#61 |
I like Green things
Re: Best Cordless 18V Drills?
hmmm sony, sounds familiar.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
#62 |
Trade: Control Systems
Warner I'm not trying to piss on your parade but there are some valid points here.
Even my old dewalt 18v would twist out of my hand, I realize I'm no hulk hogan but I abused that sucker for 5 years using a 1X18" ships auger on a daily basis. Hilti also has the overload protection chip in their batteries, and you can charge them from any load without effect because it monitors the charge level...just like Festool. Makita has a smart charger but there is no protection circuitry in the battery itself. Dewalt has a simple version that shuts the battery down then uses the charger as a re-set. When you supply tools to a few other guys I'd rather pass them a ryobi too, handing off a festool just isn't right! The biggest mistake I made was buying Hilti twist drill bit sets, its cost me a small fortune replacing thoes broken bits from guys who can't hold a drill straight. 3 year warrenty, whoopie not much above Ridgid/Milwaukee/Makita etc. Espicially if you look at replacement cost. Brushless motors and electronics make for a more efficient drill with fewer wearing parts but it also adds more electronic complexity to fail. Although I agree that brushless is the way of the future for drills. Slow chargers can also be really aggrivating, espicially if one night you have a severe case of "gethomeitis" and leave yourself with a fraction of a charge in one battery, next day you drive a few screws and then are forced to wait for the battery to charge. I think Festool tools are fantastic but their cordless drill (along with most of their tools) are aimed at workshop use not feild use. They have some outstanding features (espicially the badass chuck system) yet for someone in my line of work they would not be a panacea. |
#63 | |
I like Green things
Re: Best Cordless 18V Drills?Quote:
It is expensive because it is built to hold up to job site abuse and still be highly accurate. Don't say it can't when you haven't. It will out last almost anything out there.
#64 |
Just tell me its a POS so that I don't end up buying one and wind up single...I'm easy to sell too and I'm good at ignoring yelling.
Closest festool dealer is Brockville, about a 45 min drive, all highway, unless I move or one comes to Ottawa I can't see taking the plunge. |
#65 | |
Trade: Construction
Also i dont think the Festools are designed to be used the way some of use some of these tools. 15v drills aint really desined to bore 1"+ augers and 5" hole cutters. They would run of of TQ before you would finish each hole. Even my makita with almost double the TQ of the Festool struggles with some of the stuff i drill. But there's no doubt they are a great tool if they are within the specs you require. Last edited by BCConstruction; 09-03-2009 at 07:49 AM. |
#66 |
I like Green things
We bored 1" auger holes in a piece of 8/4 poplar with the 15+3.
#67 | |
Trade: Construction
I should hope so for the cost of them. I have a crappy porter cable drill with same TQ and it would be able to do that. Porter cable one never used to be able to go through a 12" thick oak beam in a 500 year old cottage though. Even my Makita had trouble doing that. Only problem was battery used to get stupidly hot but it saved my pulling out the angle drill with reduction head on it. |
#68 |
Charitable animal
Trade: decks
I've always been a milwaukee man, no complaints with several 18v hammer drills and RAD, BUT, I can tell you that milwaukee's L ion batts absolutely suck $h!t, 2 years ago I picked up another 18 v lion hammer drill, and since then I've taken the batts (2) back to a milwaukee service center at least 3 or four times, upon diagnostic, they havent even been cycled but 50 or 60 times, finally just asked for nicads last time
#69 | |
Trade: Construction
It's to do with the quality of cells in the packs. Dewalts use the most expensive cells at about $2.50 a piece and they have about 15 of these in a cell. But they are a low MAH rating for the cost of the cell. Makita use cells that are about $2.30 a cell but they have more capacity because they are normal LI-ION. Milwaukee use cells that are about $1.20 a cell and they wont hold up anywhere near the length of time compared to the more expensive cells. |
#70 |
I like Green things
You guys do realize that some of the things you want a cordless drill to do, should be done with a drill that has a cord.
That might save your guy's cordless tools. Sometimes you cant improve on electricity.
#71 |
Trade: Construction
Your 100% correct lol. I have 2 sds drills that are exactly the same but one is cordless and one is mains and even when i need to drill a 2" hole in Engineering brick i still try to use the cordless knowing full well it will stop half way through lol. I have corded versions of most of my tools but still the Cordless get used a lot more than they should.
#72 | ||||
I've never used a cordless angle grinder, let alone seen one on a jobsite. |
#73 | |
Trade: Construction
Tell you what though. My mate could have done with some overload or clutch protection on his core drill as he was drilling a 4 inch hole in a wall and the core drill locked up in the wall and he spun the whole way around while holding the drill. Proper messed him up for the rest of the week lol. Funny watching it happen though.
#74 |
Trade: Home improvement contractor
I just replaced my Dewalt with the Hitachi 18V lith ion, havent really put it through its paces yet but I will report on how it does
#75 |
Trade: General Construction
Not the best replacement. From what I have read here you will be disappointed in the long run. There is a reason Hitachi battery tools are so affordable. Don't quote me on that.
#76 |
Trade: Custom Metal Fabrication/Residential Construction
I just picked up the Bosch 36v hammer drill with fat pack batteries the other day. Really didnt need a drill but got it for a steal at www.onetooladay.com sometimes you just gotta buy it. In any case was wondering if anyone has used this drill before as far as if it has good power, torque, battery life etc. I know its a 36v but that doesnt always mean more power...just a bigger battery. Besides it not like Im going to return it but would like to know what I have in my truck when I do decide to use it. Thanks.
#77 |
Trade: Builder, Custom Timber Structures
I've always used the dewalt 18v but it sounds like I should try the Hilti.
#78 |
Trade: HRV
I talked to my local tool repair guy today. I asked him what the best was and he says they all suck since box stores. Makita Dewalt Milwaukee all low quality. The best he said was Hitachi. Hilti except the service out here is bad from what he said.
#79 |
I would find a new tool repair guy. Hitachi is far from the best. Milwaukee and Makita have the best cordless out to date, for the money.
#80 | |
Trade: Construction
Your tool guys need to go back to tool school lol. Hitachi the best! ![]() The problem with these places is most are biased towards what they sell or service even if they know better. They don't have hands on experience with tools and working on site with other trades teaches you a lot about tools. I cant remember how many lunch breaks i used to spend talking to other trades about their tools. |
| Replacement Batteries for Durabuilt Cordless Drills | duckdown | Tools & Equipment | 11 | 12-16-2010 08:17 PM |
| cordless jigsaw advice | cabinet runner | Tools & Equipment | 27 | 07-04-2009 07:04 PM |
| looking at a festool cordless drill | fr8train | Tools & Equipment | 31 | 05-10-2009 03:28 PM |
| Cordless Drills | Tw. | Tools & Equipment | 36 | 02-23-2008 10:18 PM |
| Impact Driver | Nick H | Tools & Equipment | 24 | 02-21-2008 07:37 PM |
