The Best Electrical Lug Crimpers
Old 08-01-2007, 09:00 PM   #1
Teetorbilt's Avatar
Rewards Points: 2,000
Manual (bolt cutter) type, no 'hammer type'. Prefer the hex crimp. From 6 Ga. - 2/0 battery cable.
Albert Einstein
Teetorbilt is offline
Old 08-01-2007, 09:13 PM   #2
mdshunk's Avatar
Rewards Points: 2,002
Re: The Best Electrical Lug Crimpers
Among electricians, the Thomas and Betts TBM6 is pretty much the standard crimper for that sort of work. There are many nearly identical copies of this same tool under many, many brand names. TBM stands for Thomas and Betts Method, and the 6 is for the six-ton crimping force. It makes a hex crimp or a round crimp depending on the die you click in it, and has dies available for about anything you'd ever want to do. Typically, you crimp copper with a hex crimp, and aluminium with a round crimp, but the actual terminal you're using will have that specified. The tool I'm recommending does #8 through 500 MCM. They show up on eBay every day for between 100 bucks and 500 bucks, depending on how many dies the seller is including with the tool. This is pretty much the real-deal; the be all and end all of manual crimping tools for the larger terminals.
mdshunk is offline
Old 08-05-2007, 11:05 PM   #3
canuck88's Avatar
Trade: Electrical
I use the TBM6, as does pretty much everyone else I know...
canuck88 is offline
Electrical License in PA ABLE1 Low Voltage 29 10-25-2010 11:20 AM
What the worst electrical safety issue you have seen? SuperiorBuilt Electrical 63 01-01-2010 11:28 PM
Electrical Riser Diagram nehal101083 Electrical 9 02-09-2007 05:30 PM
Question regarding surplus electrical material solcam Electrical 2 07-25-2006 05:31 PM
On discouraging DIY electrical work... mdshunk Electrical 52 02-17-2006 11:58 PM
