Sharp Improvements
Beltsander Breaking Belts???
I just bought a Bosch 12.5 amp 4x24 beltsander. I am using the 3x norton belts and they are popping way too soon. I am sanding sections of pine floors that are nail free. They seem to just pop whenever they feel like it. They pop across the belt not at the glued seam. I have burned through about $40 of belts. I am done wasting money. Any ideas?
Handle It!
Re: Beltsander Breaking Belts???
Too tight. Too loose. Improper sanding method......One or the other. Norton is on point as far as sanding medium is concerned. Only 3M can compete.
Handle It!
That is, unless of course, the drums are warped or out of "true".
Sharp Improvements
Well,
It has an arm when pulled it compresses the drum so a belt slides over. Once the belt is on you just push the lever that tightens the belt and tuck the arm away. I don't believe there is and any adjustment to loosen or tighten, just a one time application. I could be wrong though. As far as method goes, I couldn't be any gentler and still make it work and still not pop. |
Moderator
Which model is this sander?
Cabinetmaker
Norrrrrrrrrrrrrrrrm, there is a tracking adjustment on the belt. Keeps it from running off the rollers or cutting into the body if you have checked that and it is fine then I would be making a phone call asap to mfg.
Bosch makes good stuff and I know they will be all over it to resolve this issue. |
Sharp Improvements
It is the 1276 DVS. Any experience with this?
#8 | |
Sharp Improvements
Re: Beltsander Breaking Belts???Quote:
Moderator
Did it break the belt that was included in the box? The free one you got?
Is the port knob in the proper position?
Sharp Improvements
Thanks Double D's
I will check it out first thing in the morning. I tell you what, sometimes I don't know where I would be without you guys. e-hug for everyone!! Oh yeah, The factory belt did not pop yet. I have been using 24 and the factory belt is an 80. |
Trade: Kitchen & Bath
I'm curious how u made out with the belt sander. I have the same model. I never had any trouble with belts breaking other than the usual problem of nail heads sticking out of the floor and drywall screws on the loose(how do they elude my broom like that?) I often use the expensive Norton belts that are blue and it really burns me up when those things rip.
Sharp Improvements
A little update,
Well I went to check the knob that double A showed us and positioned the port knob at a different setting(only 2). I have only been using the cheaper belts and they seem to be better as of now. I have had a few pop at the glue seam. I think they were getting hot. I previously used up all the the expensive blue ones so I am not sure how they will fare with the adjustment. As I said in another post, they were popping across the belt, not at a seam. It was really strange. I think I have one 80 grit left and will try it tomorrow. I will let you know. |
#13 | |
Carpenter/fencing
Is there something stuck up in the sander that may be causing a tear? piece of wood, nail or staple? A belt generally does not break ,even with somewhat heavy usage. Sure its adjusted properly and not getting scored on the inside edge? I see this sander has a different style of adjuster? looks like it could also be the cause, the belts are overheating from being to tight?
Learning without thought is labor lost; thought without learning is perilous. Last edited by nywoodwizard; 03-23-2008 at 08:32 AM. |
| Circuits Breaking | barbie13607 | Electrical | 11 | 09-20-2007 03:27 PM |
| Sanding belts in the Florida heat? | MinConst | Carpentry | 1 | 07-17-2007 09:20 AM |
| Inspector breaking my balls or what? | Mike Finley | General Discussion | 26 | 03-01-2007 10:39 PM |
| Breaking Down T&M in Estimates | dirt diggler | Business | 9 | 09-13-2006 01:01 PM |
| buider breaking my heart | cynthiann | Painting & Finish Work | 9 | 04-07-2006 11:26 PM |
