Best Line Laser Level
Old 09-29-2012, 04:28 PM   #1
calmod's Avatar
Trade: general contractor
Rewards Points: 128
hello forum
I currently own a rotating laser that I use for footings and decks, etc. It works great but it's difficult to set up to easily shoot a line to set cabinets, outlets, etc etc off of. I'm always fooling around with the tripod up and down and it seems overkill. I need recommendations on a line laser ( if that is indeed what i need and the terminology is correct) to shoot lines. Horizontal is a must and vertical would be nice. If it has a plumb bob feature that would be a major plus. Easy mounting on studs with possibly a camera tripod option. The market place seems like there are many options but if you could help me out it would be greatly appreciated.
Thanks!
calmod is offline
Old 09-29-2012, 04:44 PM   #2
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,382
Re: Best Line Laser Level
This is the one I have and I flippin' love it.
http://www.plslaser.com/line-lasers/pls180
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
Tom Struble (09-29-2012)
Old 09-29-2012, 06:11 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
i have that one too Joe..it's super
Tom Struble is offline
Old 09-29-2012, 09:32 PM   #4
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
we have the 360, it gets used all the time for our icf foundations.. stick framing. siding elevations and setting deck ledgers.. only prob is its a little off and needs to be calibrated.. if that can be done
woodworkbykirk is offline
Old 09-29-2012, 11:19 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,854
I have a Hilti PML-32, I like it a lot.
KillerToiletSpider is offline
Old 09-30-2012, 01:19 AM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Look at PLS & Spectra for some quality products...
griz is offline
Old 09-30-2012, 08:49 AM   #7
Working
Cole82's Avatar
Rewards Points: 2,276
Send a message via AIM to Cole82
PLS180 with detector is a nice laser.
To make the height adjustments out doors I use a very lightweight camera tripod that cranks up and down.
When inside I just stick the pls to the metal corner bead for outlets and cabinets.
Cole
The boss of awesome
Cole82 is offline
The Following 2 Users Say Thank You to Cole82 For This Useful Post:
CENTERLINE MV (09-30-2012), Tom Struble (09-30-2012)
Old 09-30-2012, 09:05 AM   #8
Dirtywhiteboy's Avatar
Rewards Points: 7,584
Cole
I've been having trouble with my detector I reads a inch different? I will get 2 readings a inch apart from one another
Dirtywhiteboy is offline
Old 09-30-2012, 09:08 AM   #9
Trade: siding
Rewards Points: 4
i remember you saying that..if you look close at the detector it seems impossible that could happen
Old 09-30-2012, 09:18 AM   #10
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Originally Posted by Tom Struble
I remember you saying that.. If you look close at the detector it seems impossible that could happen.
Got it Jay..
ohiohomedoctor is offline
Old 09-30-2012, 09:57 AM   #11
Trade: siding
Rewards Points: 4
looks alright to me..
Old 09-30-2012, 10:11 AM   #12
Working
Cole82's Avatar
PLS will calibrate it for you. never had a detector go bad but have had a couple lasers go bad. You check a laser just like a level. Shoot it to one wall 25' away then flip 180deg if the marks don't line up it needs recalibrated. The self leveling lasers have magnets in them that help keep the laser from flopping around uncontrollably when transporting the laser. They can shift over time and need to be recentered.
Cole
The boss of awesome
Cole82 is offline
Old 09-30-2012, 10:32 AM   #13
Joseph A. Capece
I had that happen to me the other day with my reader but I just assumed it was because I was using at close range (under 10').
Old 09-30-2012, 12:21 PM   #14
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,052
I have a PLS 180 also, I use a 3rd hand extension pole with a piece of cloth on top then stick the laser to that. I tried the camera tri-pod but it was always an inch too low.
Inner10 is offline
Old 09-30-2012, 12:38 PM   #15
Hack
asevereid's Avatar
Rewards Points: 126
Hilti PMC 46...works great, but the prism does not lock for transport.
http://www.hilti.ca/holca/page/modul...nodeId=-244652
asevereid is offline
Old 09-30-2012, 01:51 PM   #16
Trade: siding
Rewards Points: 4
neither does the pls 180
Old 09-30-2012, 01:53 PM   #17
Inner10's Avatar
Do any of them?
It concerned me a bit that it sounds like a can of spray paint when you shake it.
Inner10 is offline
Old 09-30-2012, 01:55 PM   #18
Trade: siding
Rewards Points: 4
don't know...pls claims it's not needed i think
Old 09-30-2012, 01:57 PM   #19
Inner10's Avatar
Yeah that's what I tell people when they ask about features my competition suggests.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
JT Wood (11-30-2013), Tom Struble (09-30-2012)
Old 09-30-2012, 02:07 PM   #20
Working
Cole82's Avatar
Originally Posted by Inner10 View Post
Do any of them?
My rotary laser does. Ironically it broke and have just been using the pls now.
Cole
The boss of awesome
Cole82 is offline
What brand Rotary Laser Level mewoods Tools & Equipment 21 03-07-2012 03:04 AM
rotary laser NjNick Tools & Equipment 5 11-14-2010 06:09 PM
What size and kind of service line? help !!! mebedave Plumbing 10 10-31-2010 03:41 PM
Hilti PR 26 Laser Level XanadooLTD Tools & Equipment 2 07-15-2009 04:28 PM
Line levels Tscarborough Masonry 26 03-15-2008 12:58 PM
