Belt Sander Repair?
Old 10-04-2009, 06:25 PM   #1
Glid's Avatar
Belt Sander Repair?
Porter Cable Model 503 belt sander? I had to replace the brass gear (pinion) and the exploded drawing is not complete or is different for the worm drive stack up of parts between the motor fan and the sawdust fan. Can someone give me the stack up from the motor fan out? I have a cup that I think goes on one side of the worm gear that is unaccounted for on the exploded drawing. It has external thread, but nothing to screw into. The sander ran, but I don't think I had the stack right because it would stall out with pressure on the belt. Motor ran/belt didn't. The only thing that runs the worm gear is pressure from a spring on one side and friction from the shaft spinning.
Normally, I'd just get a new sander. But this is a beefy SOB and I had it for 30 years. A model 503 goes for $1000.00, so it is worth repairing.
Glid is offline
Old 10-04-2009, 06:38 PM   #2
LRG WoodCrafting
Leo G's Avatar
Re: Belt Sander Repair?
http://www.ereplacementparts.com/ima...503_TYPE_1.pdf
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 10-04-2009, 06:41 PM   #3
Railman's Avatar
Trade: Railing
Try this:
http://www.ereplacementparts.com/por...1997_2071.html
Joe
Edit:
Never mind, link won't work for some reason. It's the same as Leo's anyway!
Railman is online now
Old 10-05-2009, 07:18 AM   #4
Glid's Avatar
That's the link that I bought my parts from. The .pdf isn't right or doesn't match my stack up. Like I said, I have a piece that came out that is not accounted for. Plus, when I re-assembled per their diagram, it didn't work! Thanks for the input! I hate to bring things to the shop if I can fix them myself.
Glid is offline
Old 04-09-2011, 09:44 PM   #5
westrushia's Avatar
Trade: Repair
I have the same problem with my sander. did you find a solution to the bad info.
westrushia is offline
Porter Cable 371K 2 1/2" x 14" Compact Belt Sander dayspring Tools & Equipment 7 08-19-2009 01:51 AM
porter cable compact belt sander woodworkbykirk Tools & Equipment 17 05-03-2009 08:05 PM
Belt sander question larrys2006 Tools & Equipment 14 11-06-2008 04:41 AM
Belt Sander Recommendations pn70 Tools & Equipment 3 11-20-2006 09:17 PM
I need a new belt sander Leo G Tools & Equipment 7 12-28-2005 11:21 PM
