I think i payed $660 if i remember correctly .
Old 05-09-2010, 08:22 PM   #14
doc7string's Avatar
Trade: home builder
Hey wellbuilthome, do you have the pls 360 or something else? I am just about sold on the pls 360, I just need to go look at one first. And yes, I will be doing some outdoor work.
Old 05-09-2010, 10:55 PM   #15
Pompass Ass
bwalley's Avatar
Here is a new PLS 360 with detector for $439
bwalley is offline
Old 05-10-2010, 08:21 AM   #16
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
They done the same thing here. The whole lazer section was empty and the day before it was full. Guess most of the employees had the bulk of them away to sell on ebay. perhaps they are going to stock some new brands.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-10-2010, 02:36 PM   #17
Dan
ApgarNJ's Avatar
i'll have to check out lowes next time for that bosch tile laser. that makes the 90 degree lines out. looks like it would be great for larger tile floors. i have always snapped lines and gone off them but for that you can check your work as you are going and lines you cover up with thinset as you move across.
ApgarNJ is offline
Old 05-10-2010, 03:29 PM   #18
Pompass Ass
bwalley's Avatar
PLS makes one, it is a PLS 90, not cheap but it is a great laser.
the lasers you see at the home centers are not the same quality as the PLS lasers.
bwalley is offline
Dewalt Rotary Laser problems?? bowhunter Tools & Equipment 26 10-12-2015 07:42 AM
rotary laser level eric131 General Discussion 70 05-29-2013 01:05 PM
Rotary laser Cache General Discussion 8 01-15-2010 08:12 PM
rotary laser level eric131 Decks & Fencing 2 05-19-2009 12:45 AM
Laser level for top plates on partition walls? personalt Framing 3 11-12-2006 09:58 AM
